Question about DeLonghi Caffe Nabucco BCO70 Espresso/Coffee Maker
Coffee maker leaking from bottom
Why does coffee maker leak from bottom
    Problem Solver:
  • 8 Answers
I have had a few of these machines leak.
I pulled off the bottom and found Mr Coffee is using low quality tubing that melts or leaks where it attaches to the heater element that boils the water. I replaced the tubes with higher quality silicone tubing that I bought directly out of China on Ebay and the problem was solved.
Posted on Mar 03, 2013
  • DeLonghi Master
  • 19,396 Answers
Check the water tray first, it is more likely a leak from one of the internal hoses, the machine must be probably taken apart and inspected to fix this.
Posted on Dec 26, 2008
There is a hole that goes though the bottom of the water chamber side.
The unit will not leak when there is water in the water chamber. The only reason for water to come out the hole is condensation from making the water. There are no hoses in the water chamber area.
Posted on Jan 01, 2009
  • 4 Answers
SOURCE: Unit leaks out of the bottom
Mine just developed the same problem. Me being an engineer, I decided to take it apart and found the problem. There is an aluminum tube shaped like a "C" with a heating element inside of it. Water flows through this metal tube, is heated, and then pushed via steam pressure. There is a metal brace that holds this "C" piece securely to the bottom of the machine. This brace is sharp and overtightened, which caused a small hole to form in the metal, causing the leak (in my machine of course). I am currently researching how to patch aluminum so I can hopefully fix it.
Posted on Jan 06, 2008
Cuisinexpert
  • 61 Answers
SOURCE: water leaking out the bottom of the coffee maker
If it leaks DURING brewing, you may have to decalcify it (aka, run through a cycle of 4 cups vinegar, fill to the top with water, 2-3 times and see if it helps).
If it leaks before you even start brewing a pot of coffee, something is broken on the inside of the coffee maker, and I would recommend contacting Waring--they may be able to get you a replacement coffee maker (and if you're under warranty, usually a replacement would be free!).
Their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Posted on Aug 27, 2009
SOURCE: water leaking from bottom of coffee maker
The tool is a special tool that is either meant to be vandal or idiot proof. Being one of the aforementioned I bought a set of these special tools at Sears. The first problem is Cuisinart recesses the hole so much that my tool can not remove the screw. I tried widening the hole using a drill bit but it cracked and broke.
As for using a hose from a hardware store, I have been there and done that. The hose attatched to the warmer side melted and leaked everywhere.
Posted on May 14, 2008
SOURCE: Bunn Coffee Maker Leaks out the bottom
Contact Bunn and they will send you a free repair kit with good illustrated instructions.
Posted on Aug 17, 2008
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Posted on May 19, 2010
My coffee maker is leaking from the reserve. Is there a fix? I don't see a crack. It just started recently.
Reserves usually has a overflow hole on back . If not you might look for leaks around bottom were reserve meets up with coffee maker. Maybe leaking there.
Oct 29, 2015 | Cuisinart DCC Coffee Makers & Espresso...
Mr. Coffee CG13 12-cup coffee maker. Have used it
There is high temp tubing that may have come loose or become dammaged fromheat or the coil that heats the water may be leaking if you are using strong cleaning chemicals to remove scale from the unit. The bottom is held on with screws. Remove these and look to see what is the source of the leak.
Nov 21, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
Water leaking out the bottom of the coffee maker
Good luck! :)
Aug 27, 2009 | Waring Pro WC1000 Coffee Maker
Water leaks
unds like there is a leak in the tank. Take it back for a refund/exchange.
Jun 12, 2009 | Black & Decker TCM700 Coffee Maker
Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Jan 12, 2009 | Bunn VPR Coffee Maker
Water leak
just had the same problem the heater ring at the bottom has a whole in it or the hoses have got a crack in it. use a no 9 torx driver to take the bottom off. the check hold it up get water in it and look for the leak. the heat ring should have white corrosion on it, that should be were the leak is
Jun 24, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Leaks at bottom
look for leaks up at the top by the top hinge.
mine leaks there. apparently a gasket is missing or just not tight enough.
you should see bubbles come out and see water go into the filter cone but some of it leaks down the inside (near the pot inside) and out the bottom of the maker and appears to be leakng from the bottorm.
Mar 23, 2008 | Cuisinart DCC-1200 Coffee Maker
Steam leak in GB Mia Espresso Coffee maker
I had the same trouble before and probable causes were:
too much coffee powder in the funnel?
or
the coffee beans are ground
too much, makes the power clogging in the bottom of the steam tube?
Jan 02, 2008 | Guido Bergna Mia Coffee Maker
DeLonghi Caffe Nabucco BCO70 Espresso/Coffee Maker Logo
7,699 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
