Question about Gaggia Baby Espresso Machine
No water getting through to the coffee holder
No water coming through to the coffee and excessive water coming through the froathing arm ?
  • Jam_1980 Dec 26, 2008
    I too am having the same trouble i have cleaned it and the water is just not coming some steam is?
    please can any one help
  • almcsingh Dec 28, 2008
    Similar poblem - Gaggia baby class. Water just pouring from AROUND not through the coffee holder. Mail order seller just says FORCE the machine to make hot water - not very helpful so far!
There is a valve inside the machine, under the water reservoir, that is broken. It's plastic and brakes easily when the hose attached to it is moved. This happened to my machine during shipment and I had to return it. Why can't they make these with brass?
Posted on Jun 18, 2010
If the machine is making very load noise while trying to make coffee ie. water to grinds or steamer this is more than likely a pump problem.
Posted on Jan 12, 2009
My Solis Master 5000 will not make a cup of coffee anymore. I already descaled, the water comes through the steam arm, but not through the coffee drip. How to fix?
If the problem is that water come from steam arm only,and if you try to make coffe is nothing happen- try to make several coffees with descaler liquid in the water tank.
Aug 31, 2017 | Solis Coffee Makers & Espresso Machines
Why does my Keurig smoke when brewing coffee, and the water doesn't go through until I take out the cup?
You probably have a clogged nozzle/needle. Take a straightened paperclip and run it thru the hollow needles that puncture the top and bottom of the k-cup. Make sure they are clear then try to brew a cup. Never reuse a k-cup. That's what usually clogs the needles.
Sep 19, 2014 | Keurig Coffee Makers & Espresso Machines
Blanco Blanco BCM6X Built-in Coffee Maker manualmanuals
My Blanco coffee machine (BCM 6 X) does not heat or froath milk
Jan 03, 2014 | Cooktops
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
coffee."
Apr 26, 2017 | Starbucks Saeco Italia Digital Barista...
I can't get the water to come through the coffee holder. It builds up pressure but won't shoot the coffee out. The water comes out if I take the holder off , but not when it is in place. Do I need a new...
Remove the brew head. Pry out the metal coffee filter, then pry out the rubber gasket. There is a small black plastic insert that is likely gunked up with coffee buildup. Clean the parts well, reassemble, and then try again.
If you are a good "tamper", you can leave out the rubber gasket and plastic insert entirely, and just go with the the filter. It takes a bit of practice, but you will get equally good crema if you match the grind to your tamp pressure.
Jun 21, 2010 | Saeco Starbucks Sirena Espresso Machine
Coffee grounds in the cup
since you said usually... I suspect the rubber seal that surrounds the top needle is not seating well...
you can verify this by making a beverage with a k-cup and, just before the water starts, add a little hand pressure to the K-cup arm pushing down a little bit... not hard...
If it consistently makes a good beverage, then we focus our attention to that piece of the brewer...
when the consistency of the water changes, it tells me to look for leaks or unusual percolation of water...
you can verify the K-cup holder is ok... but another way to simulate the hand pressure is to put a shim of some sorts under the lip of the k-cup... like the thickness of a couple sheets of paper under the rim... not the actual k-cup... but the k-cup holder... raising it up a smidge is the same as the slight hand pressure...
I would look to see if the rubber seal has come loose around the top needle....
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
May 04, 2010 | Keurig Platinum B70 Coffee Maker
Very little water comes out while brewing and its brand new
Could be the exit valve on the k-cup holder is clogged.had same prob and fixed in 2 mins.Take out k-cup holder as if you were going to brew your own grinds.It will twist off into two pcs.Take the top pce and get a paper clip and stick end of paper clip into valve from the bottom and wiggle a little then run under water to clean out.reassemble and you should be brewing coffee again.Good luck
Apr 07, 2010 | Keurig Platinum B70 Coffee Maker
Krups XP4020
The coffee holder is just hanging in place, not secure against the seal as it should be. Make sure the coffee holder is secured flat up against the seal before turning the handle and locking it into place.
Apr 18, 2008 | Krups Allegro FND111 Espresso & Coffee...
Gaggia Baby Espresso Machine Logo
314 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
