Question about GE GSL25JFPBS Side by Side Refrigerator
Frozen water line
How do I get to and fix this problem on a GE side by side fridge? Thanks
  • 700 Answers
You have to take the bottom shelves out of the refrigerator and then towards the back of the refrigeratoer you will see the water resevour. Tale a hair drier and thaw out the resevoir. then adjust the temperature and make sure that there's good circulation aruound all of the product that ouy have in the refrigerator. Thanks for using FixYa
Posted on Dec 26, 2008
Water line keeps freezing on my GE side by side refigerator
Check to see if the water tank in the bottom of the refrigerator section is frozen. If it is, you will need to turn the refrigerator section temp down.
Dec 05, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Water does not work. Possibly frozen line. i keep
I have a GE PSS25SGNA no ice no water freezer side is reading -2 refrigerator side 25 everything is freezing help
Jan 03, 2011 | GE PSS25SGNBS Side by Side Refrigerator
The water line was frozen (no ice being made and no water available in the door), so I took everything out of the fridge and freezer, let it all defrost, plugged it back in, now I have water in the door,...
Grab a blow dryer and aim it at the water tube that supplies water to your ice maker. More then likely it is frozen with ice and will need further melting to clear it out so that your ice maker will work again
Sep 14, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE GSH22JFR side by side refrigerator
Yes the water line has frozen in the door. There is a kit to repair this WR49x10173
Feb 09, 2010 | GE GSH22JFR Side by Side Refrigerator
G.E. Side by side model quit dispensing water. The refrigerator door was not completely closed overnight. Is is possible the water line froze since the freezer had to run so much
It is possible the water line inside the freezer door froze . Remove the bottom kick plate and follow the white tubing about 6" to a coupling . Push in on the white ring and at the same time , pullout on the tubing . Push the water dispensor , and if water comes out of the hose going under the fridge , this means the line is frozen in the door . If no water comes out , it means the water tank at the bottom of the fridge section (behind crispers ) is probably frozen . A hair dryer should work on the tank , but , a different procedure will be needed to thaw the door . Come back if door is frozen for the procedure .
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No ice and no water dispenser
Would have to talk you thru with chat .
Jul 17, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a GE Profile Arctica Side By Side refrigeratorand the water despenser is not working. I have narrowed the problem down to be a frozen waterline, but it is not frozen in the frezer door. The line is...
There may be an issue with the water dispenser line freezing in this model. The fix for it might be this dispenser water tube heater kit # WR49X10173. Hope that helps you out and best of luck
http://tclaundryrepair.com/
Feb 25, 2009 | GE Profile¿ Arctica® Energy...
Side-By-Side GE Fridge Won't Supply Water
Sounds like a frozen line ... press on the inside door lisen to see if there is ice inside defrost the freezer check if water will flow ... if stainless steel door there is a heater kit you can put in... if plastic you will have to replace the door.
Dec 15, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Fridge Not Dispensing water
First place to start is in the fridge. Look behind the crisper drawers for the water tank. It may have frozen at the outlet line. Try thawing it out with a hair dryer or a heat gun, being careful of course not to melt anything.
Dec 13, 2008 | Refrigerators
Frozen water line
GE has a heater kit available. I can email you the sevice bulletin in PDF format and you can se if its something you can do.
Dec 02, 2007 | Hotpoint HSS25GFP Side by Side...
GE GSL25JFPBS Side by Side Refrigerator Logo
87 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Brad Goodale
