Question about InFocus LP70+ Multimedia Projector
Projector powers on but no picture.
My Infocus LP70 and LP530 projector powers on but there is no picture. Initially when I plug in the projector the green light is on, so I press the power button. I could hear the fan come on but no picture. Then the green light turns to a blinking green light. The bulb is brand new. What else can it be?
  • 8 more comments
  • Stephen Chan Apr 17, 2007
    After a few minutes the green blinking light turns into a orange blinking light. Overheating?
  • Anonymous Nov 15, 2007
    I plug my infocus L70 in, the amber light is steady. I press the power button to turn on & the light turns to a steady green. There is no lamp or projected image at all. Then after about 15 seconds, the steady green light begins to blink off & on. Then, after another 20-30 seconds, the light goes steady again. This repeats over & over again. The fans run continously & you can hear a faint, soft clicking sound when the green light goes from steady to blinking of & on. Any ideas?? I am thinking the lamp is bad but, I know nothing about these & I hate to spend big bucks on a replacement lamp, only to find it still doesn't project an image. TY in advance!
  • Anonymous Feb 08, 2008
    I have the exact same problem. The projector worked fine 2 days ago and tonight I went to turn it on and the light changed from orange to green steady. YOu could hear the fan turn on and everything seemed normal, but then there is a click and the light changed to green flashing.
    Help me!!
  • jaylen710 Apr 09, 2008
    When power on projector shows start-up screen: "InFocus The Worldwide Leader in Digital Projection" Does not show computer desktop, or other information from computer.
  • Anonymous Apr 24, 2008
    The projector light is brand new but there is no picture at all . And it isn t overheated and the power light keeps blinking i dont know what else to do.And
  • strach Jul 02, 2008
    Mine will power up, fan runs, light comes on but I cannot get a welcome screen or menu to come up just a white screen. Also all my status lights are as they should be. Help !
  • jaycarter Jul 28, 2008
    My Infocus LP70 projector powers on but there is no picture.
    Initially when I plug in the projector the amber light is on, so I
    press the power button. I could hear the fan come on, thelight inside from the bulb comes on, but the picture is too dim to show on the screen.
    new. I tried another lamp, same thing. What part do I need?
  • benhan Aug 26, 2008
    This seems to be a common problem. I just bought an InFocus LP70 secondhand and the first time it went fine but now when I push the power button, the LED lights green, the fans go but the lamp won't light. The unit then cycles from solid green LED to blinking green LED every 15-20 seconds. And yes, there's that faint clicking noise like a relay switch when it goes from blinking green to solid green and vice versa.
    Sometimes I hear the DLP wheel start to spin up (high pitched noise like a fan powering up that gets higher and higher) and the bulb lights then it goes back to sleep again a few seconds later (high pitched squeak comes down in pitch then stops as the DLP wheel stops). Other times it struggles like this for a whle then just comes on and everything seems fine (except for that shadow in the lower right corner that everyone complains about). Any suggestions?
  • trendkilla May 11, 2010
    Did anyone figure this out?
  • Anonymous Mar 27, 2014
    In 72 it has the green on light but only a dull white rectangle with no logo can you re set from the buttons?
Depends on how many times the orange light blinks also when you replaced the lamp did you do a timer reset? you can find alot of information on how to trouble shoot this www.infocus.com/support
Posted on Sep 12, 2007
  • sernaj Sep 12, 2007
    if the orange light blinks once try reinstalling. if it blinks twice then you need to reset the lamptimer if it blinks three times it may be overheating and check to make sure your fans are turning. and if it blinks 4 times its a board error
I have thise exact same problem, and the orange light blinks over 20 times?? What does it mean?
Posted on Feb 08, 2008
I too am having an issue with the projector's orange light blinking.. blinking ... blinking.... blinking... until I unplug the power. The light starts off blinking green, I hear the projector power try to energize the bulb, however, it gives up after a few tries then starts with the Orange blinking light.......
