Question about Whirlpool 24 in. ADP5962 Free-standing Dishwasher
Hi. whirlpool-dishwasher 4404/5. dot work. flashing light x 4 ???
Dishwasher ligh ON now flashing 4 times....hear motor sound but no action. please can you give any advise as to what it is wrong.
HAVE UNBLOCKED DRAIN AND SINK..???
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, this would require that the drain system be thoroughly cleaned including the filter, mesh filter, the sump (bowl), the black screen (grid). This of course needs to be done with the unit unplug. Thereafter, reset the machine by press and hold the START button until the indicator light flash out.
In some instances, it may be needed to force dry the drain/bottom area. A can of compressed air, compressor, vacuum/blower or hair dryer may do the trick.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 26, 2008
    President:
  • 2,110 Answers
Reset is by holding the start button until the light goes out.
Remove the filter and mesh filter, inside the bowl you'll see a black grid, very carefully clean this out (an old toothbrush and boiling water is good) and try the machine again.
    Genius:
  • 1,550 Answers
Check the float switch inside the tub, it should move freely up and down.
Check the harness to the motor
My dishwasher is just flashing F10 all the time
Codes are pretty generic between Hotpoint, Hoover and Whirlpool.
Heating element fault
Issue: The LED lights on your dishwasher are displaying in the following sequence (please see below these error codes for your LED reference
  • LED 1: OFF
  • LED 2: ON
  • LED 3: OFF
  • LED 4: ON
Action: We recommend you call our customer service centre to book an engineer.
Here is the Hoover site.
http://service.hoover.co.uk/advice-centre/dishwashers/
Error codes Hotpoint
Jun 19, 2016 | Hoover 24 in. HD97E Free-standing...
Whirlpool adp 4404/5. Green light flashes 7 times !! Any idea ?
F7 - Flow-meter failure
Symptom: water inlet valve (WV1) is switched on and the water indicator (WI) is on (level reached).
Could be:
1. Water tap closed during water inlet
2. Water inlet hose blocked
3. Water inlet valve (WV1) defective
4. Flow-meter (FM) sends too few / much pulses (less than 10 imp.in 10 sec.)
Flow-meter counts wrong (or the sump is full in less than 30 sec. Causation: Hose felt down and slipped the disc of the valve. The effect is a displacement of the valve tappet).
5. Aquastop defective
6. Flow-meter defective
Dado
Jul 26, 2015 | Whirlpool Dishwashers
Whirlpool DU930PWP02 Start Light Flashes 3 Times and does not run
Sounds like the anti flood alarm has activated - may be a small leak from the door or the sump into the base tray. You need to drain the tray, fix the leak and test. Try cleaning the door gasket and part of the door it seals against.
Feb 04, 2018 | Whirlpool Dishwashers
Whirlpool ADG7540 approx 4 years old (maybe a bit older) I have ran diagnositic check and the start light flashes 4 times stops briefly then flashes 4 times again over and over along with a continuous...
Yikes, we have just identified this exact same problem tonight. If you've had any success with fixing it, we would sure appreciate hearing how. Best of luck with your machine
Mar 03, 2011 | Whirlpool 24 in. ADG7540 Built-in...
Hello.have whirlpool dishwasher 4404/5. green light flashes x 4
sorry...
This is the WRONG PLACE for paid advise...
You need to contact the CLOWNS who charged you...!!
FIXYA is entirely FREE... (all volunteer)...
Not ever to be confused with money grubbers...!!
Good luck with your scammers.
Carnac the Magnificent
Dec 03, 2017 | Whirlpool 24 in. ADP5962 Free-standing...
WHIRLPOOL dishwasher 4404/5.
The water pressure is not upto the mark in your dishwasher , try switching it on when there is no other water being used.
Dec 26, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Changed Electronic control on Kenmore dishwaser
Sounds like wsh motor is not running. Test cycle by pushing in order: hi temp, air dry, hi-temp, air-dry. All lites come on and unit will run. Should hear motor running when 'washing' light is on. If not then motor is bad or something stuck in impeller area. Please leave feedback.
Nov 25, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Won't start, beeping sounds
sounds like the door switch might be an issue,, does teh tub light go on /off as you open the door??? if not try manually pushing the switch in a few times.
Oct 25, 2008 | Whirlpool GEW9250 Electric Dryer
Prima lpr 600 dishwahser
Control Lock means that the entire dishwasher is locked, for child safety purposes.  It's normally cleared by holding the "No Heat Dry" button in for 4 seconds or more.  It is locked again by the same procedure -- holding the "No Heat Dry" button for 4 seconds (or more.  I'd suggest trying this on yours...
Oct 14, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool 24 in. ADP5962 Free-standing Dishwasher Logo
119 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
