Question about Samsung SGH-G600 Cellular Phone
I WANT TO DELETE OPTION FROM 'CENTER' BUTTON TO GAIN MENU OPTIONS
Hello, when i press my main centre button to normally gain the menu options, i get GPRS/EDGE NETWORK WHICH THEN TURNS ON, I want to delete this if possible, and just have access to normal MENU options.can you help please?
First you selected the right button on your hand and then it will deleted ok you changes the option button in settings
Posted on Dec 26, 2008
How do I set clock on c3 picasso
Press the "MENU" button for access to the main menu , then press the " ^ " or " v " buttons to scroll through the various menus: - radio-CD, - vehicle conf guration, - options, - display settings, - language, - units. Press the "OK" button to select the menu required.
Once the "Display settings" menu has been selected, you can gain access to the following settings: - year, - month, - day, - hour, - minutes, - 12 or 24 hour mode.
Once you have selected a setting, press the " << " or " >> " buttons to change its value. Press the " ^ " or " v " buttons to switch respectively to the previous or next setting. Press the "OK" button to record the change and return to the normal display.
Mar 09, 2015 | 2011 Citroen C3 Picasso
Tip
How to delete multiple text messages on a Samsung Intensity
On many mobile phones, you only have two options for deleting text messages: deleting one message at a time, or deleting a whole folder at a time. However, the Samsung Intensity (among other phones) gives you the option to delete multiple text messages at once without deleting an entire folder. You just have to know how to do it.
Go into the Messaging menu, either by pressing the upper left option button or by going into the main menu and selecting Messaging (option #2). Select your inbox, then press the upper right option button (Options). Select #9, Msgs View by Contact. The text messages in your inbox are now grouped according to who sent them.
From this view, you can delete multiple text messages at once. Press the upper right option button again and select choice #2, Erase Multiple. Now as your messages are displayed, there is an empty box next to each one. Scroll down through the list and select the messages you want to delete by pressing the center of the directional pad. A check will appear next to that message. To uncheck a message, repeat the same process.
The only messages you won't be able to delete are messages that you've previously marked as locked. If you want to delete a locked message, you'll have to unlock it first, then delete it.
Once you've put a check next to all of the messages that you want to delete, click the upper left option button (Done) and you'll see a confirmation message. Choose whether you want to delete all of the checked messages or only the unread ones, and then click the directional button (OK). The messages you selected will be deleted.
To resume having your messages displayed in chronological order, click the upper right option button and choose option #4, Msgs View by Time.
on Jan 12, 2011 | Samsung SCH-U450 Cell Phone
Bosch dishwasher has a buzzer on all the time .
I'm not sure if you mean it is buzzing because of a fault or if it buzzes to say the program has ended and you want to switch this off??? if it is the later the following should help
To activate any of the Dishwasher Options listed, follow these steps:
Open the dishwasher door far 1. enough to expose the control panel.
2. Press the On/Off button.
3. Press the MENU/OK button until the desired option appears in the display window.
4. Press the - or + button to step through the available option settings.
5. When the desired setting is shown in the display window, press the MENU/OK button to save the setting. The display will indicate "Value Stored" and return to the main
menu. If you did not change the setting, press the start button to return to the main
menu.
6. Select the desired wash cycle by pressing the - or + buttons.
7. Press the start button and close the dishwasher door to begin the cycle.
NOTE: In the Options Step Down Menu, you can return to the main menu at any time by
pressing the START button.
Feb 20, 2013 | Bosch SHX98M0 24 in. Built-in Dishwasher
Android xperia guide
  • Press the center button on your X10 Mini Pro to launch the phone's main menu. Tap on the "Settings" option to enter the Settings menu.
  • 2Tap on the "Wireless Controls" heading to manage your phone's wireless connections. Tap on the "Wi-fi" or "Bluetooth" heading to enable your phone's Wi-Fi or Bluetooth radio.
  • 3Tap the "Wi-Fi Settings" option, and then tap "Add" to connect to a wireless network. Or tap the "Bluetooth" settings and then "Discoverable" to begin pairing your phone with a Bluetooth device. Press the phone's right button to return to the main menu.
  • 4Tap on the "Sounds and Display" option. Tap on the "Silent Mode" option to mute your phone's ring or tap the "Phone Vibrate" option to set your phone to vibrate. Tap on the "Phone Ringtone" option to select a ringtone for your phone.
  • 5Tap on the "Brightness" option to adjust the amount of light your X10 Mini Pro's display will emit. Tap "Screen Timeout" to set the amount of time your phone's display will stay lit after being inactive. Press the phone's right button to return to the main menu.
  • 6Tap on the "Applications" heading. Tap on the "Manage Applications" option to manage the programs that appears in your X10 Mini Pro's main menu. Tap on a program, and then select the "Delete" option to remove the program from your phone. To add a new program, tap on the "Market" icon in the main m
    sincerely. G-d bless you
    ernesto cuadra
    managua,nicaragua.c.a
  • Dec 18, 2011 | Sony Ericsson Cell Phones
    How do i put a signature on a pantech link
    Text message signatures are the post scripts at the end of text messages. Some people use text message signatures to provide an unrelated, off-top status update to the recipients of their text messages. Other people use text message signatures to attach a favorite quote with every outgoing message. If you own Pantech's Link handset, you use the device's messaging templates to attach a signature to your text messages.
    steps:
  • Press the right "-" button to access the Link's menu. Use the handset's directional pad to navigate to "Messaging" option in the menu. Press the center of the directional pad, the "OK" button, to select the "Messaging" option.
