Question about LG GSA 4163B DVD±RW Dual Layer Burner
Drive wont open/eject
When I push the eject button, the green indicator light flashes 6 times slowly, followed by about ten rapid flashes, then another 5-6 times slowly, but the tray wont open. I assume this is some sort of error code. I have manually ejected the tray to ensure nothing stuck, but still no dice. Any ideas?
  • Scott Hopgood Apr 18, 2007
    Tried the above, but still getting same error code :(
  • Richard Marshall Oct 26, 2008
    i had the same problem but i took my aggressions out on the drive and forced it open,breaking something inside in the process,now looking for a replacement of same specs(size and features)as i have removed the drive from the tower.Any sugestions?E mail at richbonnie220@yahoo.com
    President:
  • 2,961 Answers
Try, go to my computer>properties>hardware tab>device manager and go down the list to cd/dvd drives, click on the '+' and right click on your listed drive and select uninstall. restart the notebook and then the drive will be re installed with drivers automatically. it may be a firmware or driver error.
Posted on Apr 18, 2007
  • andrew pester
    andrew pester Apr 18, 2007
    If it still won't eject the drive is definately faulty as the same thing happens when a cd or dvd is in the drive but cannot be read and the laser is still trying to read the disc and not allowing you to eject other than manually.
Bmw 325 on a y reg will turn over but will not fire fault code pointing immobilizer fault anti tamper fault any ideas easy cheap fix thanks
Hi Mark you could try to see if re-programming the key might do it, you could also disconnect the battery for 10 minutes and see if it resets that way...to re-program the key this is what you do, please follow by the book or it wont work, this however is just a trial to see if it will do the job, if reprogramming the key does not do it, then disconnect the battery for ten minutes and then try re-programming of the key...
1, unlock the car with the key ( not fob) get in and shut the door 2, switch ignition on and then off ( do not try to run it just on then off) 3, remove ignition key 4, press and hold unlock button 5, press lock button 3 times quickly all within ten seconds keeping the unlock button pressed 6, release unlock button 7 ( if you have this type of key fob) the led will flash slowly for 10 seconds 8,( if you have this type of key fob) the central locking system will lock and unlock rapidly to indicate correct programming 9 ( if you have this type of key fob) repeat procedure if the led flashes constantly, or the locking system does not unlock and lock rapidly please follow as directed..if you have any problems understanding what to do, please contact me on email address s.e.morris@live.co.uk hope this helps
Jan 13, 2011 | 2001 BMW 325
I have a quantum model 3212 serial #3000...fcc id #kj8intrmt...ok im trying to program my garage door to my truck..help please
1. In the vehicle press and hold the two outside buttons until the indicator light begins to flash (after 20 seconds). Release both buttons. Note: Some vehicles may require the ignition switch to be turned to the second (or "accessory") position during the programming process.
2. Hold the end of your handheld transmitter between 1 and 3 inches away from the Homelink surface (located on your visor or overhead console) keeping the indicator light in view.
3. Using both hands, simultaneously push the handheld transmitter button and the desired HomeLink button. DO NOT release the buttons until step 4 has been completed.
4. Hold down both buttons until the indicator light on the HomeLink Wireless Control System flashes, first slowly then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapidly flashing light indicates successful programming of the new frequency signal.)
To train your garage door opener.
1. Locate the smart/learn button on the garage door opener motor head unit.
2. Press and immediately release the smart/learn button.
Firmly press and release the programmed HomeLink button. Press and release the HomeLink button a second time to complete the training process. (Some garage door openers may require you to do this procedure a third time to complete the training.)
Feb 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
2005 honda odyssey homelink programming
If you just received your vehicle and have not trained any of the buttons in HomeLink before, you should erase any previously learned codes before training the first button. To do this, press and hold the two
outside buttons on the HomeLink Transceiver for about 20 seconds, or
until the red indicator flashes.
Release the buttons, then go to step 1.
If you are training the second or third buttons, go directly to step 1.
1. Unplug the garage door opener motor from the electrical outlet.
2. Hold the end of the garage door opener remote 2 to 5 inches from HomeLink. Make sure you are not blocking your view of the red indicator in HomeLink.
