Question about Dell Inspiron 1525 Laptop Jet Black
Laptop doesnt boot, stuck at the first screen
My laptop is not starting up anymore. When I press the "Power" button, the screen shows the first page with the DELL logo, and then freezes (the blue band fuzzes up as well). I am left with no other alternative other than to press the Power off. I also tried pressing "Fn" along with power, and other combination, but it freezes at the same point.
Any help would be appreciated!
Thanks
Anurag
  • 2 more comments
  • anuragps Dec 26, 2008
    Thanks for your time!!
    The laptop model is Dell Inspiron 1525 (Jet Black). I bought it just 3 months back. I cant get into BIOS because no matter which key I press, it freezes barely 3-4 seconds after it starts up. The "blue band" is on Dell screen. And there is no CD in the drive.
    I did call up Dell support line. They made me try the "Fn"+Power combination to start the computer. Post that the 3 LEDs adjacent to the Power button started blinking/flashing. So they have said its the case of a bad motherboard.
    Dell support line is very hard to reach, and is not available on weekends...and on weekdays its difficult to tally with my office timings. So a couple of questions:
    1) Motherboard replacement: can it by any chance affect the Hard Disk, in terms of data loss? (Pardon me if its a stupid question :) )
    2) Is it usual for a 3 month old laptop, kept in proper condition...to face this problem?!
    3) Does this replacement come at a cost for me?
    Thanks!!
    Anurag
  • jaybird09 Dec 27, 2008
    I have what seems to be exactly the same problem with daughters laptop (Dell inspiron 1525)
    I did power on in safemode as suggested but still have blank screen.
    I was able to get into the movie mode (accidentally clicked on one button but not sure which one :( ) but it said to power off & restart with windows.
    Initially I thought it might be the inverter but because the movie mode appeared on the full screen, I highly doubt that's the problem.
    Power off no longer works either - have to unplug & wait for battery to deplete - then restart with plug in.
    Any suggestions as to what else I could try before I take it in?
    I've already decided I won't be sending it to Dell - sounds like they generally overcharge/charge for something which might be their problem to begin with. (correct me if I'm wrong)
    One side note: My own laptop is an HP - never had this problem with it & their online support team is super. They'll walk me through step by step no matter what time in the day/night & no charge to me if done via my other working computer. Is Dell always like this?
  • Boogerhead01 May 11, 2010
    Which blue band -- on the Dell screen, or the progress bar on a Windows startup screen?
    Make sure you have no CD in your drive.
    If it's freezing in Windows, keep hitting F8 as soon as your computer begins to restart and select Safe Mode.
    If Dell screen ... life may get complicated. See if you can hit F1, F2, F10 and/or delete to get into a boot menu, hit each key frequently as your computer tries to boot so hopefully it'll launch you into a "BIOS" menu. The details of this menu tend to vary as much as the keys you use to get into them, but it's the basic beginnings of your computer.
    What you want to do is make sure it's set to boot off your hard drive; make sure you have no CD in the drive. Try to Exit and Save the menu, and see if you can boot now. If that doesn't work, feel free to post here with details and any error messages. My other suggestion would be, if that doesn't work, this may be time to call Dell's support line, which should still be free for you.
    Alternately, if you feel brave and/or stupid, see if you can find a "Restore to defaults" function in the BIOS that may get you back on your feet.
  • Dapid Candra
    Dapid Candra May 11, 2010
    Can you get into the BIOS? (Press F2 when DELL logo showing)
I have this problem but i think the bios is completely gone, nothing is happening except light blinking. Whole laptop is opened, only motherboard and compulsory parts are connected to turn it on. how can i reflash it? can you please send me the link or file which i can load directly from flash. Because its stuck on DELL page. Please help, i m stuck with this laptop.
Regards
Posted on Aug 29, 2012
  • 50 Answers
Check bios settings and turn them to default,
and install windows again
Posted on Jul 06, 2009
  • Terminator Jul 27, 2009
    contact your dell support center.
    and try using fn+esc+power button , when power button start blinking release the keys and contact support center for bios update via email or some other type. then copy the file into pendrive and connect it to laptop after 1- 2 minutes windows start up then 2nd step is copy the other file into pendrive , double click on it and update bios. then restart.
    plz check that support center prvides you  two file namely flashgt or something like that and one other.
Ok wat u need to do is that, you will have to send the laptop for repairing. your address fax no, email;opeyemi4real2000@yahoo.com
Posted on Jul 01, 2009
    Problem Solver:
  • 10 Answers
The laptop could have a corrupted/bad hard drive
Posted on Jun 19, 2009
    Problem Solver:
  • 6 Answers
Dear Anurag,
There is some serious problem in your laptop relating to the ram. I suggest to try some confirmed working ram module with your machine. I am sure it will help
Posted on Apr 30, 2009
  • 73 Answers
What kind of warranty did you purchase? most of the new laptops come with a 1 year warranty, so the replacement should be covered.
As far as whether or not it is normal, it does happen from time to time that the parts of a laptop are defective which is the reason for the warranty. I manage about 450 Dell laptops and desktops and i have noticed that I have issues with about 2-3% right out of the box. Dells tech support has been very good to me and they have taken care of the issues as they come up.
Posted on Feb 08, 2009
LG E23 My laptop hung while i was using it. I held the power button to force shutdown, but after that when i pressed the power button it would not boot. The power light is on, the dvd drive opens when i...
Old computer technicians trick. 1st, remove the battery and unplug from any power. Hold the power button down for about 10 seconds to short the board and clear any charge left in the capacitors. Plug in power supply and press the power button. It should boot up fine and you can put the battery back in.