  • 2
    Select the "Templates" option from the "Messaging" menu, using the directional keypad. Select "Options" from the "Templates" menu, using the left "-" button and then select "Add New."
  • 3
    Key in your text message signature using the Link's QWERTY keypad. Select "Options" with the left "-" and then select "Save" from the "Options" menu.
  • 4
    Press the red "End" button to exit the "Templates" menu. Press the right "-" button to return to the Link's main menu. Select the "Messaging" option from the menu.
  • 5
    Select the "Create Message" option in the "Messaging" menu. Compose your message with the Link's QWERTY keypad.
  • 6
    Select the "Insert" option before sending your text message. Select the "Templates" from the "Insert" menu. Select your text signature from the list of available templates and then select the "Send" option to transmit your text message.
  • Dec 02, 2011 | Pantech Link P7040 Black Rubber Feel Hard...
    How to clean browser or cookies
    Hello melissalucy8 and welcome to FixYa. Clearing your browser history and cookies is easy. Let me walk you through.
    1- Select Internet Browser from the XMB.
    2- Press the Triangle Button.
    3- You will now see a list of options on the right.
    4- Highlight History and press the X Button.
    5- Now you will press the Triangle Button again
    6- You should see a option for Delete All. Highlight this and press X.
    7- You will see a screen that asks Are you sure you wish to delete history? Highlight Yes and press X to complete the process.
    Now for deleting your cookies follow these steps.
    1- From the browser options menu locate and highlight Tools and press X.
    2- From here you can delete your cookies, cache or web history. Highlight the ones you wish to delete and press X. If you are trying to clear all traces of your web surfing hightlight and select cookies and cache and press X to delete.
    Now your PS3 browser is clear.
    I hope you found this helpful and thank you for visiting FixYa.
    Apr 27, 2011 | Sony PlayStation® 3 (80GB) Console
    The language is not egnlish
    STEP 1 - Go to the main menu
    1. Press the Menu/Home button.
    STEP 2 - Go to Settings
    1. Press the Pause/Play (>'') button several times or until you see a picture of an equalizer.
    2. Press the center button on your device to select it.
    STEP 3 - Look for the language setting
    1. Press the Down button until you find an option that has the letters, FM.
    2. Scroll to the one above this option (this will be the Language option), then press the center button to select.
    3. Scroll through the options, and select English or your preferred language.
    Mar 22, 2011 | SanDisk Sansa Clip MP3 Player
    How to adjust color for better picture
    Hello there,
    For the Best Picture use the HDMI Cable and here are the Settings for the color setup.
    Adjusting Your HDTV Settings
    Using the On-screen Display (OSD)
    The remote control or the control buttons on the side of the TV can control all the function settings. The
    OSD allows you to adjust contrast, brightness and other settings. The TV will save changes made to the
    settings, even if the TV is turned off.
    The OSD consists of several menu options. The main menu options may vary depending on your
    selected input source.
    Note: Some of the main menu options may have additional submenus, for example, the TV Rating
    submenu for Parental Controls.
    The remote control or the buttons on the side of the TV can control all the function settings. The HDTV
    Settings App allows you to adjust contrast, brightness and other settings. The TV will save changes made
    to the settings, even if the TV is turned off.
    The HDTV Settings App consists of several menu options. The main menu options may vary depending
    on your selected input source.
    1. Press the VIA button.
    2. Press ? or ? on the remote control to select the HDTV
    Settings App, and then press OK. The Main Menu will be
    shown on the screen.
    3. Press ?, ?, ?, or ? on the remote control to select one of
    the menu options:
    ? Input
    ? Wide
    ? CC
    ? Sleep Timer
    ? TV Settings
    ? PIP
    ? Network
    ? Bluetooth
    ? Help
    4. Press OK to select the option or feature you want to adjust.
    5. Once the menu option is displayed, press ? or ? on the
    remote control to select one of the items to adjust.
    6. Press OK to select it, and then press ?, ?, ?, or ? to adjust the selection.
    7. Press BACK once to return to the previous screen. To return to your program once adjustments
    have been completed, you can do one of the following:
    a. Press EXIT on the remote control.
    b. Press the RED button on the remote control.
    c. Highlight and select the RED X in any menu.
    i hope this was helpful don't forget to Rate
    Jan 26, 2011 | Vizio M550NV 55 in LCD HDTV
    How do I get the language back to english on a sansa clip
    To get back to English on a Sansa Clip:
    1. Start from the main menu:
    > Press the menu/home button
    2. Select Settings [ image of an equalizer ]
    > Press the pauze/play button >|| several times to select the equalizer
    > Press the center button to enter the settings
    3. Select language
    > Press the Down button to see an option with the letter FM
    > When you see the FM option, go one step upwards with the UP button: this is the language option
    > Press the center button to go into the language selection
    > Scroll Down/Up through the options to find English
    > On the preferred language press the center button to select it
    Aug 15, 2010 | SanDisk Sansa Clip MP3 Player
    W375
    From the menu, select "Recent Calls"
    Go to received calls, press the centre button & you will get a menu, where the first option is Delete (for the first entry) and the second option is "Delete All".
    Go back and select "Dialled Calls", again press the centre button for the menu with the delete commands.
    Feb 15, 2008 | Motorola Mobility W375 Cellular Phone
    Samsung SGH-G600 Cellular Phone Logo
    62 people viewed this question
    Top Samsung Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