3. Press and hold the remote transmitter button and one of the HomeLink buttons at the same time.
If the red indicator in HomeLink begins to flash slowly at first, then rapidly, release both buttons, and go to step 5. If the red indictor in HomeLink continues to flash slowly (does not flash rapidly), your remote transmitter may stop transmitting after a short time. Go to step 4.
4. Press and hold the remote transmitter button and one of the HomeLink buttons at the same
time. While continuing to hold the HomeLink button, press and release the remote transmitter button every 2 seconds. If the red indicator in HomeLink begins to flash slowly at first, then rapidly, release both buttons, and go to step 5. If the red indicator in HomeLink continues to flash slowly (does not begin to flash rapidly), repeat steps 2 thru 4.
5. Plug in the garage door opener motor, then test the HomeLink button by pushing it for about 1
second. If the button works, programming is complete. If the button does not work go to step 6.
6. Push and hold the HomeLink button for a few seconds, then watch the red indicator on HomeLink.
If the indicator stays on or flashes slowly, repeat steps 2 thru 5. If the indicator flashes rapidly
for 2 seconds then stays on, you have a rolling code transmitter. Go “Training with a Rolling Code System”
7. two HomeLink buttons to operate any other compatible remotely controlled devices around your
home (lighting, automatic gate, security system, etc.).
Repeat these steps to train the other
Jan 05, 2010 | 2006 Honda Odyssey
2005 hyundai accent 1.6L. car won't start
Hyundai TSB 08-BE-012
PROCEDURE:
1. For first time training, press and hold the two outer HomeLink buttons, releasing
only when the HomeLink indicator light begins to flash after 20 seconds.
NOTE: Do not perform this step when training the additional HomeLink buttons.
2. Position the hand-held transmitter 1-3 inches away from the HomeLink mirror,
keeping the HomeLink indicator light in view.
3. Using both hands, simultaneously press and hold both the desired HomeLink button
and the hand held transmitter button.
DO NOT release until the HomeLink indicator light flashes slowly and then rapidly.
When the indicator light flashes rapidly, both buttons may be released. The rapid
flashing indicates successful training and the procedure is complete. This also
indicates that the garage door opener does not use rolling code technology.
Note: The garage door may open or close during this step.
Steps 4 through 7 are only necessary if the HomeLink button appears to be
transmitting after step 3, but the garage door does not operate.
4. Press and hold the trained HomeLink button and observe the indicator light.
If the indicator light is solid/continuous, training is complete and your device should
activate when the HomeLink button is pressed and released.
If the indicator light blinks rapidly for 2 seconds and then turns a solid/continuous light,
proceed with the following training instructions for a rolling code device. A second
person may make the following steps quicker and easier. It is recommended that a
ladder or similar device be used to obtain access to the motor housing. Do not stand
on the vehicle to perform the next steps.
5. At the garage door opener receiver (motor housing) in the garage, locate the “learn”
or “smart” button (usually near the hanging antenna wire attached to the unit). If
there is difficulty locating the training button, refer to the garage door opener’s
manual.
6. Press and release the “learn” or “smart” button (the name and color of the button
may vary by manufacturer).
NOTE: Once the button is pressed, there are 30 seconds in which to initiate the
next step.
7. Return to the vehicle and firmly press and hold the trained HomeLink button for two
seconds and release. Repeat the “press/hold/release” sequence up to 3 times to
complete the training process. If successful, your garage door should open or close
during this step.
If the vehicle owner continues to have difficulty programming their HomeLink mirror,
please have them contact HomeLink customer service directly at 1-800-355-3515 or
www.homelink.com for further assistance.
PROCEDURE COMPLETE
Dec 06, 2009 | 2005 Hyundai Accent
How do I setup the homelink feature in my 2000 chevy impala with my garage opener?
First clear it pushing the 2 outer buttons for about 20 seconds till the lite blinks.
Then here is the weird part take the old remote that you use for your garage door opener and hold it next to the home link in the car.
Push the button on your old remote then the button on the home link. the home link will flash slow then quickly (about 10 sec).
