Question about Sony STR-DB940 Receiver
Sony STR-DB940 has no output
Gutted!! My beloved amp suddenly decided to stop making any noise :-(
When i turn it on, the mute and volume indicator (red LED on volume dial) flash for around 5 seconds, then it stopps and appears to be ok. No sound though!?!
I pressed a few buttons and the flashing started again, then stopped. I changed mode, (input selector) and the same again. No sound from it at all.
When i turn it off, the mute and volume indicator keep flashing, then just stay on. I had to turn it off at the mains to get them to go off...
I've tried leaving it off under the A/C for a few hours incase it had over heated diring a particularly hot day, no diffence.
Any advice or even a solution or diagnosis would be gratefully received
Thanks
Tom
  • fatboy14 Jan 15, 2009
    Have the same problem for the 2nd time. First time it was repaired under guarentee by Sony in The Netherlands and was returned without a report. I live in Spain now and have the problem again. Brought the receiver to an authorized Sony Repair Center. They claimed the digital module (top middle board) is defective and should be replaced for around 350 euro. Did not go for it 'cause you can buy a good new one for that price or for less a second hand DB940 for spare parts.
SOURCE: Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Regards
Darryl.
Posted on Mar 13, 2008
jango2
  • 38 Answers
SOURCE: need help
Have you connected an extra pair of speakers?. (Thereby loading the amp stage beyond it's capacity)
Are the speakers connected to the unit the original ones the system came with or different? ( Speaker impedance, usually displayed at the back of the speaker cabinet must not be less than amp's specifications....6 ohms, 8 ohms)
If you're driving the unit excessively you're lucky this piece is equipped with protect mode, else your speakers and amp would have been fried by now.
One last possibility comes to mind: High volume causes vibration causing loosely fitted mains plug to rattle in wall socket calling "protect" due to improper feed voltage. Move the unit to another wall socket and ensure a tight fit into mains receptacle.
Posted on May 20, 2008
  • 15 Answers
SOURCE: Sony amp str-db940 - protection
Somewhere in your speaker wiring, you have a shorted wire. This short can be as simple as a single strand of wire touching the other terminal on one of the speakers.
With a bright flashlight, look carefully at the back of the receiver and then the speakers for any loose strands.
Posted on May 27, 2008
SOURCE: Sony FD Trinitron WEGA Tv KV32FQ86E two flashing led
Check 470 uF 450 V in the power supply. I don't know if the chassis is the AE-5, but I had a similar case and the capacitor was bad.
Please tell me if it worked.
e-mail: jlopes.electronica@sapo.pt
Posted on Jan 22, 2009
  • 4234 Answers
SOURCE: SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Posted on Mar 19, 2009
Volume is gone (except for a clicking noise)
Check whether the mute function is ON or not. If not, the muting section circuit inside has the fault.
Jan 22, 2013 | Sony KV-27V55 27" TV
Rear speakers L and R not working and MD in and out not working on my Sony STR-DB940
I'm guessing these are separate issues.
Has either one ever worked and stopped suddenly?
From the manual:
"No sound or only a very low level sound is heard from the rear speakers.
>>> Make sure the sound field function is on (press SOUND FIELD - MODE).
>>> Select a sound field containing the word "cinema" or "virtual" (see page 33-35).
>>> Adjust the speaker volume (see page 72).
>>> Make sure the rear speaker size parameter is set to either SMALL or LARGE (see page 20)."
Be advised that using any Tape Monitor loop (that's what the MD/DAT is) disables any digital sources. Not that that would explain the rear speaker failure. Analog sources can still be processed into various surround modes.
Any Tape Monitor use requires at least a live INPUT to hear anything.
May 29, 2010 | Sony STR-DB940 Receiver
Hello,When the amp is turned on there is no sound the amp has been fine up until now what should i check?
I have the same problem. Over the night the sound disappeared. It happens on all the inputs(analog/digital) and with speakers/headphones. The digital signal is correctly detected and all the 'clicks' are like before when turning the amp on. Switching to direct mode does not help. Is there schematics available somewhere? I suppose it's some output related soldering which has come loose. If only I knew where to look, or point a local service guy to right direction...
Dec 15, 2009 | Sony STR-DB940 Receiver
Sony STR-DB940 Receiver Speaker Impedance Question
Whats the rating on the Plasma? How many watts at 4 ohms? If the plasma is rated 100 w at 8 ohm... hanging a 3.4 ohm load would put a lot of strain on the plasma's output amp. At 3.4 ohm the amp would be trying to delive close to 200 watts at full power. But it depends on how hot you normally run the volumn. Remember an amplifier output is AC volts. 1 ohm of resistance is close to a dead short. The amplifier would have to work its *** off to supply that type of power and would probably burn the output op-amps. If the outputs burn & it pumps any DC current through the speaker wire..the speakers would be toast...if not catch on fire. Try to keep the speaker load at or very cloe to the plasma's output load rating. Also if the plasma doesn't state it will handle loads down to 2 ohms...It probably won't.
Gene
Mar 02, 2009 | Sony STR-DB940 Receiver
Sony str-db940
Most likely a cold solder joint somewhere in the audio circuit. Most likely on the legs of the relay that turns the speakers on or off. Also check the connections at the audio outputs. Give it a good look over for bad solder connections, given the symptoms that's 98% likely to be the problem.
Oct 06, 2008 | Sony STR-DB940 Receiver
May 27, 2008 | Sony STR-DB940 Receiver
No Sound?
yes !! it should be some kind of circuit breaker , if system detects overload ,it simply disconnect the outputs , should automatically restore the sound , when you turn it off and on again , thats in most cases , oh !! check also the main speakers ,they have internal fuse as well , at least the expensive ones , like INFINITY . HOPE THIS HELPS
Apr 29, 2008 | Sony STR-DB940 Receiver
Sony STR-DB940 Receiver Logo
257 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
