Question about RCA OPAL M4001 MP3 Player
Battery won't hold a charge...
I've been plugging it in and letting it charge but once I unplug the device and try to turn it on, it goes to the "initializing...." screen, blinks then turns off. When it's plugged back into the computer, the battery is completely empty again...
  • addysonbolto
    addysonbolto Dec 26, 2008
    when i go turn it on it says low battery and the it turns off. when i go to plug it in into the computer the screen stays black and in white letters it says low battery and then it turns off.
  • 8,596 Answers
Your problem is probably hardware-related, and will require replacing the player, but you can try this:
Download the latest firmware upgrade from to restore the player. The firmware upgrade file will be on the "Download Upgrades" section of the website.
-Tha Mp3 Doctor
Posted on Dec 28, 2008
My textbook 7p won't turn on
This tablet does t reset with the power button unlike other Android devices. When you hold down the on/off switch, it only drains the battery. If you see the color indicator still charging, allow a full charge.Then, only stay put and pulse the button for a moment quick and let it rest few seconds to try again and again. Only when u see a light coming out of the screen, and I recommend you do this with the power cord on, you hold the power switch down until the rebooting is iniciated. Let go til it is finish and see where the problem is. More likely, like mine, the Settings stop working and needs tune up for the CPU. Never leave an application running when closing your system. With or without internet connection.
Apr 20, 2013 | Tablets & eReaders
Side lx won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Nov 01, 2012 | T-Mobile Cell Phones
Battery light won't change colors, drops to 0% once unplugged
Let the battery completely discharge all they way and let it sit for a day or so. Some times when a battery is new most user do not let it fully charge and then completely drain this causes problems for long use batteries. Then give it a try. It also sounds like your plug your cord that connects to the battery may be faulty. Did you by a different cord with the battery? Or use the one from your old one? If you did. This is a "No No" always buy the cord that come for those battery since they are rated for the particular battery.
Feb 25, 2012 | Fujitsu LifeBook A1110 Notebook
Product: Innovage Digital Photo Keychain Issue: Not holding a charge In a nutshell, the hardware works (I've already used the minicd to load the software, and have even put pictures onto the...
What probably happened is the battery slowly drained on the shelf and its shot. Basically the type of battery in these (and a lot of other devices) can not be left with a very low charge for long periods of time or it degrades them. What happened is the battery just degraded and now cant hold a charge.
Jul 05, 2011 | Computers & Internet
I accidentally left my camera on, and the battery died. Later, when I plugged it in to charge, the charger light just binks orange continuously. The camera won't turn on at all, and I can't get the...
I think the battery was already damaged,a rechargeable battery once you use it,it needs to recharge again so that the battery memory will stay longer.use a new one,regards....
Jul 03, 2011 | Samsung SL102 Digital Camera
It won't turn on and even if i plug it into the computer or a ciagrette lighter nothing happens. it was working perfectly fine when i was using it and now i have absolutely nothing. it kept saying low...
Have you tried pressing and holding the power button for about 8 to 10 seconds? It should go on then off. Then wait a few seconds the turn it on normally. This usually resets the unit.
If this does not work try a hard reset.
Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite data.
Once it gets going update your gps at the Garmin site.
Thanks for using FixYa
Here is a link to the owners manual if needed.
Jun 30, 2011 | Garmin nuvi 1450 GPS Receiver
Has never charged, even after extended time periods - both with car charger and usb. Any tricks I'm missing. I've tried "ejecting" it but it just goes back to showing computer connection....
Sounds like the internal battery won't hold a charge and needs to be replaced. If you're "handy" you could do this yourself, but it's not for the faint of heart, and replacement batteries are available on the Internet. Here's a video that shows the procedure for disassembling and reassembling it to install the replacement:
May 11, 2011 | Garmin nuvi 255W GPS Receiver
Frozen Zune
Turn it on: if it will stay powered up, hold down on the pad, and hold the back button at the same time: This will turn the device off, thus possibly fixing the problem. (for the record, holding up on the pad while pressing back will reboot the device, but I find this sometimes does not want to take, like in the situation you are having)
I may also suggest plugging it into any give USB port, letting it try to charge again, then, when you unplug it, do the reboot or turn off commands as described above.
Hope that this helps: I would think the system is off, since you say it "turned off" on you, and now when you start it up you get the "i need a charge" battery, but knowing how my 80 gig acts sometimes, it may THINK it is shutting of when it is not.
Oct 15, 2008 | Microsoft Zune JS8-00001 Digital Media...
Shows Li-On battery charged when plugged into AC, shuts down when unplugged
Here is a palm article on the battery not holding charge-,/
My battery loses its charge very quickly
Like all Lithium Ion batteries, the battery in your device will eventually wear out. If you charge your device fully but it loses power after a few hours (or sooner), it may be time to replace the internal battery.
Sounds like you already did this. Do you have someone you know who has the same battery you could try? Or try your battery in their device?
Also this site looks good -
Step #11
You can connect it via USB and let it charge that way a little while, then try charging it normally. It's called trickle charging-
Trickle charging
Some Palm devices have the ability to "trickle charge" from a USB port on a PC or Mac. This means that it receives a very small amount of charging from the USB port, even if it is not connected to its AC charger. If your device is capable of this function, the charging time will be significantly longer for a trickle charge (depending on the power rating of the PC USB port). However, the device may not charge at all on an unpowered USB hub (or for example off off a keyboard).
Dec 30, 2007 | HP iPAQ RX3715 Pocket PC
RCA OPAL M4001 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