Jan 29, 2018 | LG Computers & Internet
When i start my laptop the system doesnt boot and gets stuck after main memory check page. I need a help on this. When ever i power on system doesnt read os to laod at all and shows blank...
You will need a WinXP CD....
insert the CD and re-boot...
if boot seq is not set to boot from CD change it
restart PC...immediatly press either (F1, F2, Del) key to got to BIOS menu....
look for boot seq,
change the 1st boot dev to CD/DVd rom
save and exit BIOS menu
re-boot....
let the PC boot from CD
follow on screen inst...to reapir the OS or reinstall OS
for more info
got to my site
www.sureshayyar.110mb.com
Reg
Kris
May 08, 2011 | Fujitsu AMILO PC Laptops
I made in bios a setup to boot fast and when i open the laptop the bios option it doesnt appear anymore , it is starting windows. how can i repare it .how can i acces the bios again?toshiba L655-S5058
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
May 04, 2011 | Toshiba Satellite L655S5058 Notebook PC
Laptop screen is not showing anything after power is on
if the power is on and the screen does not show up , try to hook an external monitor using the VGA cable. If the screen does show up, it means that the problem is in the laptop LCD monitor itself. Otherwise if the external monitor does not show up, that means your laptop does not boot anymore to the operating system. Try to turn off the power and remove the power cable and battery on the laptop. Then press and hold the power button for 8 secs. Then reinsert the battery and power cables on the laptop then turn on the laptop. If there is still no screen displayed then call Lenovo for repair of your laptop.
Oct 22, 2010 | Lenovo 3000 C200 Notebook
Doesnt go to the start page
I would recommend that you try to boot the computer in Safe Mode. This will load the basic drivers and few programs, allowing you to determine if there is a hardware or software issue preventing the machine from performing a standard bootup.
Step 1. Remove any discs in the CD/DVD drives.
Step 2. Power off your computer.
Step 3. Disconnect all devices from your computer except the power cable.
Step 4. Power on your computer, and press the F8 button every second or so until you are brought to the Windows Safe Mode screen.
Step 5. Select the Safe Mode (without networking) option and hit Enter.
Step 6. The machine will then begin to load with the most basic drivers and basic programs.
Step 7. Be patient during this time. It may appear that the machine is stuck. Give it up to 5 minutes.
Step 8. If your machine performs a successful boot, log on with an administrator account.
Step 9. On the Desktop, right-click on My Computer and select Manage.
Step 10. In the Manage Your Computer Console, in the left hand side, expand Event Viewer.
Step 11. Scan through the logs to see if there is any issues recorded during the last successful boot.
Step 12. If you find any issues, read through them carefully to see what they say.
Step 13. Restart your computer and let it perform a regular boot.
Step 14. If you expereince anymore issues, let us know.
May 01, 2010 | HP Pavilion dv9000z Notebook
Acer 5920 vista page fault in a non paged a blue warrning page
Hi there, please restart your laptop when its booting press F8 key . You will find few option asking for selection. Select that by using up/down arrow key. Select " Last know good configuration" & press Enter. Next page asking for selecting operating system, for example: windows vista or Windows XP etc. Just select the operating system & press Enter again. ( Hope your laptop showing only one operating system ). Your laptop will start normally. If again that's blue error screen come then remove the RAM, clean it by soft napkin, Fix it back on ram slot & on power button. If nothing changes then format the Operating system & reinstall again.
Thanks & waiting for your feedback
Jan 10, 2010 | Acer Aspire 5920-6574 Notebook
I have a Toshiba Satellite A305D-S6848. Last
Connect an external monitor to your laptop. Start your laptop and use Fn+F5 buttons (or those appropiate to your model) to send the video signal out to the external monitor. If you do not get any image on the external monitor it means that most probably the mainboard is damaged (video card or even more). Expensive to fix or replace. Have it checked by a professional.
Oct 06, 2009 | Toshiba Satellite A305D-S6848 Notebook
Acer aspire 5315 doesnt boot blank screen
When you power up the laptop press F1 or F2 or "del" key to enter in bios setup.
Then check your harddisk is detect or not?
Then also make sure SATA option is disabled in bios.
Then go to boot option and set first boot device as your harddrive.Then save settings and exit.
But if you even not able to enter in bios then you have reset bios settings and Refix RAM memory .
For that open back cover fo laptop and find cmos cell on motherbord pull it for 10 minutes so all settings of bios goes to factory defaults.
Let me know if you need more assistanse.
Thanks.
Sep 25, 2009 | Acer Aspire 5315 Notebook
Laptop doesnt boot only power ligth comes out when press on buttom a ligth comes out but nothing on the screen i dont hear the fan keep going.
Maybe there are some problem in your start button (the button wire connect to mainboard is Loosening.
Please press the start button for about 3-4 seconds then see it would start. Always it may solve the problem, this happend to my inspiron 6400 too, after used for years the start button failure. It shows only power lamp lights green but the other light cant light red.
If no, maybe your must change a power supply, as the lower volt current cant start all the device.
May 15, 2009 | Dell Inspiron 6400 Notebook
Spacebar stuck
you need a new keyboard most likely, contact your maker of your laptop and give them the information. you can also search up your make and model of your laptop on ebay and try to find a new keyboard that way. im 95% sure its the keyboard the rest could be software. if you have any more questions or comments pleasse email me at meanness628@aim.com
Jun 25, 2008 | Toshiba Satellite A105 Notebook
Dell Inspiron 1525 Laptop Jet Black  Logo
418 people viewed this question
Alun Cox
