Question about Whirlpool RBD245PD Electric Double Oven
Range is not working
This range is somewhat old and recently, I cleaned it. There was something on the coil so I had unscrewed it from the back of the oven to have the ability to get under the coil. Then, I turned the oven on to soften the plastic that had melted on the coil and scraped it off when it was warm. I turned the oven off, but while cleaning it, I heard a pop and saw a small spark. Since this incident, the oven has not worked in any way. The fan, top coils, top oven, and bottom oven are all dead. What do you think is the problem? Thank you, Tracy Long
    President:
  • 1,462 Answers
I know it sounds obvious but have you checked you oven fuse or circuit breaker - ie in your fuse box?
Posted on Apr 17, 2007
Why does the oven time flash but the oven won't turn on?
power to the unit by removing one or more fuses or tripping one or more breakers at the main entrance panel or at a separate panel. If the range is fused at a separate panel, this panel may be located adjacent to the main panel or in a basement, crawl space, or other location. If there is a grounding wire to the range, disconnect it. Make sure the power to the unit is off.
Servicing FusesIf the range or oven is receiving power but doesn't work, the unit may have its own fuse or circuit breaker assembly. This assembly is usually located under the cooktop of the range. In some units, lift the top of the range to gain access to the fuse assembly; or lift the elements, remove the drip pans, and look on the sides of the cabinets. Inside the oven, look to the back to spot the fuse assembly.
If the unit has this additional fuse or breaker system, components such as the oven light, the range heating elements, the timer, and a self-cleaning feature may be separately fused.
If these components or features fail to work, don't overlook the possibility that the fuses have blown. To replace a blown fuse, unscrew the old fuse and install a new one of the same type and electrical rating. If the unit has circuit breakers, push the breaker or reset button, which is usually located on the control panel.
May 09, 2015 | Ovens
I have a whirlpool range rf263lxtq the oven stays consent on what is wrong with it
Oven clicks as if it is relighting almost constantly.
· Old electric range ovens use a coil heating element called a resistive coil.
This is nothing more than an electrical wire encased in a sheath. They have flat black coils over rounded burner drip bowls that catch your drips and spills.
· The newer glass-ceramic cook top style element produces heat that radiates through the glass top to the cookware above.
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Feb 15, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Hey my oven wont turn on, the burners work tho can you help me please?
Check for the correct voltage at the receptacle behind the range where you plug the range power cord in, you should have 220 volts
at the receptacle, it is somewhat common for wires to burn in two at that point.Also, check for the correct voltage at the terminal block on the back of the range where the cord wires onto the range, look for burnt wires there also.
Don't forget to double check that your circuit breakers or fuses are good.
GOOD LUCK !
Aug 19, 2010 | Magic Chef Ovens
I have an older Frigidaire range model # RGC-32 BA. This past week, the lower element inside the oven stopped working. Can I order the element separately and are there any "tricks" to removing the old one...
do an ohm's test on the element if it reads around 25 ohms it's ok, might just be the connecting wire itself, look for charring on the wire connected to the element.if the element reads open then it's bad.
you will need to unscrew the terminals that hold the wires on. unscrew the element from inside the oven.
replace by reversing the proceedure.
Jun 21, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
"Door Lock" LED flashing
that means you have door or lock problem may be the door latch failed after the oven self-cleaned,the heat might have blown a thermal overload fuse.first unplug the range and check the wires and connectors between the control and the door switch for damage. if they are okay , pull the range out and remove the back panel. check for the small gear motor that controls the latch and rotate it to unlock the door. . In the open back panel, look to your 10 o'clock position for a round part about the size of a quarter fastened with two screws. You can find out if this is your problem by unscrewing the fuse and taking the wires out, then joining the two wires together. Plug in the oven and see if the led disappears and the door lock works again. If it works, that fuse was your problem. if not then its the door hinge but be careful when doing this,to avoid more damage to the oven
Jan 09, 2010 | Whirlpool AKZ159IX Oven
My oven is two years old and the bottom oven coil will not heat up. The top one works just fine but not the bottom.
you may have a burned out bake element even if the range is only a couple of years old. if you can see the element look for a burned area. if you can't see it you will need to unplug the range and see how to get it out yourself or call a repair service. hope this helps.
Oct 13, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Kenmore Elite Freestanding Electric Range - Cooktop not working
Your stove probably requires a separate 20A circuit with 12 ga. wire.
May 19, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
Where are my fuses located?
From http://home.howstuffworks.com/how-to-repair-an-oven3.htm Servicing Fuses If the range or oven is receiving power but doesn't work, the unit may have its own fuse or circuit breaker assembly. This assembly is usually located under the cooktop of the range. In some units, lift the top of the range to gain access to the fuse assembly; or lift the elements, remove the drip pans, and look on the sides of the cabinets. Inside the oven, look to the back to spot the fuse assembly. Electric Oven Troubleshooting Guide There are a myriad of problems that can cause your electric range or oven to malfunction. Click here for instructions on how to deal with specific issues. If the unit has this additional fuse or breaker system, components such as the oven light, the range heating elements, the timer, and a self-cleaning feature may be separately fused. If these components or features fail to work, don't overlook the possibility that the fuses have blown. To replace a blown fuse, unscrew the old fuse and install a new one of the same type and electrical rating. If the unit has circuit breakers, push the breaker or reset button, which is usually located on the control panel.
Jun 10, 2009 | Ovens
Oven shut down
hi If the range or oven is receiving power but doesn't work, the unit may have its own fuse or circuit breaker assembly. This assembly is usually located under the cooktop of the range. In some units, lift the top of the range to gain access to the fuse assembly; or lift the elements, remove the drip pans, and look on the sides of the cabinets. Inside the oven, look to the back to spot the fuse assembly.
thank u........
Sep 12, 2008 | Ovens
Whirlpool RBD245PD Electric Double Oven Logo
61 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
