Question about Nintendo Wii Console
I want to change names on nintendo wii
Help.
i want to change names on nintendo wii
  • 903 Answers
Http://www.nintendo.com/consumer/downloads/WiiChEng.pdf
go here for the manual download and go to page 24 for renaming (nicknaming) the wii or download the manual (it is in pdf format) it will have all the information you need for all the settings on your wii and it is a free download.
I hope this helps
Posted on Dec 26, 2008
What is the ssid #
How to Locate a Router's SSID and SSID Broadcast Setting
Applies to: Wii U Deluxe, Wii U Basic, Wii, New Nintendo 3DS, New Nintendo 3DS XL, Nintendo 3DS, Nintendo 3DS XL, Nintendo 2DS, Nintendo DSi, Nintendo DSi XL, Nintendo DS, Nintendo DS Lite
Published ' Updated --> Step by step instructions on how to locate your router's SSID and broadcast settings.
Note:
Was your router provided by your Internet service provider? If so, before continuing check for a sticker on the bottom or side of the router that has the default SSID printed out. This is usually labeled as the SSID or "Network Name" and may be located next to a barcode.
What to Do:
  1. Log in to your router's settings. How to
  2. Search through your router for phrases such as SSID or Wireless Network Name. The terms and locations can change from router to router. Below are examples for common router brands:
    • D-Link:
      You can typically find the SSID by selecting the "Setup" option, and then "Wireless Settings."
      Enable SSID broadcast by selecting "Visible" for the "Visibility Status."
    • Netgear:
      You can typically find the SSID by selecting the "Basic" settings option, and then selecting "Wireless Settings." The SSID may be labeled as "Wireless Network Name."
      The option to enable SSID Broadcast is often located by selecting "Wireless Settings" under the "Advanced" settings.
    • Belkin:
      You can typically find SSID by selecting the "Wireless" tab and then selecting the "Channel and SSID" option.
      The option to enable SSID broadcast is located here as well.
    • Linksys:
      You can typically find the Network Name (SSID) by choosing the "Wireless" tab, and then "Basic Wireless Settings."
      The option to enable SSID broadcast here as well
If you require additional assistance locating your router's SSID settings, please refer to your router manual
Oct 07, 2015 | Nintendo Wii Console
Tip
Reset your Wii Video Settings to the Default
One annoying thing about the Nintendo Wii is that there is no way to reset the video settings once you have changed them in the Nintendo Wii System Menu.
It will not detect which cables you are trying to use and just tries to use the last settings that you set it to.
So, if you have changed your Nintendo Wii from using the regular cables that came with the system to using component cables, then switch back to a TV using regular RCA cables (these are the yellow, red and white cables) then you need to reset the settings on your Nintendo Wii to the default video settings.
You can reset your Nintendo Wii video settings to use Composite (or RCA - Yellow, Red and White) cables by doing the following:
1. Make sure the Nintendo Wii is powered off and a red light is showing.
2. With the power off, unplug the video cables from the back of the Nintendo Wii, leave them plugged into your TV (these should be the RCA/Composite cables)
3. Press the Power button on the front of Nintendo Wii. Make sure the cables are still unplugged.
4. Keep the Nintendo Wii powered on and plug your cables back into it with it still running.
5. If all went well, the picture should appear normally now.
6. Once the picture has reappeared, you should go into the Nintendo Wii Menu (the Wii button in the bottom left hand corner) and change the display back to 480i to make the changes permanent.
I hope this tip helps!
on Apr 09, 2010 | Video Game Consoles & Games
How to connect wifi to my wii?
First be sure you have removed the old connections setting from the Wii, then set up the new info In the Wii. That will typically work.
Jul 22, 2014 | Nintendo Wii Console
I can not connent to netflix via my wii gives me an error 51330
According to Nintendo's website, it lists this particular error code as not being connected to your network. Please reference this troubleshooting guide here for verifying your wireless network name and password.
http://www.nintendo.com/consumer/systems/wii/en_na/onlineErrorCodes.jsp
Sep 06, 2011 | Nintendo Video Game Consoles & Games
Cannnot connect to the internet error 50300 0n tv screen?
Hi.
It appears that your Wii console's Internet connection may be affected by wireless interference.
Try the following:
1) The Wii console's internet connection settings are not correct. This could include your network name (SSID), WEP or WPA keys, or any manual settings you may have entered.
2) It's possible something has changed since you last connected online with your Wii console. Try setting up a new connection file, using your router's settings.
3) While "Search for an Access Point" is the easiest and recommended connection type, your network may require you to use the "Manual Setup" option. Click on the link below for help
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
If the problem persists then please click on the below link to troubleshoot any problems.
http://www.nintendo.com/consumer/systems/wii/en_na/onlineWirelessRouterTroubleshooting.jsp
Good luck.
Jun 09, 2011 | Nintendo Wii Console
Recently secured wireless network with a new name and password. Can't get on Netflix now.
You need to go into your network settings for your Wii and change your Wifi network settings to reflect the new name and password. Your WIi is looking for a Wireless router named whatever you used to call it and not finding it.
Apr 29, 2011 | Nintendo Wii Console
How do you add a new player to Band Hero?
Options>Online Settings>Change Online Name
Mar 10, 2010 | Nintendo Rock Band for Wii
How to identify security type on my belkin wireless router relative to nintendo wii security type options
For nintendo wii , you can use the security WEP or WPA ( PSK ).
These 2 security types will works with WII. If you put WEP,then 10 digit number will be the security code.
To change the security on the wireless network, you will need to open the set up page of the router.
Once you change the security on the router, it is recommended that you will change the wireless network name SSID. after changing the wireless settings , you will need to connect to the new wireless network on all your wireless devices like laptop , wii.
Click Here for step by step instructions
Mar 05, 2010 | Belkin Computers & Internet
Nintendo ds + wii+ wireless router help
On the router do you have a password? If you have a password on the Router along with the router name then in the setting setup for the Wii you will need to go into the network setup and configure the settings just as you have them on the router. For Example: If the router name is netgear and the password is abc123456789 then in the setting for the Wii you need to put in netgear and the password abc123456789
Mar 11, 2009 | Nintendo DS Lite Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
