Question about Nokia E61 Smartphone
Past few days I am getting a message when i press Option in Calender : Unable to execute file for securit reasons
  • Anonymous May 23, 2009
    I got the same problem, started after upgrading to latest nokia email software, remove the nokia email software and all ok.
    The nokia email software is really good but I cannot use it as it stops the calendar and to do notes working correctly
    Scholar:
  • 61 Answers
First, try a battery pull. For about 30-40 seconds. Re-boot the phone. Try to get back into the calender. Try a soft reset code:
Soft Reset: *#7780#, 12345 and then Yes If the error message continues, do a master reset. This will bring the phone back to it's original status from when you got it out the box. (ex. wall paper, ringtones, themes, etc...). Full Reset: (clears everything off the phone memory!! Be sure to back up your contacts!!): *#7370#, 12345 and then Yes!
The screen may go out, and come back to it's orig. screen. Then, re-try the calender. Youl'll be golden!
Posted on Feb 03, 2009
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured
Clean 50 is either Dirty Encoder Stripe or broken Maintenance Unit. In first case clean thoroughly the vertical Encoder Stripe and it should work. In case 2 better exchange the machine
Nov 23, 2015 | Brother Office Equipment & Supplies
Tip
How can I run two Skype accounts on the same computer?
To use more than one Skype account on the same computer at the same time you need to start a new instance of Skype.
1.
From the Windows taskbar, click Start > Run (or press the Windows and R keys on your keyboard at the same time)
2.
In the Run window, enter the following command (include the quotes) and press OK:
"C:\Program Files\Skype\Phone\Skype.exe" /secondary
If you get an error message, copy and paste the exact command from this page and try again.
Be aware that if you have changed the installation path for Skype then you will need to enter the correct path for the Skype.exe file.
If this solution fails, you can try another option:
1.Find the Skype executable file (Skype.exe) in: C:\Program Files\Skype\Phone\
2.Right click on it and select Send to > Desktop (create shortcut)
3.Locate the shortcut on the desktop, then right-click on it and select Properties
4.In the Target field, add: /secondary. The Target field should now be "C:\Program Files\Skype\Phone\Skype.exe" /secondary
5.Click OK. You can now start a new instance of Skype every time you double-click the new shortcut.
on Nov 19, 2013 | SKYPE Computers & Internet
Message keeps popping up....
Frequently, this happens do to a problem with your contacts or calender. It's a problem with syncing those items with your Google account or PC. If the problem is with one of these, you should try to manually synch the calender and contacts. (Go to Settings > Accounts & Sync > (Go to Gmail account). You'll see the option to sync the Calender, Contacts and Gmail. Select each one to manually attempt to sync the files. Determine which item is providing the error; you will need to clear the data from the problem application. (Note: back up your contacts first. Use the People > Menu > Import/Export > Export to SD card option if you can.)
Next un-check the sync option for the problem app (calender or contacts) under the Google Account > Accounts. Then go to Settings > Apps > Manage Apps > All and clear the data and cache for the problem app. (The contacts may be under the Running list.) Then re-enable the sync feature. If the calender is causing the error, you may need to erase and re-create your recurring item.
For some scrolling down to the Google Frameworks service in the Manage App > Downloads (or Running) menu then clearing that data. Then chose the "force stop" works to fix the problem. (However, this can put your cell phone into a factory reset state and may cause other problems.)
You will need to turn the cell phone off and back on before re-enabling the sync.
I hope this helps.
Jan 09, 2014 | Samsung Galaxy GT-S5570
I'm unable to rename any file in win XP,a message appears displaying "If you change a file name extension,the file may become unusable" Plz help to fix this
Go to control panel then go to folder option then click on view tab. On the list you'll find a option named "Hide extensions for known file type". Enable this option and click OK. Now you can rename your files easily.
Mar 13, 2011 | Computers & Internet
When I try to graph, I get ERR:INVALID DIM I tried going to PlotsOff and I still can not graph
What happened when you tried going to PlotsOff. Did you actually execute the command?
If you executed that command and cannot graph then for some reason you are feeding lists or matrices as arguments to the functions you want to draw.
By the way are you drawing STATISTICAL GRAPHS or FUNCTION GRAPHS?
If you are drawing statistical graphs and you executed the PlotsOff command, it is normal you will not be able to graph because PlotsOff turns OFF the statistical graphs.
Here are a few things you can do:
If you got the message while trying to draw a graph
  1. Press [2nd][Y=] (STAT PLOT)
  2. Choose option [4:PlotsOff][ENTER]. Screen displays Done
If message popped up while doing something else that involves lists or matrices, the length of lists may be different, or the dimensions of matrices may not be compatible.
To Clear the lists:
  1. Press [2nd][0] (CATALOG)
  2. Press [PGRM] (C) to jump to first command that starts with c.
  3. Use arrow to scroll down to ClrAllLists, select it [ENTER]
  4. Calculator displays Done
  5. Start the new problem.
To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
Aug 17, 2010 | Texas Instruments TI-84 Plus Silver...
HOW TO INSTALL APPLIATION IN SAMSUNG S3310 METRO
In Samsung s3310 mobile,installing games is itself a big task and you did that.
The reason is only games folder can run Java executable files(.jar) files.When we move Java executable files(.jar) to application folder,it cannot execute the .jar file.Therefore the applications like call tracer which runs in background mode could be installed but cannot run in s3310.
only games and applications like dictionary(which does not need background running mode) can run in Samsung s3310 in games folder.
May 12, 2010 | Samsung SGH-L700 Cell Phone
I bought used touch diamond recently. But, the phone unable to to turn on Wi Fi after a few days even I tried to turn on through "Comm Manger" -> "Wi-Fi". Is the Wi-Fi device issue?
Try resetting your device to factory settings, but before doing so, please take a backup of everything (contacts, messages, calender etc.)To reset the device:
1. Turn off the phone and pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
"This operation will delete all your personal data, and reset all your settings...."
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
It might take a while to start the phone and check the WiFi after the phone has restarted. In case it still has the same issue, then it might be a hardware fault.
May 09, 2010 | HTC Touch Diamond Smartphone
I am unable to follow links to yahoo profiles on yahoo messenger.
Good day.Your problem is that you have downloaded the yahoo installer and your computer doesnt know which installer to choose for your package.Go to the folder options and bind the .exe applications with the istaller icon or executable files.
Jun 22, 2009 | Yahoo Messenger
Base settings 'not available'
Press Play. Keep pressed and switch off at mains. Wait a few seconds. Keep Play pressed and switch on at mains, keeping Play pressed for a few more seconds. Then, register handset with base.
Jun 29, 2008 | British Telecom BT On-Air 1300 Executive...
Error Message ('replace belt CG')
To reset page counter after replacing the OPC belt or FC Roller please follow the steps below:
  1. Power the printer on while holding down MENU/ENTER key
  2. Release the key when the display shows "Utility Menu Clear FC Roll"
  3. If you have replaced the FC Roller then select this option by pressing MENU/ENTER key. If you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
  4. When one of these options is selected Press the MENU/ENTER key and the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute". Press the MEDIA key and the display will change to "Execute"
  5. Press the MENU/ENTER key and after about 10 seconds the display will change to "Completed Clear FC. Roll / Belt CG"
  6. Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
Jul 12, 2007 | Tally T8006 Laser Printer
Nokia E61 Smartphone Logo
63 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
