Question about Sony (ICSSP20) TV Input
I cannot make my wii to work on my Sony tv
My TV is a Sony Advanced 100Hz Digital Plus NICAM and I have lost the instruction manual.When I plug the Wii AV input cable into one of then TV input sockets on the back of the TV the Wii Menu Screen does not appear.As I don't have the TV manual it is not clear which socket I should use although my VCR seems to work whichever socket it is plugged into.
    Genius:
  • 1,466 Answers
Some newer hdtvs use the green rca in the back for both a/v and component. Usually it has green with a touch of yellow on rca input itself. Then plug in audio to red and white.
Posted on Oct 06, 2017
J4XXN
  • 182 Answers
SOURCE: Source list for Samsung LCD TV when hooking up PS3
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option. hope this helps
Posted on Jan 08, 2008
welcomejee
  • 10594 Answers
SOURCE: Default to channel 3
I would strongly recomend to contact nearest Sony repair shop because your TV has hardware problem and it needs qualified service technician.
Posted on Jun 12, 2008
  • 237 Answers
SOURCE: We hooked up a new
Hi, I am sorry, I had to leave. You are okay to go to another guide without added fees. Good luck with your problem!
Posted on Jan 01, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Green screen with sound from cable, but picture is fine with Wii
That would be my solution. The trouble is either in the box or your connecting cables. Verify this by connecting the cable directly to the set. Then try a new set of connecting cables, or call the cable provider to replace the box.
Posted on Feb 08, 2009
  • 147 Answers
SOURCE: dvd/vcr hook up to sony tv, not playing picture on sony tv
The simplest is Video out an the DVD to Video in on TV, Yellow, red and white. If the TV has component input this is better. That is Green, blue and red for the video plus red and white for the audio.
Posted on Apr 02, 2009
Mono stereo function
Tv Speaker; Stereo/dual Reception; Nicam Reception ...
www.manualslib.com > ... > Flat Panel TV > 141K TX > Owner's manual
LG 141K TX) Manual Online: Tv Speaker, Stereo/dual Reception, Nicam ... Stereo. Dual. Mono Sound Selection. In stereo reception if the stereo signal is weak, ...
Video Mode; Audio Mode; Still; Stereo/mono - ManualsLib
www.manualslib.com > ... > LCD-32CA9S > Owner's manual
Dec 21, 2015 | Televison & Video
Tip
How to set 100hz or Motionflow/Trumotion Effect on Panasonic 42X20 Plasma or...
To those who want to have the Motionflow/Trumotion effect on this Plasma Flat Panel TV or similar models, do the following:
1. Set your media player / source (PS3, Xbox 360, Western Digital Media player, Apple TV, etc) at 720p@50hz / 1080i@50hz / 1080p@50hz.
Note: not all player supports 50hz read your source manual if your source/media player can support 50hz
2. Go to the TV's menu and select Setup
3. Select Other Settings
4. You will be able to change refresh rate to 100hz for a Motionflow/Trumotion effect that they have on LCD/LED (if you don't see the 100hz setting that means your source is at 60hz not 50hz)
Note: 100hz refresh rate is different from 600hz subfield drive.
on Mar 26, 2011 | Televison & Video
Tuning instuctions for old Hitachi Opus Nicam TV
Click here to downlaod the manual. It will have all details.
Apr 06, 2012 | Televison & Video
I have a samsung 6 series led tv which says it plays at 100hz, however on screen it only ever says its playing at 50Hz. How do i get it to run at 100Hz?
120 hz and 60 hz any ways heres the thing it is running in a 120hz but its always going to say 60hz because its not a true 120hz your tv is upscaling it to 120hz its called auto motion plus you can adjust it under settings but it will always say 60 hz never 120hz cause it dosent do it true you can call samsung or read the forums at cnet.com i have the same t.v. just the 46 in samsung and sony are very shady in the way they word things
Jan 06, 2011 | Televison & Video
I don't have the tv manual
Please intimate exact model number of your Sony TV to look for instruction manual copy.
Jun 05, 2009 | Sony Televison & Video
Tuning Probleme for an 90's Nicam Toshiba T.V.
after you hook it up to the input, you have to look on the front at the buttons, there should be an input button, hit that untill you get the picture
Jan 08, 2009 | Toshiba 42H81 42" Rear Projection...
Old Sony Triniton KV-M2 with no instructions how to tune in Wii?
HI,TV MUST HAVE A SCRAT SCOKET IN BACK?,OR THE WI WOULD WORK ON AV SETTING ON SET ,OR GO THROUGH CHANNELS WITH WI ON AND IT SHOULD WORK,THANKS
Jan 02, 2009 | Televison & Video
Reddish screen on sony wega kv-28fx68 100hz trinitron
it sounds like a b+ cap going bad and is intermittant that feeds the the video drivers on the crt pcb or the crt is shorting.
Oct 14, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv stuck in standby
If you can not turn on TV set with the power button on the TV its not a standby problem as this would by pass the standby. Theres most likly, on a set of this age, top have a poiwer regulator problem and is going to need a trained tech to assist you in this repair.
Sep 10, 2006 | Sony KV-32S42 32" TV
Sony (ICSSP20) TV Input Logo
1,952 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
