Question about D-Link AirPlus G DWL-G710 Wireless Range Extender
DWL-G710 keeps disconnection from router
I am using the D-Link DWL-G710 for quiet a while now, and everything was working just fine. But somehow for now appearent reason the repeater does not connect to the router anymore. Even if they are just inches appart and no encryption is enabled.
I do not think this is a setup issue, since it was working before. There is no later firmware available and I realy dont know what to do.
Is there any help/hint/tipp/link/anything?
I'd very much appreciate it!!
cherio Woltan
  • Angelbert Mellores
    Angelbert Mellores May 11, 2010
    If you are still able to access the GUI of the range extender that should still be fine, have you tried to reconfigure the wireless settings of the router and the range extender like channel, ssid and enable the encryption.
  • 21 Answers
Sounds like it isn't working anymore.
try resetting it and configuring it again with the network cable
Posted on Nov 05, 2009
Range Extender DWL-G710 & Wireless N Router DIR-615
Try to configure your new router and you have to reconfigure the Range extender to tally with the new router. The IP Address that the range extender should have should depend on the DHCP server of your router that provides the IP Address.
Jan 12, 2010 | D-Link AirPlus G DWL-G710 Wireless Range...
DWL-G710 won't connect to 192.168.0.30
Here is a link to the manual for your DWL-G710.
D-Link manual on page 13 it lists the url entry should be
"http://192.168.0.30" This is a HTTP link not a HTTPS.
Also the address you typed in might be a typo. The IP address should be 192.168.0.30 not 192.168.0.30.
GOOD LUCK!!!!
Oct 18, 2009 | D-Link AirPlus G Wireless Range Extender...
Can't access the internet. No problem with the static IP address and setting up the DWL G710. Searched and found 2 AP's for my wireless account. Selected one and saved. Got indication that DWL G710 was...
Is there any particular reason you're using a static IP? Most routers are set up already for DHCP.
If you need to use a static IP, make sure you have the right settings for the default gateway and DNS servers (you'll have to contact your ISP to find out the addresses for the DNS servers).
I would recommend switching to DHCP though, and you won't have to worry about such settings.
Aug 02, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
No internet connection via DWL-G710
Your extender may not be able to talk to the router. Make sure you have set default gateway in extender to IP of the router. Turn off encryption first. Check the router if extender shows up in active client list or active mac address list.
Oct 18, 2008 | D-Link AirPlus G DWL-G710 Wireless Range...
Can a dlink dwl g710 range extender work like an acess point
hi, i think there is no chance to make an AP from range extender because it is ONLY RANGE EXTENDER so you need another device to work as AP.
Jul 13, 2008 | D-Link AirPlus G DWL-G710 Wireless Range...
Comm problem between range extender and BT home hub
make sure the SSID, channel & wireless key on router & all extenders are the same, also the default gateway on the extender has to be the IP address of the router.
Nov 27, 2007 | D-Link AirPlus G Wireless Range Extender...
DWL-G710 and DWL-700AP compatibily problem
when using the AP you have to make sure you set the SSID, channel & wireless key in the AP the exact same as the router and make sure when configuring the Ap that you set the default gateway as the IP address of the router.
Nov 03, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
D-Link AirPlus G DWL-G710 WIRELESS EXTENDER
the IP address must be different on the router & extender but use the same subnet mast. The extender has to have the gateway set as the IP address on the router.
Sep 16, 2007 | D-Link AirPlus G Wireless Range Extender...
LAN problems with the router
Are you using the correct cable type. If it is a CAT5 type cable it could be you are using a patch cable rather than a straight through type or vise versa.
May 23, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
DWL-G710
Move the repeater directly next to the router, connect to the repeater with a laptop/desktop and enter the configuration utility, see if you are even able to establish a "signal" status. If not, you may have a defective product or extreme amounts of emi.
May 03, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
D-Link AirPlus G DWL-G710 Wireless Range Extender Logo
503 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