Now go push the learn button on the main door unit then back to the car and push the home link again for 2 seconds.
Oct 22, 2009 | Chevrolet Impala Cars & Trucks
Cd rom drive won't open
i had the same problem i solved mine by using a knife and using the tip of the blade to push up and pull out on the drive while it tries to open and drive opened with out a hitch.. it turned out to be a gear problem with the drive.
Jan 07, 2009 | E-Machines emachines (emachinees) CD-ROM...
I need to know the process on how to program the cars built in gurage door opener on a 2001 chrysler town & country
Hi my name is Allen!
Program a previously trained homelink button as follows... 1. Press and hold the desired pre-programmed HomeLink button for at least 20 seconds (but no longer than 30 seconds) until the indicator light begins to flash. Without releasing the HomeLink button, position the hand-held transmitter 1-3 inches away from the homeLink surface keeping the HomeLink indicator light in view. 2. Using both hands, simultaneously press and hold both the desired HomeLink button and hand held transmitter button (or press and "cycle" - as described in "Gate and Canadian programming"). DO NOT release until the HomeLink indicator light flashes slowly and then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapid flashing indicates successful programming) The previous device has now been erased and the new device can be activated by pushing the HomeLink button that has just been programmed. however, it may be necessary to follow steps 5-7 of the "programming" section to complete the rolling code training. This procedure will not affect any other programmed HomeLink buttons.
Dec 20, 2008 | 2001 Chrysler Town & Country
REMOTE CONTROLS WILL NOT WORK-WALL BUTTON FLASHING RAPIDLY
Does your wall switch have a lock feature? By pressing the lock button, the remote control is disabled. A flashing light indicates this feature has been activated.
To deactivate, press and hold the lock button for 2 seconds. The flashing should stop and your remote should work again.
Dec 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Program garage door opener
You must first erase what's in the memory.
1.) Simultaneously press both buttons 1 and 3 on the Audi's built-in remote. Hold them until the indicator light flashes (20 seconds or longer).
2.) Now hold your garage door remote close to the Audi remote.
3.) Simultaneously press and hold both your garage door remote button and the button you would like programmed. The indicator light will first flash slowly then rapidly.
4.) You may release both buttons once the light flashes rapidly.
Jul 01, 2008 | 2000 Audi A6
Jag xj6 1996 97 programming the garage door openers
1. For first time training, press and hold the two outer HomeLink buttons, releasing only when the HomeLink indicator light begins to flash after 20 seconds. (Do not perform this step when training the additional HomeLink buttons.) 2. Position the hand-held transmitter 1-3 inches away from the HomeLink surface (located on your visor), keeping the HomeLink indicator light in view.
3. Using both hands, simultaneously press and hold both the desired HomeLink button and hand held transmitter button. DO NOT release until the HomeLink indicator light flashes slowly and then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapid flashing indicates successful training.)
property_damage_symbol_sm.gif Note: Some garage door openers may require you to replace step 3 with the “cycling” procedure noted in the “View Canadian Instructions” section.
  • If the indicator light is solid/continuous, training is complete and your device should activate when the HomeLink button is pressed and released.
  • If the indicator light blinks rapidly for 2 seconds and then turns a solid/continuous light, proceed with the following training instructions for a rolling code device. A second person may make the following steps quicker and easier. Please use a ladder or other device. Do not stand on your vehicle to perform the next steps.
5. At the garage door opener receiver (motorhead unit) in the garage, locate the “learn” or “smart” button (usually near where the hanging antenna wire is attached to the unit). If there is difficulty locating the training button, reference the garage door opener’s manual or contact us. 6. Press and release the “learn” or “smart” button (the name and color of the button may vary by manufacturer). NOTE: Once the button is pressed, there are 30 seconds in which to initiate the next step. 7. Return to the vehicle and firmly press and hold the trained HomeLink button for two seconds and release. Repeat the “press/hold/release” sequence up to 3 times to complete the training process.
Jun 13, 2008 | 1997 Jaguar XJ6
LG GSA 4163B DVD±RW Dual Layer Burner Logo
431 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
