Question about Dell Dimension 4600 PC Desktop
I would like to change my hard drive
I currently have an 80GB in a dell dimension 4600 and would like to put in something around 250GB. My concern is which one will be compatible? I just upgraded my power supply to 400W. Memory will be upgraded to 2GB, currently running 1GB. Is it better to run 4 x 512mb or 2 x 1GB?
  • carlylevi2 Jan 01, 2009
    I just wanted to thank you for your input. Just in case it is troubling you, the board has 4 memory slots and after countless hours of digging I was able to find out that it will support 4GB of memory. At the time of my last posting, I was running 2 x 256 and 1 x 512 (thank you office depot). I purchased 1 x 512 and 2 x 1GB and am currently running 3GB. This is truly the upgrade I was looking for. I spent $90 and it has been worth it. Windows Vista hasn't operated so good on this old machine. Yes, I made that my primary OS when XP to crashed on me. Off to do some research on hard drives. Thank you again for your input; it really helped.
    Problem Solver:
  • 8 Answers
The Dell Dimension 4600 uses a Serial ATA-150 hard-drive... you should be able to buy one just about anywhere.
Anything at http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010150014%201035915133&name=SATA%203.0Gb%2fs should work on your computer.
As far as I know your system does not have 4 memory slots on the board, but if it does, it would still be better to have 2 x 2GB.
Posted on Dec 26, 2008
  • 837 Answers
If you are looking to save just a "small" bit of $ .. 2 - 1GB sticks should be cheaper .. but what is the current configuration . is it 1 - 1GB or 2 - 512MB or 4 - 256MB?
You have the option of IDE or SATA drive so either is an option .. You may want to get a drive copy utility and just "clone/ghost" your current to the new drive and then swap it to master and GO
Compatible printers for Dimension 4600?
Any printer available will work. If it's compatible with your operating system software, i.e. Windows XP, Vista or Windows 7.
Oct 02, 2013 | Dell Dimension 4600 PC Desktop
Dell dimension 4600 setup
http://www.dell.com/support/drivers/us/en/04/Product/dimension-4600
DRIVERS.
ABOUT Os THAT CAN YOU PURCHASE AT ANY PC-DEALER.
JUST PUT THE DVD IN YOUR CD/DVD-PLAYER 32X OR 64X DVD FOR THE PROCESSOR YOU HAVE.LET WINDOWS DO THE REST
Jun 23, 2013 | Computers & Internet
Hardrive is unknown device in bios
The BIOS determines the maximum size hard disk the computer can support.
The max hard disk size for this model Dell is 80Gb.
To use your 250Gb hard drive, install this Hard drive into an USB hard drive case and use it as an external USB hard drive.
Mar 09, 2013 | Computers & Internet
Is it possible to fax with my Dimension 4600?
1. Yes, very much possible. Any PC, laptop, desktop, mobile phones. What you will need is no.1 the Internet connection and 3rd party application to do the job for you. I am currently using pFingo.
<a href="http://www.pfingo.com/pf/public/control/signUp?referer=c8d9f73a9751010c5a68787c71039165" target=_blank>Click here for more Info</a>
2. Send fax at about 15cents per 5secs of fax internationally.
3. Call internationally at about .02 cents in USD per minute all around the world.
Oct 27, 2009 | Dell Dimension 4600 PC Desktop
RAM for Dell Dimension 4600
Heres a link from DELL,it has all the correct parts and manuals for you,
This section is titled Removing and Installing Parts by DELL.
http://support.dell.com/support/edocs/systems/dim4600/en/4600/sm/parts.htm
Your memory is DDR Ram.
Aug 16, 2009 | Dell 1.44 MB Internal Floppy Drive for...
I have a dell dimension 4600 which is having intermitent problems connecting to the internet via a hardwire connection to a verizon fios wireless router. The router works fine with my dell laptop both when...
I assumed you adapted the pc with a device for wireless connection ..if all the other are OK ..the problem is this device ......try it on other computer ..if it works ..its just a compatibility issue ..if not its a problem with it ...
also try to change the freqvency they work in ..if it possible ....or change the position ..cause they work on a radio wave and you might interfere with something when it goes out of signal ...
Jun 16, 2009 | Dell Dimension 4600 PC Desktop
Ethernet card
hi
yes the ethernet card is compatible
kind regards
RAhUL_hunk
Mar 10, 2009 | Dell OptiPlex GX260 PC Desktop
4600 Dimension Dell currently have 512 ram want to upgrade 1 gig
That computer takes PC3200 RAM. it can be ordered here: http://www.cdw.com/shop/products/default.aspx?EDC=638463
PC3200 memory can also be found at amazon.com Be sure not to buy laptop memory.
May 15, 2008 | Dell Dimension 4600 PC Desktop
New Hard Drive over 128 GB on Dell 4600 - but only recognizes 128 GB!
Check that your motherboard supports the high capacity of HDD
Install the OS having the latest service pack combination.
Let me know if your problem is solved and rate me as FIXYA!
May 10, 2008 | Dell Dimension 4600 PC Desktop
Dell 4600 motherboard
That particular Dell uses a power supply with non-standard wiring. The plug is the same size as an ATX plug, but it's wired differently. If you were to replace motherboard & plug in the standard power supply, it would damage the supply, or the motherboard, or both. Also, the front panel plugs (for power & power LED & hard drive indicator) are proprietary as well. Ideally you should replace it with another Dell Dimension 4600 motherboard. I've found replacements for reasonable prices on some of the auction places on the web. I recently replaced a failed motherboard in my Dimension 8300 with one I got from a popular auction site, I think my cost was about $59 plus shipping.
The other option would be to remove the hard drive, video card (if any), and optical drives, and consider a 'barebones' package from various sites such as geeks or newegg.
Jan 05, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
98 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
