Question about Toshiba Satellite A100-S8111TD Notebook
When typing on toshiba the curser skip and actually moves
To another spot...cannot find where to adjust this?
  • econklin Jan 05, 2009
    I have the same problem and cannot figure out how to address it.
  • 3 Answers
It might be that your palm is brushing across the intel touch pad (mouse pad) as you're typing?.. try holding down the function key (Fn) (on the lower left corner of the keyboard) while pressing F9 (this activates the "Toshiba Flash Cards Menu" and is a keyboard shortcut to toggle off/on the touch/mouse pad. You can turn it back on this way too. I almost always use a conventional USB mouse with my laptop for this reason and because it's faster than fiddling around with the pad, IMHO).
Posted on Jan 06, 2009
How to use a spotting scope for shooting?
A Spotting Scope is an essential element for hunters and shooters. This small device is technically a special type of telescope used for hunting, magnifying and watching an image or object more clearly. The methods use a shooting spotting scope does not involve much difficulty.
Here is the method:
Comfortable position
For a perfect shooting experience, you need a comfortable position. If your comfortable position is unable to help you fix the targeted area, you are likely to miss the hit or glance.
Attachment of the spotting scope with the tripod
Having an accurate view of the targeted area is important. Due to this reason, shooters need to position the spotting scope with a tripod so that they can see the targeted area very clearly and accurately.
Adjustment of the magnification level
The lens and magnification level should be adjusted so that you can get the appropriate view of the targeted area.
View of the targeted area
After fixing the targeted area, you have to adjust the magnification level with the lens to view the targeted area. At the time of using scopes, you will find some problems that magnification will present. If you fix the magnification and focus firstly, you may not find the target. You have to first view the target, and you have to adjust magnification level as required. Here, you should bear in mind you will have to go with the slow magnification process because the fast magnification process cannot give the accurate target.
Adjustment of the focus
You have to know how to reset the focus because you will need to do it again and again. It may sometimes harm your eyes with the magnification level being set to high.
Focusing on target is important for shooting and the spotting scope is also important for this purpose. For acquiring a specific target, it is important to use magnification level with the spotting scope.
You should follow all the methods of using explained above. There is no alternative way to learning how to use a spotting scope for shooting except these methods.
Apr 05, 2018 | Optics
Tip
How To Use A Spotting Scope For Shooting
If you practice hunting and shooting, a spotting scope is one of the best instruments that you need to have to provide you with a clear view when you are aiming at your target. Before we get started on how to use a spotting scope for shooting, it is great if you know what exactly a spotting scope is.
Precisely, a spotting scope is a small device that is used for many outdoor activities to magnify and help you watch images and objects closely. Before purchasing the best spotting scope for shooting, you need to know a few things that will help you use it well in your shooting career. Here are some things that you need to know when using a spotting scope for shooting.
Comfortable Position Is Key
If you want to get the best performance from your spotting scope, ensure that you position yourself in a comfortable place. You know when you are using a spotting scope you will be holding it for long so it is very crucial to find a comfortable place that you can sit or lay down depending on what you find best. Make sure you find a comfortable place and learn more about the specifications of the area which should be the point of targeted area.
Attach Your Scope To A Tripod
Sometimes holding your scope with your hands can compromise the quality of images that you get because of shaking and fatigue. If you want to achieve a clear and accurate view, get a tripod and attach to your scope. This means that your scope will be very stable because there are minimal movements so you end up getting very accurate results. When you are using a tripod, the chances of missing your target are very minimal.
Adjusting The Magnification
You should also adjust the magnification of your spotting scope to a level that you like. Spotting scopes are designed differently so you need to know how to adjust magnification and the lens layout of your scope. For the most accurate results, it is great if you read the instruction given about the magnification levels and how to adjust.
In some spotting scopes, you need to use the lens knob so that you can zoom in and out of the magnification. In other scopes, you need to use the small zoom in and zoom round trigger on the point of the eyepiece.
View Target Area And Adjust Magnification
When you are using spotting scopes, it is not advisable to go with the magnification first because you might not get the right results. The best thing that you can do is to view the target area first and then adjust the magnification effectively.
