Brand new lcd tv worked for one day then not coming off standby
Brand new Acoustic Solutions 42" TV set up on Christmas Eve, worked Christmas Day and this morning not coming off standby. Remote not even switching blue light on, has to be done at side of telly.Then,it just sits and stares at us regadless of what we try. Any suggestions would be greatly appreciated.Thanks in advance.
    Novelist:
  • 152 Answers
Hello, if all your connected components and power sources are ok
then you may want to take it back for an exchange if it is possible.
it seems to be defective from the start.
your tv is in shutdown mode, a fualty power supply or internal board circut is cuasing your tv not to work.the tv needs service for internal circut trouble.
try to exchange it or get your refund asap..
hope this helps
happy holidays
Posted on Dec 26, 2008
Stuck timer
my acoustic solutions tv is stuck in standby mode its the timer because it com on the other day how do i turn timer off
Jan 02, 2014 | Electrolux Ovens
Acoustic Solutions LCD26761HDF TV turned itself off & standby light started flashing. TV wont respond to remote or on set buttons
The solution to Acoustic Solutions problems, such as intermittant power off and flashing blue light is very simple: dump it in the trash. This product has lots of problems which are associated with memory and timing. There is no software update available, its just cheap Chinese ****.
Sep 25, 2010 | Daewoo DLP3212 32 in. LCD Television
I bought a brand new 42 inch plasma vi vo tv 2
New products do fail. The set should certainly be under warranty. I would speak to the dealer you purchased the unit from and see what they suggest. Don't remove the rear cover, or do anything else to give anyone a reason to void your warranty. Most brands are 90 days on parts and labor.
Nov 25, 2009 | Televison & Video
PLaystation 3 won't link up via HDMI cable
You might want to try a factory reset on your PS3 = turn it off then hold down the power button for 5 seconds it should then Beep.
there is a small memory in the PS3 that stores info about the tv that is was Initially setup on. IF you do this reset this should allow you to connect it to your Acoustic Solutions tv via the hdmi cable.
Another Tip i would do is connect it all up with it turned off then power up your appliances once its all connected.
Hope this sorts it out for you
Little Dish Fitter
Sep 18, 2009 | Televison & Video
Acoustic Solutions backlight comes on then resets TV to Standby
Probably a burned out transformator in the backlight inverter
Jul 16, 2009 | Televison & Video
Olevia 42"
Olevia LCD 542I - Had the same issue for a week until the tv would not turn on anymore, after several attempts it came back on. A few days later the tv turned off then only the standby light was on, then lost the standby light as well. After researching the problem it could be in two areas, either the power supply or main board. Removed the back and found the power supply had several capacitors that were bulging on the top and appeared the fluid was leaking, all signs of a failed part, removed the PS and replaced four capacitorst that had shown some issues. If you can removed the PS and check for a number on the board, mine was FSP271-4F02, and find someone who has some electronic circuit capablilty, the issue may be resolved at a fraction on the cost of a new power supply.
Apr 13, 2008 | Olevia LT42HVi 42 in. LCD Television
Will not turn on
have you tried to unplug it? need model number also
Feb 01, 2008 | Televison & Video
Freezing Tv
it is the chip you need to unplug the tv for about an hour and see what it does.if that do not solve the problem have a tech look at to replace the chip or the whole board.good luck
Apr 02, 2007 | LG M4200C 42 in. HDTV-Ready LCD Television
Televison & Video Logo
190 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
