Question about Samsung TXP3275H 32" TV
Color rings on hdtv
I have a Samsung HD 36" X-P3264 and instead of a regular picture, it now has rings of color (red, green, and purple) making the picture colors now look like a bullseye. the picture is also off center. you can still see the screen in black and white with the bullseye colors in it. prior to the rings appearing, it was moved 4 feet. the tv was on a stand that was slid the four feet and was not tipped or tilted. can anyone help? i would like to know what is wrong with it, what it would take to fix it, and a cost estimate if i take it to the shop. Thanks, Mike
  • 2 more comments
  • michael preiss Apr 18, 2007
    would this repair be covered under the warranty for the picture tube?
  • michael preiss Apr 19, 2007
    Thank you very much for your help. I have contacted Samsung and they are setting it up for repair.
  • michael preiss Apr 20, 2007
    You're not going to believe this, but when the TV was turned on this morning, it is working perfectly.Any ideas now?
    Mike
  • Anonymous May 02, 2009
    color rings on hdtv
    President:
  • 1,284 Answers
Sounds like a CRT (picture tube) that did suffer a bit of a blow to it. The rings are caused by the thin sheet of steel inside of the CRT called a shadow mask being warped. The other cause for this is the internal degauser in the TV comming on and staying on too long causing damage to the CRT. Either way the CRT is over $400 plus you will need to find out what caused the issue and repair that first.
Posted on Apr 18, 2007
  • 1 more comment
  • Don
    Don Apr 19, 2007
    The CRT should have a 2 year warranty I think.
  • Don
    Don Apr 19, 2007
    You might have to pay for labor but, the CRT can be expensive so good thing it is under warranty. Post back when all is done.
  • Don
    Don Apr 20, 2007
    The degausing circuit is causing the problem then. At least not the CRT and less costly.
I have sound but the picture is purple and will not adjust with the remote or manually with the buttons on the tv what can I do to fix this on the philips 36pt41b129
The unit has lost its green video information. This can be a picture tube or a green drive problem. The only colors you are getting are red and blue thus the purple picture. All picture tubes have red, green and blue guns to make all the colors needed for a normal picture. It will take some troubleshooting to determine whether it is a drive problem or the picture tube itself. Have a repair shop check it out for you. A 36" TV is worth a check out fee. Thanks for using Fixya. Let me know how it goes.
Nov 05, 2009 | Philips Televison & Video
Green flashing crazy patterns all over
It may seem obvious, but have you may want to double-check all the connectors to make sure that none are loose?
May 15, 2009 | JVC HD-56FB97 HDTV
I have a samsung sp42q2hl, which on the front of the tv say's it is a hdtv ready, and yet i cannot watch high defenition images or movies, also there is no hdmi inlet at the back so i'm not sure how you...
Hi.
Use component to connect this will give yu HD picture,
On the back of the set you will see A group of 5 phono sockets Blue, Green, Red, These carry picture,
Then Red, White, these carry stereo sound.
Component video improves the picture quality even more by not only separating the color from the black-and-white portions of the picture but by further splitting the color information into two color-difference signals. When the picture signal is split up in this way, you get an unfiltered, uninterrupted image, with better resolution and greatly improved color saturation. And this is why component video is the predominant method of hookup from HDTV set-top decoders to HDTVs.
So this is how your set can produce HD picture from Hd source.
http://dysonmanuals.llc.nu/
Jun 22, 2008 | Samsung Televison & Video
Sharp aquos LC-37D4ou
What kind of connections are you using?
If component (red, green, blue) double check to make sure they are seated properly. I'm thinking it sounds like the blue one got loose.
Mar 27, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Mitsubishi DLP 62" WD-62725- Clear Picture w/ Purple Screen
Sounds like one of your colors are missing. make sure all colors are lit, Blue, Red, Green
Dec 27, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Color problem with Samsung 40 in LCD HDTV
Check your component cables. You have 3 colors coming in. Red,Green and Blue. Make sure the Red cable is good. You can do this by substituting the red cable only, or just change all 3 cables
Best regards
CircuitCity
Nov 25, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Color problem
Replace D805 (?) Thermistor for permanent fix, manually
degauss with coil is temporary........T.
Oct 29, 2007 | Panasonic CT-36SF37 36" TV
Samsung HL-p4674 RB
Sir, Pull up the on screen menu and make sure the unit is set to display 1080i or 720p instead of 480i. This may be the issue. Good Luck
Jun 04, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung TXN3275HF 32" tv - purple picture
Chuck the TV - probably It depends on the repair facilities available where you live. In big urban areas the cost of staffing a repair shop is such it can cost nearly as much per hour just to look at an item is it does to buy the next one-plus you get all the latest features.
May 21, 2007 | Samsung TXN3275HF 32" TV
Samsung TXP3275H 32" TV Logo
261 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
