Question about Siemens 24 in. SE64A630GB Built-In Dishwasher
How do I start my Siemens se65t371eu dishwasher?
I can't stop my Siemens SE65T371EU dishwasher. I was not given the manuel and I don't know which combination of buttons to press to start it. Even worse when I do press the right combination it takes 5-10 mins to start so I don't know its right until 5-10 mins later.
Please can somebody help me! Does anybody know how to start this dishwasher?
  • mandidabbagh Dec 26, 2008
    I can't start* my siemens...
3 Suggested Answers
  • 4 Answers
SOURCE: SIEMENS SE64630GB NOT TAKING IN WATER
I know sounds stupid, but I must ask: Are the water supply valves turned on? Is the water supply pressure good?
A pump usually isn't found on the inlet side. Most such appliances have sediment screens located in the water inlet connections. These will sometimes get blocked with sediment such as lime, for example. Otherwise, you may have a defective controller or defective solenoid. Most units have two solenoids (hot & cold). The solenoids are located at the water inlet hookup (the screen is usually a part of the solenoid). When the washer is started, a metallic click should be heard from the solenoids. Beyond checking the screens and water valves, a repairman should be called in, unless you're skilled with a voltmeter, electrical troubleshooting, and appliance disassembly.
BTW- is this a new installation or has the unit been in service for awhile?
Good luck.
Posted on Apr 13, 2008
danekeeper12
  • 6 Answers
  • hot water valve selinoid and cold water selinoid valve are magnetily operated valves located in the lower part of the dishwasher that need electricity-----
  • wire loose?
  • kinked supply hoses and
  • my favorite is the valve at the kitchen sink angle stop is lying to you, indicates open but is really still shut (broken valve stem) or it has corroded shut .
Posted on Aug 15, 2008
Siemans lady130 dishwasher dont have manuel.how does it work
C'mon Juanita!
Many free sources of operating manuals via search engines!
Give us a tough one! ??
Oct 24, 2016 | Siemens Dishwashers
Error code E:14 Siemens Dishwasher - stops after 1 min of cycle
It might be helpful if you provide the full model number of the Siemens dishwasher. Most likely E14 error has something to do with water flow sensing. Check if your mains water pressure is ok (tap under sink is fully open). But can provide more details only if you can tell me the model number.
Apr 03, 2014 | Siemens Dishwashers
Dishwasher leak
It is difficult to see properly from the video but it appears that the fitting under the tap is the sort used on copper lines that have a flair inside the nut that fits on a taper on the tap.. Have you tried tightening the nut. or remove the hose and see what is causing it to leak.
Jun 10, 2013 | Dishwashers
Siemens dishwasher has stopped taking in water red light on indicating this problem, I have checked water supply that's ok
Click this link for tips : Inlet valve
Check the voltage to the valve to confirm that the control panel is working,
Jan 24, 2013 | Siemens Dishwashers
I need a manual for dishwasher sf25a060gb/08 Siemans
Can you see a model name or number on the dishwasher? if so, we can get you a copy of the manual online. K
Jun 10, 2009 | Siemens Dishwashers
Siemens dishwasher
My siemense dishwasher (2 month old) stopped working
No matter which program I choose, after 1 min the program stops and I get "tap" symbol on the led display.
Instructions says it might be a problem with the water source but i checked and it is fine.
ideas?
Aug 17, 2008 | Siemens 24 in. SE25T250 Free-Standing...
  • wire loose?
Aug 14, 2008 | Siemens 24 in. SE64A630GB Built-In...
Good luck.
Apr 13, 2008 | Siemens 24 in. SE64A630GB Built-In...
Siemens 24 in. SE64A630GB Built-In Dishwasher Logo
109 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
