Question about Braun 360° Complete 8985 Electric Shaver
Shaved hairs fall out of shaver head
I have a braun 8000 series shaver (8995) and as I am shaving, the shaved hairs inside the head come out, especially when the head is turned sideways or down- its gets all over my shirt and the sink, what a mess! I therefore have to shave with a garbage can under my chin. Can anyone help with this?
    Novelist:
  • 124 Answers
This shaver wasn't designed very well for keeping the whisker debris from falling out. I recommend that you shave before you put your shirt on. Otherwise, just try to keep the shaving head tilted upwards. If you've got a heavy beard, dump the whiskers halfway through the shave--that will help minimize the mess. Good luck.
Posted on Oct 22, 2009
    Problem Solver:
  • 9 Answers
IT'S A GOOD THING THAT THE HAIR COMES OUT ITS STOPS THE CLIPPERS FROM JAMING. USE A GARBAGE BAG AND POKE A HOLE BIG ENOUGH FOR YOUR HEAD. PUT THE GARBAGE BAG OVER YOUR SHOULDERS AND TRIM AWAY. THAT WILL HELP IT FROM GETTING OVER YOUR CLOTHES. IF YOU HAVE A GARAGE PUT A MIRROR IN THERE AND YOU CAN SWEEP UP THE HAIR OFF THE FLOOR EASIER THAN IN THE HOUSE.
Posted on Jun 06, 2009
  • 153 Answers
U have to less off the speed of ur shaver
Posted on Jul 21, 2009
Braun pulsonic 70s strange cutting head vibration
The problem sounds like the drive unit is broken inside. The oscillator can break over time. This part can be found at shaveroutlet.com
Braun Pulsonic and Series 7 Motor Drive Unit
Feb 07, 2018 | Braun Health & Beauty
What is an electric shaver?
Not like shaving razors, electric shavers work by shearing the whiskers, the hair enters the perforated metal heads of the shaver and is cut by the moving blade inside.
Feb 06, 2013 | Health & Beauty
The screen on my braun shaver has holes and needs replacement can i get new ones for it? its the one that says caution for use only with braun series 549 class 2 power unit www.braun.com it has a trimmer...
Braun 8985 replacement foil and blades is braun series 5 combi 51S foil and cutter replacement pack.
But costomer reviews in amazon.com who take braun series 3 combi 30B foil and cutter replacement pack is fits to Braun 8985 perfectly, very smooth and close shave. Shaves much better than the Braun 51S screens foil.
You consideration
http://www.amazon.com/gp/community-content-search/results/?ie=UTF8&search-alias=community-reviews&tag=best-electric-razors-20&Go.x=0&linkCode=ur2&query=braun%208985&camp=1789&Go.y=0&creative=9325&idx.asin=B001VH6F9G
Sep 16, 2011 | Braun 360° Complete 8985 Electric Shaver
How can I clean my braun washable series 3 (330) shaver. better. I can take it apart so far but just cant get under the blades
This model uses a 'shaving cassette'. The blades can not be removed from the foil assembly. Braun's instruction is to simply rense the shaving head under hot running tap water. Unfortunately, this does not work very well over time due to the poor design of these parts. Once they become clogged up it is usually necessary to replace the cartridge.
If replacement is needed you will find one at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-series-3-shaver-foil-and-cutter-head-cassette-32s32b-p-835.html
Jul 27, 2011 | Health & Beauty
Bought a Braun series 3 razor (#340 wet and dry). It hardly shaves the whiskers but it really messes my skin up. ( I was using a Norelco which did a pretty good job) I think there is something wrong...
You should be able to run your finger over the foil mesh on the Braun shaver to feel if there are any rough spots causing the problem you describe. If there is damage you may also be able to see it.
It could also be that the Braun shaver simply does not agree with your skin type. There are many people who are sensitive to different kinds of shaving methods. Foil shavers like Braun may not be the type of shaver for you
Apr 04, 2017 | Braun Syncro 7680 Electric Shaver
Not shaving close enough.
This problem is usually cause by a worn out shaving head (foil and cutters). Braun suggests that you change these every 12-18 months for best performance. You will find replacements at shaveroutlet.com for your model 4501 Braun shaver. See link below.
http://shaveroutlet.com/foil-cutter-fit-braun-4000-series-flex-control-twin-control-p-146.html
It is also possible that your shaver is running too slowly due to an old battery if you've never replaced it. If you require a new battery, it can also be ordered from shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To change the battery you will need to be able to do a little soldering. Open the shaver by removing the two round screw covers on the bottom of the shaver and then the screws underneath. You will also need to remove the foil and cutters and then the swivel frame which is attached by two tiny screws. Once removed, you will be able to open the shaver from the bottom and seperate the front and back. Remove the circuit board to easily get to the battery.
Note: The tabs on this type battery will work for most applications however they may be slightly different than some original equipment. For these instances, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can them solder the tabs from the new batteries to the old existing tabs
Feb 19, 2010 | Braun 4501 Electric Shaver
New head
Hello Brian, You can give the folks at www.electricshaver.com a try. They typically stock all the replacement and repair parts for most brands of electric shavers.
Here's a link to their site where you'll find part #5646768 for about $38 for a new set of the cutter head and foil (screen). It's always best to replace BOTH the foil and cutter block (head) at the same time, as any mircro burrs or nicks in the cutter blades will quickly ruin any new foil screen.
http://www.electricshaverstore.com/get_item_5646768_braun-foil-cutter-kit-360-complete-8000-series.htm
As you know, this is the simplest and easiest way to get an electric shaver back to a "like-new" shaving experience.
I hope you find this Very Helpful and best regards!
Nov 11, 2009 | Health & Beauty
Head (foil and blades) used to last 10-12 months. Now they last about six weeks. I don't hink I have done anything different when shaving. Braun Syncro is abotu four years old.
Six weeks? That's very peculiar. Are you certain that they are seated properly on the shaver? If there's a problem with the head and they're not fitting into place slightly off, they can end up wearing out faster.
If you've used your shaver for a number of years, your best bet is to probably step up to a newer model Braun shaver. The 7000 series was OK, but the 8000 series is much better. You can still pick up new old stock ones off "that auction site". They shave not much differently from the new 9000 series (Pulsonic). Good luck!
Sep 16, 2009 | Braun Syncro 7526 Electric Shaver
Where can i get a cleaning stand for the braun 8985
http://cgi.ebay.com/Braun-8985-Electric-Razor-Comes-with-everything_W0QQitemZ270329232498QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item270329232498&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50
Jan 16, 2009 | Braun Syncro 7526 Electric Shaver
Resetting the how many shaves counter
Hi,unfortunately there is no way to reset this counter,even after replacing battery it still stands there.Braun somehow prohibits user and/or unauthorized repair men to do such action.If you visit the following link there is a official statement by Braun states that" total number of shaves (cannot be reset)."
I am sorry,this is the fact.
Regards
www.service.braun.com/line/SH/S5646/S5646_3_CHIN_KOR.pdf
Aug 20, 2007 | Braun 360° Complete 8985 Electric Shaver
Braun 360° Complete 8985 Electric Shaver Logo
200 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
