Question about Dyson Flowcheck CRO1 Front Load Washer
Hi there, got a CR01 flow check which recently had it's rear circuit board replaced to cure a F11/F14 fault (can t remember which). Since then when it starts the rinse cycle (normally 2 rinses) it trips my electrics!! Have to manually reset them about 8 times just to get the darned machine to complete. Tried cancelling and using the rinse/spin option but same thing happens
Had electrics tested already but before board was swapped this problem never happened??
any ideas?
SOURCE: how to repair a F 11 fault on a DYSON CR01 flow check
To Clear F11 Code after a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
You will now hear the door lock release so you can get to your pants.
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
Posted on Feb 10, 2009
SOURCE: F14 error code, and says Flooding. Help please.
F/14 ERROR CAUSES DUE TO:--EEPROM ErrorThe Central Condrol Unit (CCU) receives it's data from an EEPROMonboard the CCU. If there is an error reading this data, it will cuse this error.
TO RESLVE THIS ERROR MANUALLY TRY THIS BEFORE CALLING ENGINEER :--
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
Check CCU
Posted on May 06, 2009
3, Power on
Diagnostic
Thanks for using Fixya.
Posted on May 28, 2009
SOURCE: f11 fault code
Please find the steps that needs to be taken for trouble shooting F11 fault code specially if there was a power cut.
3, Power on
I am sure it would help you to resolve the issue.
God Bless.
Posted on Jul 09, 2009
f11 fault code is a problem with the main power board (could be blown fuse) or a blown board check the fuse the board is behind the back plate in the bottem right corner (looking from the back of the machine.(!unplug before you take apart!)
Posted on Sep 17, 2009
Feb 23, 2015 | Dyson Washing Machines
Mar 17, 2014 | Dyson Flowcheck CRO1 Front Load Washer
Dec 13, 2013 | Dyson Flowcheck CRO1 Front Load Washer
Jan 07, 2012 | Dyson Flowcheck CRO1 Front Load Washer
Aug 13, 2011 | Dyson Flowcheck CRO1 Front Load Washer
Oct 03, 2010 | Dyson Flowcheck CRO1 Front Load Washer
Sep 15, 2010 | Dyson Flowcheck CRO1 Front Load Washer
Apr 07, 2010 | Dyson Flowcheck CRO1 Front Load Washer
May 29, 2009 | Dyson Flowcheck CRO1 Front Load Washer
Apr 04, 2008 | Dyson Flowcheck CRO1 Front Load Washer
65 people viewed this question
