Question about HP iPAQ H3835 Pocket PC
Erase ipaq 3835 pocket pc - HP iPAQ H3835 Pocket PC
3 Suggested Answers
SOURCE:
  • 33 Answers
SOURCE: hp ipaq pocket pc 2003 screen broken
If you have the expertise to fix it your self, there are several places you can buy parts, here is one:
http://www.ipaqparts.com/index.html
If you would rather have it repaired, try here (same company):
http://www.ipaqrepair.com/
Posted on Dec 16, 2009
  • 457 Answers
SOURCE: can i use windows vista with my ipaq 3835 pocket
The iPAQ 3835 runs Windows Mobile. While this provides a similar look than Windows for desktop PCs, it is very different under the hood.
I'm sorry, desktop Windows like Windows XP, Vista or 7 will not run on your pocket pc.
In the 3800, and 3900 series 1GB is maximum for the SD card. Any size CF card will work.
Posted on Feb 09, 2010
Can i use windows vista with my ipaq 3835 pocket pc and what is till the memory expandable upto
No, you cannot use Windows Vista on your iPAQ.
I am not 100% sure but, I have seen products made before the whole HD SD cards not being able to use them so, I would stick to the regular SD cards which go to 2GB.
Feb 09, 2010 | HP iPAQ H3835 Pocket PC
Window Vista syncronizing with iPAQ 3835 problem
In order to sync any iPAQ with Windows Vista, you will need to download and install Windows Mobile Device Center 6.1 from http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx.
Activesync will only work for XP Operating Systems and earlier.
Notes
  • To find out whether your version of Windows Vista or Windows 7 is 32-bit or 64-bit, click Start, right-click Computer, and then click Properties. The version is listed after System Type.
  • You can use Windows Mobile Device Center 6.1 only with phones running Windows Mobile 2003 or later. ActiveSync and Windows Mobile Device Center won’t work with Windows Embedded CE 4.2 or 5.0, Pocket PC 2002, or Smartphone 2002 devices. (To see which Windows Mobile operating system you’re using, and if your phone doesn’t have a touch screen, click Start > Settings > About. If your phone has a touch screen, click Start > Settings > System tab > About.) To sync content to any of these devices, you must use a USB or serial cable and your computer’s Internet connection and File Explorer.
  • You must use Microsoft Outlook 2002, Outlook 2003, or Office Outlook 2007 to sync your e-mail, contacts, tasks, and notes from your computer.
  • You must use a USB cable to connect your phone to your computer the first time you use Windows Mobile Device Center to sync.
Jan 11, 2010 | HP iPAQ H3835 Pocket PC
Online with a Compaq iPAQ H3835 Pocket PC
The 3835 did not have WiFi capability so you can't get online. Probably not worth messing with unless you're a real techie. I think there is a distro of Linux that can run on it if you want to play with that.
Nov 08, 2009 | Compaq iPAQ H3830
On IPAQ hx2700, how do I do a hard reset? I want
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
My ipaq 3835 doesn't hold a charge any more, is it possible to change the battery?
It looks like it is possible, here is a kit...
I have no affiliation withthis website...
http://www.batteryship.com/htmlos/htmlos.cgi/batteryship/catalog.html?item=263897-001&model=iPAQ+3835
Hope this helps,
David
If my solution helps, please rate it accordingly.
Mar 16, 2009 | Compaq Computers & Internet
Only works while plugged in
i would say def. its the battery thats dead!
Did a quick search for batteries and found a lot and costs about 10-30$ for a battery
and some include a charger as well.
Worth spending if you gonna use it daily!
Dec 27, 2008 | HP iPAQ H3835 Pocket PC
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Resetting the Device
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
Performing a Soft Reset
A soft reset stops all running applications, but does not erase any
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
To perform a soft reset:
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
2. Use the stylus to lightly press the Reset button.
The Pocket PC restarts and displays the Today screen.
loaded are stored.
functionality.
Oct 16, 2008 | Computers & Internet
3835 charge light
does the pda work fine otherwise just no light when the battery is supposed to be full?
Jul 30, 2008 | HP iPAQ H3835 Pocket PC
Media player 9 on ipaq 2215
A hard reset will get it back for you, but you will lose your data. So either backup first, then restore it. Or sync to PC and back if it's just OUTLOOK data.
Sep 11, 2005 | HP iPAQ H2215 Pocket PC
HP iPAQ H3835 Pocket PC Logo
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
