Thinkcentre M55 8806 power on off problem
Thinkcentre M55 8806 A72
After the mains power is given to CPU, the PC fan runs fast then slows down and then the fan stays running in a slow speed. The power LED at front panel glows on, but the Start button in front panel of CPU has no response on pressing it. After pressing the button continuously long for atleast 10 sec., the system is forced to poweroff and the Glowing LED gets off. Now again pressing the start button the same thing is repeated, but the system does not boots. After trying this 3 or 4 times, fortunately system boots and runs good. But after shutdown, the LED is still glowing, fan is still running slowly and the above problem is repeated. (If I choose restart option from windows, then there is no trouble and system restarts properly). Please solve.... THANX
  • 1 more comment
  • anwarvety Dec 27, 2008
    Yes sir all the wirings are properly connected. Ram is properly attached. Actually on clicking shutdown button, the windows gets turned off (hard disk gets off) but the power LED is still glowing and the fan is still running (the power to motherboard does'nt gets off). Then I have to keep pressing the start button continuously to force the motherboard shutdown. Now I can't understand, why motherboard is not getting power off automatically. [Is there BIOS disturbance?]
  • mpenre1 Jan 16, 2009
    My machine fan runs on HIGH continuously, but the machine does not boot up. When I hold teh pwoer button for 10 to 15 seconds, the machine powers down, but when I press teh power button, the machine fan comes on in high speed but the machine does not reboot. This is a thinkCenter M51
  • j060403 May 18, 2009
    i have the same problem. it does boot up some time after trying many many times, but end up can't boot.
  • 38 Answers
May be your computer motherboard wires connection get loose or getting moisture in wires. Or there may be some earthing problem in ur power switch. First, check the wires connection & tighten up properly. if problem persists, check the earthing by power tester. Check you RAM if it is properly tight in the jack.
Posted on Dec 26, 2008
  • Jitender Singh Dec 27, 2008
    There may be problem with your power supply i.e inaccuracy in ATX system if it is ATX. pls consult your system administrator to fix the prob.
Why will my fan not run during use but i hear it when the computer powers up?
Fans, mainly the CPU fan, have a speed control which slows the fan down. This is usually controlled by the BIOS. The speed is based on temperature of the CPU. If it's cool with little load the CPU fan will run very slowly and you won't be able to hear it. On startup all fans ramp up to 100% until the BIOS takes over and slows the fan down.
Jul 27, 2014 | Dell Inspiron 531s Desktop Computer
Ibm thinkcentre cpu fan runs on high after shutdown
Open the Control Panel. Power Options, Change/Adjust power off settings, change Sleep and Hibernate to Never, set to High Performance. A reboot everyday will reset your computer.
Jan 18, 2013 | Computers & Internet
When I plug the unit into power, the CPU fan runs very fast but no boot, and then when I press power on the fan slows down and the PC boots normally. It shuts down in about 30 minutes with no sign of...
Sounds like you are overheating. One way to tell if it's overheating is you say it will run for about 30 minutes then shuts down. When it shuts down try rebooting to see if the boots successfully. If it fails to boot successfully right after it shut down then you are probably overheating. If you wait awhile to let it cool down for 30 minutes or so and if you reboot and it does it successfully you definitely have a overheating problem. If I remember correctly all those compaq sr series have loud and fast running fans. Computers overheat because of three reasons for the most part: 1) A fan has stopped working. 2) The Thermal Paste on the CPU and Heat Sink has dried up or is not thick enough to keep the unit cool. 3) Dust has clogged the fan vents and inside the computer. Fortunately for you desktops don't have to be completely disassembled like laptops to get to the fan, CPU and heatsink. Just pop the case and you'll see the components attached to the motherboard
Mar 18, 2012 | HEWLETT-PACKARD Compaq Presario SR5518F...
I have a hp slimline 3100. the cpu fan runs fast everytime i open a program or play a cd. it speeds up the slows down. sometimes it runs really fast, then the computer shuts down. whats going on?
This is an indication of overheating within the PC. Open the PC case and clean all the air vents. Take the heatsink and fan off the CPU and give it them a good clean. Put the heatsink and fan back on to the CPU and start up the PC. check that the fan on the heatsink is running smoothly.
Also, make sure the vents on the power supply are clear and the fan on the power supply runs well.
If you go into the BIOS setup, you may be able to monitor the fan and the CPU temperature.
Mar 18, 2011 | Computers & Internet
The CPU fan on this thing runs like a jet engine..and sounds like one too...all the time, full speed from start up to power down. HELP Please
see if the fan has 3 wires or 4 wires. You are pluggijng into a 3 pin connector? I have had this happen to me and there was one way of plugging the connector intothe header which will slow the fan down. I wish I could remember more, but I know this will work.
Mar 21, 2010 | IBM ThinkCentre M51 PC Desktop
Variable speed fans suddenly slow single speed only.
check with the temperature of the CPU core!
because of over heating the CPU is shutting down or not.
Sep 24, 2009 | IBM Computers & Internet
Computers & Internet Logo
669 people viewed this question
David Payne
David Payne