Assistance would be nice... thanks
Posted on Feb 22, 2008
    New Friend:
I have problem with NEC VT660k projector :
problem : When you turn on the projector lights orange, and status lights as orange
Posted on Feb 09, 2014
I have a Boxlight CD850M which did the same thing when I first bought it and burned out my 1st light.
Turned out I had to send Boxlight/Infocus the projector and they upgraded the software level of the machine. Jeff
Posted on Sep 28, 2008
Mine does the same only it has a brand new bulb, my bulb life was over 1900hrs and it went out so we figured the bulb burned out and then we installed the brand new sealed in the box spare bulb and now get the constant orange blinking light and nothing responds on the panel
Posted on Apr 25, 2008
SOURCE:
I have a Infocus Lp530 that as soon as you plug it in, all the lights on the top will continually flash green and an audible clicking sound can be heard. These two things occur before the power button is...
You can try removing the main board & reseating it. Also try plugging into another outlet & make sure the plug has a ground prong on it. Itshould have 2 flat & 1 pin shaped prongs. Otherwise the clicking sound may be the lamp trying to ignite. Normally when you plug in the LP530 the green power light is on steady & then you press it to start the lamp. If its flashing as soon as you plug it in it's likely that the main board is bad, the button board is bad, or the ballast/power board is bad.
You should remove the lamp & inspect it. It should be clear without bulging in the little bulb behind the lamp glass. I service LP530s all the time & something like that is usually the main board.
Good luck,
Jim
Apr 15, 2011 | InFocus LP530V Video Projector 2000 ANSI...
Light does not come on, fan is working and green light at top keeps blinking off and on on a LP70 infocus projector
if you hear a high-pitched whir, the problem is either the ballast or the lamp. if you don't, it's the colorwheel. you could try to get the parts from an infocus service center or send it in to them for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 22, 2009 | InFocus LP70+ Multimedia Projector
LP70 Infocus Projector light will not start up
if you don't hear a high-pitched whir, the colorwheel needs to be replaced. if you do, it's either the lamp or ballast. if the lamp is new, replace the ballast. you can get the parts if you want to do it yourself, or you'll have to send it in. either way, try av solutions in ny. they are an infocus service center and they're really good. www.avsolutionsny.com
Wont light up
the colorwheel needs replacing. if the colorwheel won't spin, the lamp won't light. if you hear a high-pitched whir, the colorwheel works, which means there is a power supply issue. there is a fix for that, but you have to be good at soldering. if you are give it a try: http://www.infocus.com/service/asc/communications/tech_notes/2006/09/tn495g.pdf
Oct 05, 2009 | InFocus LP70+ Multimedia Projector
LP530 green Iamge
make sure the resolution on the projector matches the input resolution.
Feb 22, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP530 projector not powering on
the power supply needs to be replaced. it goes after a while in this model.
Feb 09, 2008 | InFocus LP530V Video Projector 2000 ANSI...
Infocus lp530
I called InFocus and was walked through several steps to determine if it was a bad cable or an internal problem. My InFocus unit would power up and stay powered up with no problem until I connected it to the computer using the analog computer cable (blue connectors). They had me try it with a different computer and then with the S-Video cable. Each time the InFocus unit powered down within seconds of connecting to the computer. The problem is internal. The unit had to be sent to InFocus for repair ($180). If the unit works with the S-Video cable then your problem is a bad cable.
Jan 08, 2008 | InFocus LP70+ Multimedia Projector
Pile of ##@!#@ infocus lp70 green light wont come on. should i smash it??
if the fans aren't running, it's the power supply. if the amber is on and the button's won't turn it on, there is an obstruction under the button panel. if all turns on but the lamp and you don't hear a high=pitched whir, it's the colorwheel. if you do, it's the ballast.
Dec 20, 2007 | InFocus LP70+ Multimedia Projector
Inforocus lp70 green light not comming on or is eney thing?
Found a broken lead on the back side of the AC connector to the board. Resoldered a piece of copper wire, working perfectly again.
Dec 17, 2007 | InFocus LP70+ Multimedia Projector
Infocus LP70
its not geting power lust like mine
Dec 11, 2007 | InFocus LP70+ Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
7,103 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
martin hogg
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