Reset Focus In A New Area Always
This is very important because a sudden highly magnified glass can cause problems to your eyes. This means you can feel uneasy when you are watching your target longer. This results because of watching at a very high magnification glass for a prolonged period. You can overcome the problem by reducing the effect of the magnify glass on your eyes.
Beating The Sun
If you want to become a spotting scope pro, you must learn how to beat the sun. You need to know how to deal with the frustrating heat waves because they quickly distort your view and it becomes difficult to grass. The best way in which you can beat the sun is to zoom out. Zoom out to a lower power setting and you will enjoy heat-wave glassing hours. You should wait for passing cloud because they reduce the heat wave and give you the chance to zoom back in your target.
Final Words
Buying the best spotting scope for shooting is not enough. You also need to learn how to use it so that you can get clear and bright images all the time. This will help you gain accuracy when you are shooting so no more missed shots. If you learn these tips, you will not experience any problem when you are hunting or shooting. Knowing how to use your scope is the only way in which you will get most out of it when shooting. Best Spotting Scope to buy in 2017 Buying Guide Reviews
on Jul 19, 2017 | Miscellaneous
Rock-ola 448 jukebox skipping how to repair
The stylus might be worn or of the wrong type. A simple tone arm needs a round stylus and if an elliptical type (intended for a long S-shaped tone arm) has been fitted by mistake it could skip.
If nothing is wrong there, the remaining conclusion is either the mechanism is maladjusted or the tonearm bearing has a tight spot. In that case the tone arm should be removed and the shaft examined under strong magnification and any irregularities carefully removed, eased, blended in using a very fine abrasive (12,000 - 20,000 grit) and then ensuring the shaft and bearing is thoroughly clean apply a little very light machine oil and reassemble and readjust the playing weight...
Apr 07, 2017 | The Audio Players & Recorders
How do you adjust the Throttle Position sensor on a 2004 GS500 F Suzuki MC
Its not adjustable- if theres a flat spot it needs a very good cleaning or replacement. Likley a replacement as they are a potentiometer and sometimes do wear at often used spots
Sep 10, 2014 | 2004 Suzuki GS 500 F
My curser moves from right to left without my knowlege
Check the language set up. Also check that the keyboard type is properly set.
Over the years I have seen a defective keyboard do some erratic behavior.
Jerry G.
Jun 17, 2012 | Acer NSK8458AN Keyboard
How to adjust auxiliary lights on 2010 HD heritage softail. Cannot find any way to make adjustments.
If you're talking about the "spot lights", there is a special tool you need to adjust them. You loosen the turn signal light below the "spot", adjust the spot light, then hold it with the special tool while you tighten the turn signal. You can purchase the tool from a Harley dealer or some of the aftermarket parts dealers like V-Twin or Custom Chrome, Jireh.
Good Luck
Steve
Oct 14, 2010 | 2000 Harley Davidson FLSTC Heritage...
When typing, the curser skips.
Even though you may not even be touching the touchpad, touchpads and the tiny ribbon cables that connect them to the motherboard (directly under the keyboard) can be so sensitive that they activate the cursor just from typing alone.
Here's a great little app you can download that disables the touchpad ONLY while keystrokes are being made. It's saved a ton of my clients (and myself) alot of grief. If it doesn't solve your problem, then you can repost and move ahead with further help in tracking down the problem.
http://code.google.com/p/touchfreeze/
Best Wishes!
Jul 14, 2010 | Dell Inspiron 1525 Laptop
I cannot adjust the fan speed. There is 1 spot on
If there is only one spot on the fan control dial that turns on the fan, it seems that the fan control pot has failed and needs to be replaced. You can call the company and order one and it should fix your problem 800 989 2299.
Jan 03, 2010 | Alpine Air XL-15 Air Purifier
My rifle hits the same spot no matter how i adjust it
there should be two adjustment dials on the scope one on top and one on the side might be covered with a plastic plate, depending on the scope the top dial does elevation, and the side dial does left and right adjustments
Dec 30, 2009 | Beeman Optics
Toshiba Satellite A100-S8111TD Notebook Logo
109 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
