Question about GE WJSR2070B Top Load Washer
Won't spin. ge wjs2070b2ww won't spin.every thing else works. the lid switch checks out ok motor doesn't hum it's like when it's in spin cycle there is no power to the motor. thank for your help. larry
Washer works strongly but when it comes to spinning not work @ all not good 4 my pocket thxs.
Posted on Oct 01, 2011
    President:
  • 1,294 Answers
Your washer obviously has been over-loaded. It trips the spin switch & prevents top-speed spinning. See that you load within the machine's user manual load, not more. You can even weigh your laundry before loading to see that you dont over-load. Also see that the laundry is evenly placed within the bucket. These are suggestions.
Posted on Apr 20, 2007
INDESIT WIB101 WONT SPIN
Have you checked the lid safety switch? Even if it doesn't spin, the cycle timer will continue.
Nov 16, 2013 | Washing Machines
Washer agitates but won't spin or drain - makes a humming/buzzing sound during those cycles
check the pump,could have a sock or something stuck in it.usually i would say to check the lid switch,open and close the lid,if you don't hear a clicking sound the washer won't go into spin or drain but if you're hearing a humming sound that's the motor watch this video
http://www.youtube.com/user/RepairClinic?v=DwV71h86Gxw it will show you how to get to the pump.pop off the two clips that hold the pump on and remove the pump just pull it backwards off of the motor shaft,now get a piece of wire and strip the ends on it,2 to 3 inches long,unplug the washer before you start to work on it,get your jumper wire and stick it into the wire harness that connects to the lid switch, don't plug it into the ground plug it into the other two wires not the green wire,i'm pretty sure it's the two outside wires and the green ground is in the middle,plug the washer back in and pull the timer out in the spin cycle,if the motor runs and spins you know something is stuck in the pump or the pump is bad,but just to make sure it's not the lid switch and it is the pump put the pump back on and start the washer again if you hear the humming it's the pump or before you pull the pump jump out the lid switch and see if it spins and drains,if it doesn't then pull the pump so you don't have to stick the bad pump back on the washer,all the lid switch is for is so the washer will not run in the spin with the lid open and some washers won't even agitate if the lid is open by using the jumper wire we are bypassing the lid switch to check the washer while it's apart.hope this helps and if you can let us know how you make out so if someone else reads this with the same problem it will help them out too.
Mar 13, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
Washer won't agitate or spin
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Sep 07, 2011 | GE Profile WPRE6100G Top Load Washer
GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
GE top loading washing machine (WBSE2090A0WW) stops spinning
it sounds like you know how to remove the frount panal,remove the frount panal.put unit in spin,look to see if belt is turning,if it is not than you have a bad cluch.
Dec 29, 2009 | GE Profile WPRE6100G Top Load Washer
No spin - agitate
You just do this
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drover belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the Agitator
  • Inspect the pump coupling
  • Test the Water switch level
Good luck !!!
Regards
PCmania
Jul 08, 2009 | GE Washing Machines
GE top load washer will drain but not spin
you both need to have the switch replaced or you can open top of washer and combine the lid switches wires together as a bypass and electrical tape
the lid switches are put in the washers to keep kids from opening the washer machine this is automatic shut down
for xenazoe
you require this part for your washer
Part Number: WH12X10065
SWITCH PRESSURE
Apr 01, 2008 | GE WBB4500EWW Top Load Washer
GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Mar 24, 2008 | Washing Machines
Humming noise during spin cycle
Strangely enough, the electronics in the motor drive circuits are quite hardy. Suggest if motor does agitate but not spin, check the motor brushes and see what length and condition they are in.Have had to replace brushes on many occasion.If you have a motor that has a capacitor then check the cap. It could be defective.
Feb 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
GE WJSR2070B Top Load Washer Logo
141 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
