Question about Miele DG 4080 Stainless Steel Electric Single Oven
MIELE H 4641 PYROLYTIC OVEN
MAIN OVEN WON'T WORK - FAULT CODE 90 ON THE SCREEN
JUST WHAT I NEED OVER THE CHRISTMAS PERIOD!
ANY IDEA WHAT THIS MEANS?
  • 1 more comment
  • Anonymous Jan 19, 2009
    I turned the mains power off waited 2 mins and then turned the power back on and it seems to have reset for now.
    I don't know what the code means though!
  • Anonymous Mar 24, 2014
    please help me
  • steve stead
    steve stead Nov 02, 2017
    its a oxygen sensor fault and will probably re-occur
I HAVE THE SAME PROBLEM. KEEP HAVING TO TURN IT ON AND OFF TO USE IT.
Posted on Jan 05, 2010
After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
Miele fault code f04 Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fault code f04 > Ovens
Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
[PDF]USE & INSTALLATION MANUAL - Smeg
www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
[PDF]user manual e:line built in ovens - Appliances Online
manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
Jan 10, 2016 | Ovens
I have burnt on food (sugar) in my Miele pyrolytic oven. How do I get it off? Will using the pyrolytic process just make this worse?
Ammonia works really good to remove burnt on food. For inside the oven put a small bowl of ammonia on the rack, close the oven door & let sit overnight. The fumes will work overnight.
Dec 01, 2017 | Ovens
Mile Pyrolytic Oven got a PY flashing
Mine is doing this too. Did you find a solution?
Apr 05, 2012 | Miele Ovens
What is fault 90 on a miele oven?
F90 is an oxygen sensor fault and this is a free of charge repair in the UK
If you turn appliance off via mains for 60 seconds and turn back on this will rectify problem temporary allowing you to use the oven.
Jun 09, 2010 | Miele DG4060 Electric Single Oven
Miele pyrolytic oven: error 90
F90 is a faulty oxygen sensor. This fault clears after resetting your circuit breaker for 24hrs only. you will not be able to use any automatic programmes as the oxygen sensor measures the moisture in the air and then decides how long to cook for. You will need a Miele service technician or a registered service agent to replace the oxygen sensor. This should be covered under warranty but check with your local Miele dealer first.
Mar 14, 2010 | Miele DG 4080 Stainless Steel Electric...
Can't use my Meile pyrolitic oven fault 90
I turned it off at the main power source and then turned it on again and it worked just fine ... no further problem. I would have been mad if I had called a serviceman and had him lust throw a switch and charge the earth !
May 14, 2009 | Miele DG 4080 Stainless Steel Electric...
Neff B4562 Pyrolytic Cleaning Not Working
You need to remove the rack side supports too. Its not clear in the book as it just says shelves and racks but everything needs to come out the oven.
May 01, 2009 | Neff B1476 Pyrolytic Stainless Steel...
Pyrolytic cleaning fault
fixed very simply just turned off oven at mains turned back on and it worked perfectly!!!!!!!!
Aug 18, 2008 | AEG B5741-4 Electric Single Oven
FAULTY TIMER/CLOCK
I found mine did the same I pusshed the face and it came back on. It appears fault within circuitry of clock and will need to be replaced
Dec 14, 2006 | Smeg F170 Pyrolytic Stainless Steel...
Miele DG 4080 Stainless Steel Electric Single Oven Logo
1,348 people viewed this question
Top Miele Ovens Experts
Paul Bade
Marvin
Marvin
Are you a Miele Oven Expert? Answer questions, earn points and help others
