Question about Canon PIXMA iP3000 InkJet Photo Printer
Error 6B00 On the iP3000, I received this error which says, "A problem has occurred with the printer mechanism". All I did was move it from one room to another and everything is hooked up the same. What went wrong?
  • marcuslee Dec 16, 2007
    yup im also have this error code 6b00 for ip 3000, i dont know how to solve it .who can help me ....
  • Neil247 Mar 26, 2008
    6B00 error, tried cleaning the "squeegie" but still get the same error. What does the error code mean anyways?
  • 5 Answers
A JWalker posted on April 17, 2007, it is the "squeegie" thing.
This is located on the right side (as you face the printer) and is held by a little white plastic holder with a spring attached to it.
The round track seemed to be mucked up with ink. If the squeegie is closest to the front of the printer, gently move it towards the rear with a pencil tip. I used the eraser end and some tissue to make a large Q-Tip, loaded it with windex and wiped down the round track and it works again.
Note; When moving the squeegie towards the rear, it will clear the mucking and the spring will take over and move it to the proper position allowing cleaning of the rail.
Posted on Jan 25, 2008
Same problem error 6A00: The head cleaning process leaves ink to dry on plastic small parts in the area where the heads park and may cause some mechanism to stick if printer left unused for some time. Try to move carefully on everything you find in the area after moving the heads away. I just did this, something went click, and the printer is good as new again. Problem now is my inex finger is black with printer ink...
Posted on Jan 08, 2008
Something is blocking the paper feed mechanism
Posted on Jun 06, 2007
Hey anyone who is in denial! I have a Canon Pixma ip300 and i previously had a Service Error 6b00. I had no idea what I was doing, so I cleaned out the strip along the bottom where that little thing that holds the ink is. Also I put down the little door (for faxes??) with the logo Canon on it with the printer cover open. I then pushed down the thing that holds the ink at the same time. I fiddle with the door/ink holder than turned the printer off/on, then I shut the little door and pressed resume... and it printed!! Hoorayy! Hope this helps. Pardon my bad "computer speech"
Posted on Jan 20, 2008
I also have an Ip3000 which has performed very well for a few years. Yesterday it came up with Error 6A00 and would not work. Canon will not tell you what the code means but my local exasperated (Yes they have trouble with Canon too! ) told me it was a 'paper path error' and it would cost A$200 to fix it when the printers cost less than that new. I pulled the casing off it ( unneccessary ) and discovered ink soaked paper rubbish under the place where the print head parks. I removed it all carefully and my Ip3000 and I are friends again. I have used all types of generic ink tanks and they all work well. I like the printer but I am deeply resentful of the way manufacturers manipulate the public in this way.
Posted on Jun 26, 2007
Service error 6B00.
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Mar 18, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
What does error 6b00 mean
Hi I think it to do with some thing Paper feed position error [6B00]
Jan 23, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA IP3000 ERROR 5100 i receive this code error, ¿how can i fix it?
Try
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Hope it works for you: Pineworks
Jan 11, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Canon MP830 has error code 6B00 after paper jam
6B00 is Paper feed position error.Look for any pieces of paper in sheet feeder.
Dec 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My cannon mp600 printer makes a whirling noise when i switch it on.and comes up with error 6B00. the noise sounds like the cartridges are struggling to move across
From reading up specifics...
i have a couple of different pixma printers but have done similar things...
possibly something is jamming the paper feed... like a toy or pen down the back or a tiny piece of paper?
have a good look ... maybe blow out with AIR DUSTER ... (still no go?)then after that try turning printer upside down and give it a gentle shake, yes, really
be careful though
if helpful please rate
Oct 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
IP4000 service error 6B00
6B00 is a paper feed error, look in the back with a mirror and flashlight, and see if something has fallen in where you put the paper for printing.
Jul 19, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Error code 6B00
6B00 is a paper feed position error, the paper feed is not returning to the home position, or the encoder wheel was damaged. You can try to manually turn that large roller, and then power up again, but if it doesn't help you'll need a shop repair.
Jun 07, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Eror Code 6B00
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
May 24, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Just not working
the printer is telling you the truth. when that happens, it's like a car starting to squeak too much. Mechanisms do wear out, you know.
got backup for your computer?
Jan 21, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Ip 3000 mechanism error
change your printer use - hp - 3050
Jan 18, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
975 people viewed this question
Clive
Clive
old marine
old marine
