Question about RCA F32648 32" TV
42" RCA not working
We have a 42" RCA and at first the colors on the screen were really messing up...you could see separate colors on the screen in a sort of curvish pattern. When we blew out the back of the TV the picture came back perfectly normal for a while (couple hours) and then it would go back to the multi color thing. We took out the part in the back that houses all the components and blew that out, reassembled and it worked fine for a little while and now it wont turn on at all. I tried unplugging and replugging...but no luck.
My first thought was that it was overheating or something...but one day it was on all day and the colors were all messed up and then late in the day it just "went" back to normal.
This TV is 12 years old, I hate to just get rid of it if there is a "fix", but I also don't want to spend a bunch of money trying to figure this out.
Thank you.
  • todddana Dec 26, 2008
    We have blown all dust out of the components.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls postback the exact model number. Additionally, when the TV goes dead, does any of the small lights blinks? If yes, is there a sequence or could you possible count. This could possibly indicate the error codes and wouold point to the most likely area where to start diagnosis of fault.
Offhand, it would seem that there are no defective major components, at least during the time that it goes back to normal display. This then could be as you posted a heat related problem or as welcomejee pointed out, possible cold solder or loose connections.
To cut on repairs cost, a DIY (do-it-yourself) has to be considered. To be able to do this would require opening the unit, perform voltage measurements,determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY, perhaps your best bet would then be to seek the services of a qualified professional.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 26, 2008
  • RCA Master
  • 19,396 Answers
The problem is related with tv c be a broken solder joionvergence, it cannt, as already stated, a blown convergence IC, or a different problem
The convergence board must be tested by a technician.
Call the phone number listed on the user manual to get in touch with service support.
    Genius:
  • 1,550 Answers
Your tv is 12 years old it is not worth repairing it . The problem in your tv can be due to :
  • Bad soldering joints in your tv you need to desolder it and once again solder it properly it is going to be tough thing to do .
  • The convergence IC is damaged you need to replace stk392-120 .
  • The degaussing circuit may not be working or magnetism may have been too strong for the internal degaussing to correct.
  • The internal board is damaged . Replacing it will cost you more .
    Genius:
  • 1,913 Answers
Clean dust from all circuit.reaattch all cables .may be there is any trasnitor or capacitor blown out.check on circuit that there are not any blown parts.but first refix all connection then try.also check your power supply waltage and earthing working properly.
    Genius:
  • 1,011 Answers
Sir,
It's most likely a failure of the convergence amp / IC's and some other power supply problem in the convergence circuit by the sounds of it..Not real expensive in a reputable shop - just a pain this time of the year.. I would recommend getting it repaired, it's worth it..
Note: u must identify the ic's nos to be replaced. do u have knowledge in electronics u must do by yourself. if not better contact technician.
thanks
good luck
  • Asfiya Ahamed
    Asfiya Ahamed Dec 26, 2008
    it is a problem with convergence call customer support for more help
  • Asfiya Ahamed
    Try to adjust the converge through manual settings. Check manual for it.
    Menu
    scroll down to Manual Converge
    Choose list of the color settings, go across and then adjust each individual cross so that you can just see one color.
    If u send me the model no. i will send u the manual with link to download(pdf file)
    thanks
    good luck
    President:
  • 2,110 Answers
The cause is one or more shorted transistors either on CRT board or on main or both. The colors are red,blue and green, you have a transistor for each and a bias trans. check each there are 6 in all.
It is better to contact a technician for this..
  • 10,594 Answers
It seems dry / cold solder joints in convergence board in your 42" TV and requires resoldering work.
If you have experience in TV repair then you can do it yourself or get help of local TV Tech.
let me know exact model number to check for detail info.
  • Shahid Electronics
    Shahid Electronics Dec 26, 2008
    Blown an air to remove dust on components is not solution of tv problem.
    as I said, convergence board need to be resold, specially cold solder joints.
    Let me know, do you have prior experience of TV repair? are you familiar with TV repair and have electronics knowledge?
My RCA 42 inch TV turns on but I see nothing but different color lines on the screen and no sound.
Lines on the screen usually is a problem with LVDS board, panel or the ribbon cable to the panel. Set should have audio though. the main board processes both audio and video but will not produce colored lines.
Feb 03, 2015 | RCA L42WD250 42 in. LCD HDTV
Loss Color
I get that there is no Chroma on something but not sure in what mode or source you are speaking about. Sometimes people have trouble due to a setting being wrong or they use a really cheap video cable which can strip the higher frequency Chroma signal off of the Baseband or Composite video signal. Try a higher grade of video cable- video signals at 10MHz bandwidth do not like to go through cheap audio cables. maybe you could clarify the problem more?
Aug 10, 2012 | LG 42 42PT350 42 Plasma TV
My RCA 55 inch DLP HDTV needs the color fixed. It keeps showing purple and green on the screen
color wheel is getting ready to fail which is causing the color wheel to spin slower which cause the index speed to be off so the tints will be messed up.
Aug 22, 2011 | RCA Televison & Video
We moved the tv and now the color is messed up
Please give better details on messed up?? Thanks
Feb 28, 2011 | RCA L42WD250 42 in. LCD HDTV
I need to set up my TV (without HDMI), amplifier, dvd recorder and Skybox so that I get the best sound - so using the amplifer.I really need a diagramatic picture
No diagram needed: just connect the video RCA connector (yellow) from the player and the box to the tv using 2 separate cable plugged in separate AV entries, and the audio RCA connectors (white and red)  using 2 separate audio cables to 2 RCA joiners like http://www.amazon.co.uk/Euronetwork-RCA-phono-adaptor-Gold/dp/B000ENC20E
and plug those in the audio connectors of the amplifiers - keep the same color all the way.
Jul 24, 2010 | Yamaha Televison & Video
Color separates and picture bows on 9 year old RCA big screen.
Hi, This is a convergence problem and you can set it right by changing the STKs. It is a professional job and i have knowledge of people who ruined their tv by spoiling some miniature surface mounted components close by. You may need to look at pico fuses too. I would say seeek professional help if you not comfortable working with electronics. Check out at www.fixurtvs.com,
Mar 02, 2010 | Toshiba 55H70 55" Rear Projection...
RCA 27R410T Television colors are distorted
If you`re talking about colored spots in the screen, then you may have a degauss problem. It was frequent for those sets to have bad solder joint on the degaussing coil connector or thermistor next to it.If you`re handy with a soldering iron these connections would be near the a.c line input. good luck and don`t forget to unplug
Nov 01, 2009 | RCA 27R410T 27" TV
My rca big screen hdtv's screen is messed up
it is the convergence.normally can be fixed by replacing a fuse
May 29, 2009 | RCA R52WM24 52" HDTV Projection Television
Half Screen has colored lines, Half screen is working ok
there is a defected capacitor in the vertical circuit trouble shoot and replace. or if the vertical circuit is separate then replace the whole board.good luck
Jul 11, 2008 | LG 42PX5D 42 in. Plasma HDTV
RCA P52830BL picture is bowed and colors separated.
There is a convergence printed circuit board that likely has a few bad components. If you decide to get it repaired, the technican will probably check for fluid leaks from the picture tubes coolant area which has given problems on this model also. If the picture quality leaves a bit to be desired, it may be a wise move to upgrade to HDTV. A Sony KDS-55A20 model has a great picture and should be less than $2300. I just saw one at a local Sams Club store.
Mar 12, 2007 | RCA P52830BL 52" Rear Projection...
RCA F32648 32" TV Logo
16 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
