Question about Denon AVR-1803 Receiver
Is denon 1356 with active bass. and i want to know the difference between active bass and passive bass.
    Genius:
  • 1,175 Answers
Hi....
A passive bass is a box with a sub-woofer in it.
An active bass is a box like that with an amplifier built in.
Hope that helps.
Check the Denon site too
Posted on Dec 30, 2008
I have a pioneer dxt-x4869bt sterio do I need a certain hook up subwoofers
Unless your Pioneer has a dedicated subwoofer output or output for bass speakers the signal for subwoofers will need to be generated by either a passive or an active crossover from the regular speaker outputs and then the resulting output will probably need boosting by an additional amplifier if a passive subwoofer is to be used. An active subwoofer might not require the additional amplification.
Feb 14, 2016 | Pioneer Car Audio & Video
Fender bass has no sound
that bass has a good electronics package...maybe check the jack wiring?
Feb 23, 2014 | Fender Marcus Miller Signature Jazz Bass 3...
Connecting a passive subwoofer to a denon 2113
you need another reciever/amp to power that sub, because that denon reciever is designed for a powered sub,. if you have another old reciever/amp laying around, you can connect the sub out from the denon into an auxillary input of any old reciever/amp, (switched to that input) with speaker wires from old reciever/amp to the passive sub
Mar 05, 2013 | Denon Avr-2113ci 7.1-channel Home Theater...
What is wrong? my active bass whether i put a new battery in or not sounds passive no change whatsoever. quite a bit of the low end is severely missing. Schecter STARGAZER 5 bass.
That bass combines passive EMG pickups with an active preamp (which provides the bass and treble controls). Sounds like you are never getting the preamp to work, and if that is the case there could be numerous reasons...a dead battery...jack wiring that is broken (meaning the battery ground wire is not attached or is grounding out)...likely should see a tech, but that is a good sounding bass when working correctly.
Feb 07, 2013 | Schecter STARGAZER 5 Bass
HELLO!MY NAME IS KOSTYA SOME QUESTIONS ) BASS STU HAMM URGE 2 HAVE ONLY ACTIV?NOT ACTIV/PASIV? CAN I PLAY AS PASIV??IT S VERY IMPORTANT FOR ME!!))))
If your Bass has Active pickups then it will only work when there is a battery. It will not work without a battery. If you do not want the active pickups then you can have someone swap out your pickups for passive ones. In fact, you can probably get passive pickups for free in exchange for your fancy (expensive) active pickups. Good Luck
Dec 06, 2010 | Fender Artist Series Stu Hamm Urge II Bass...
What potentiometer is being used in rbx 374 bass volume control..because i replaced it with a500 potentiometer but still its not working..i bought yhe bass second hand,,is potentiometers for active pickups...
Yes, active use different value pots than passive. The volume control is LIKELY an "audio taper" which can be either an "A" or a "B" marking as there is confusion about the marking. The resistance is likely around 500K ohms down to as low as 50K ohms. The marking MIGHT be something like 504 B or 503 B or the same with the letter "A".
An A500 pot might be only 50 ohms... That would result in very low output. Again, the marking in the industry is not consistent.
Best bet is to get the part from Yamaha. Go to Yamaha America "parts" dept in California. You can search the phone number with Google.
Oct 10, 2010 | Yamaha Rbx374 4String Electric Bass Guitar
I am building my own speaker for he first time.i have 2 subb woofers/mid and tweeter but only ave three way cross over what would be the best and safest way of wiring up the speakers?
Hi first thing: do you have a passive or active crossover??
  1. Passive crossover: you can connect the two output together to your subwoofer to have in the same time the low bass and the mid range of frequency.
  2. Active crossover: NO solution you have choose one out put of your crossover, i guess the best is the low output, but the choice is in your hand try the the two output(low/mid) once and choose the best for you
Let me know, bye
Apr 22, 2008 | Audio Players & Recorders
Connecting a PASSIVE subwoofer to the denon AVR-1507
Yes on B Connect Left+ Right+ Equals Mono And Turn on B Side with A
Jul 01, 2007 | Denon AVR-1507 Receiver
Denon AVR-1803 Receiver Logo
118 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
