Question about Iolo Technologies System Mechanic: Windows
System Mechanic causes Registry problems
After installing System Mechanic 8.5.2, SM corrupted my Registry (XP Home, Service Pack 3) and caused software loading problems. SafteyNet failed to undo the changes and so I had to reload XP. I emailed Iolo who referred me to an article on how to exclude items in the Registry, but I found this impossible to understand. I reloaded XP, reinstalled SM and the same thing happened.
Is there some Registry-maintenance software out there that does not itself screw up the Registry?
  • Anonymous Mar 13, 2014
    Iolo system mechanic system shield real time protection will not start becouse some services failed to start.
  • 827 Answers
I use nCleaner and have had absolutely no problems for over a year now. I find System Mechanic has too large a 'footprint' and, like you said, is pretty incomprehensible to use out of the box.
The only thing that took me unaware with nCleaner was that it cleaned out My Received Files by default, so all the photos I had been mailed through Messenger were deleted, so make sure you copy them into another folder first :)
I have never had any software problems after using it though, and I install and uninstall programs pretty regularly!
So it comes highly recommended. It's a bit like CCleaner (if you have heard of that) but with more functions like Registry Clean.
I would reinstall XP first though as SM seems to have messed up, and you want a clean start. Also remember to reinstall all the XP drivers for your motherboard too.
Hope this helps
Chris (ziraffa)
Posted on Dec 26, 2008
I have directx 10 but still can not fix the Runtime Error 429. What should i do?
Error 429 issue is caused by corrupted Windows registry.
The first tips to fix runtime error 429 is to run security scan on your computer.
http://www.filehippo.com/download_spybot_search_destroy/
Repair your system's registry with http://download.cnet.com/RegScrubXP/3000-2094_4-10820427.html
Also you can try to go to the Microsoft Windows Script update page to fix runtime error 429. http://www.microsoft.com/downloads/en/details.aspx?FamilyID=47809025-D896-482E-A0D6-524E7E844D81
If possible download XP SP3 http://windows.microsoft.com/en-US/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
Hope my solution will help you...
Have a Nice Day
Oct 13, 2010 | Individual ResumeMaker Career Edition for...
Tip
System mechanic or professional failure code 323-a
This error comes usually on system with Service pack 3.
The reason why this message comes on the system is the service pack 3 is either currpted or not installed properly.
" The 323 error can occur when using the Standard Edition release of the 1.0 version of the Microsoft Systems Management Server program. It happens when the Systems Management Server is used with the non-U.S.
version of the Microsoft SQL Server version 4.21a. The 323 error appears in the Systems Management Server event log. It is logged because of a discrepancy in the settings for the two programs. The required time and date format for the Systems Management Server is different from the format used in the SQL Server. It may happen when the
French version of the SQL Server is installed on a U.S. version of Windows NT wherein French is the default language used for the SQL Server "
Do the steps to fix this problem:-
For windows XP :- ( If you have service pack 3 installed on your system )
1:- Remove the Service pack 3 from your computer :-
Click on start-->go to Computer--> Go to C drive ( Primary Drive )--> Go to windows -->
If you find some hiddens files find out $NtServicePackUninstall$ folder. If you do not find it Stop here.
If you do find it Do this:-
open $NtServicePackUninstall$ ---> open spuninst ---> double click on spuninst.exe
( Exact Path :- C:WINDOWS$NtServicePackUninstall$spuninstspuninst.exe )
Now follow the instructions and uninstall the service Pack 3. During the uninstallation of Service Pack 3
It might would prompt you that some files or services will be affected after uninstalling the Service Pack 3
Do you want to continue. So at this point DO click on yes and continue with the uninstallation.
If the uninstallation is succcessfull. Restart the computer and then try to install the system mechanic professional
or system mechanic again.
If the uninstallation of service pack 3 is unsucccessfull
Try this:-
Do a system restore and then try to uninstall the service pack 3 using the above steps.
If even then you are unsuccessfull then do this:-
Save your imporant files and documents on an external hard drive and Format the hard drive completely.
Now try and install the system mechanic professional or system mechanic. you will successsfully install it
for sure.
If the uninstallation of service pack 3 is succcessfull
Do this:-
Try to install the software now. If it works perfect. Else do this :-
install the windows installer 4.5 using the link below.
[ http://www.microsoft.com/downloads/details.aspx?FamilyID=5a58b56f-60b6-4412-95b9-54d056d6f9f4&displaylang=en ]
downlaod the executable file given below on this page:- ( WindowsXP-KB942288-v3-x86.exe )
After installing the windows installer try again to install the software. If it works perfect. Else
Try this :-
Now re-install the Service pack 3 again. using the below link:-
[ http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en ]
This may take a long time. But after installing the service Pack 3 again.
Install the software again. If it works perfect else
Do this :-
for sure.
If this does not work either call system mechanic people using the number 323-257-8888
For windows vista :-
Try to do windows Update and then try to install. If does not work then try to create a new user account and then
try. As some times the user account is also corrupted.
For windows 7 :-
Do windows update and then try installing the software if does not work then try
calling the system mechanic people using the number 323-257-8888
Note :-
( For windows 7 and vista we still are doing a research once we are done we will put that online.
In the mean while follow the instruction given above. )
on Jun 24, 2010 | Computers & Internet
Keep getting stack overload. line 0
Your browser is corrupted, reinstall it.
Jul 11, 2010 | Dell Inspiron 1720 PC Notebook
Security Certificate Error: Not Trusted
It's because your system doesn't have the right time and date. Make sure that you have the right time zone and the automatic daylight change option activated as well, also check if your computer is on sync with an internet server, to do that just double click on the clock and a window will pop there you can do all those changes.
Feb 18, 2010 | Microsoft Windows XP Home Edition Service...
The file <windows root>\system32\hal.dll.
Restart the PC. The hal.dll error could be a fluke.
Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Feb 15, 2010 | Dell Latitude E5500 Laptop
Have windows xp firewall corruption,
Access "Add/Remove Programs", and uninstall Service Pack 3.
Dec 11, 2009 | Microsoft Windows XP Home Edition
Iolo system Mechanic 8 causes registry problems
yes. tune up utilities 2009.
download the trial version from
http://www.tune-up.com/products/tuneup-utilities/
then enter the information below to make it full version
Organisation: vistasoft
Serial: AQKA2P-HY7FQF-8M0930-DW4H4V-1EJPRC-16CHPN
let me know the outcome.
enjoy
Dec 27, 2008 | Iolo Technologies System Mechanic: Windows
Svchost error with zyxel p 600 series
your operating system is corrupted..........
Dec 05, 2008 | Zyxel Prestige 841 (91-004-226010) Modem
Iolo Technologies System Mechanic: Windows Logo
1,135 people viewed this question
Top Iolo Technologies Computers & Internet Experts
Peter Dragonetti
Alun Cox
Dayton Computer
Dayton Computer
Are you an Iolo Technologies Computer and Internet Expert? Answer questions, earn points and help others
