Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
NO SPINNING NOR DRAINING LG TROMM SER.WD-12210DB 10kg
WHEN DET ON SPIN AND/OR DRAIN, MACHINE GICES 3 X CLICKS BUT DOES NOT OPERATE.(EITHER WITH OR WITHOUT FLASHING BARS) PLSE ADVISE. TkS JEAN W. SLEEMAN jsca@absamail.co.za
  • 179 Answers
Check your pump to make sure that it is clean there is a door on the bottom of the machine open it use the little hose to drain the washer in a bucket then twist the big cap and pull it out clean that trap
Posted on Dec 26, 2008
UE error on LG Tromm it drains but won't spin. I checked the filter and the filter is not blocked
UE= uneven ?
Remove any every heavy items such as floor towels or rugs. Is the machine draining completely or leaving lots of water behind? If not draining check the drain divirertor valve.
Nov 24, 2013 | LG WM-2277HW Front Load Washer
Lg tromm wd 85485 error code cl mean ?
Possible that the drain valve is clogged if the inlet line is working and so you need to remove the drain and back flush.Also check after the power plug is removed for few hours and see if the fault resets to start the machine only to show the error a few minutes later. if so clean the drain lines, check the inlet flow and the door switch.
Dec 15, 2011 | LG Washing Machines
Have an LG Tromm WM2277HS washing machine the water will not drain and of course will not spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Washing Machines
THE WASHER DOES NOT DRAIN
heatman101
May 23, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water drain open even washing mode and during spin water not drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Aug 29, 2010 | LG Washing Machines
Washer will not drain or spin
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 07, 2010 | LG WM-2277HW Front Load Washer
Machine gives an LE code and will not operate
I follow the following process:
1. drain water
2. unplug for 20 minutes
3. spin the drum manually 3 rotations
4. back in business.
This is usually caused bu a faulty hall effect sensor.
Feb 21, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Trap clear on lg tromm. still no spinning and/or draining; pse ad
OE code should appear. I've been able to re-start after unplugging the machine for ten minutes and then re-plug and it did clear the code and spin out but I'm back to the same problem and unplugging isn't working anymore. I'm wondering now if the issue maybe the machine isn't level. Well, something I'm now going to check. Good luck.
Dec 27, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Loud bang during spin
Unplug it and plug it back in after a min. Try to put it threw a rinse spin cycle. Delicate option has a shorter rinse spin time.
See if it suds up, when you hear it trying to drain lift up the drain hose to the wall. It is the gray tube that has the elbow bend, might (should) be hooked to wall. If it isn't moving a good amount of water the machine isn't draining.
Aug 04, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
149 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
