The shift keys are not working on my asus laptop tried the sticky key solutions but still don't work
It could be that you enabled filter keys by you holding down the shift key for more than 8 seconds. then click the 'Settings' button next to it hope this helps
click start menu > control panel > accessibility options
the checkbox next to 'Use FilterKeys' should be unchecked, if it is checked, uncheck it and
Then uncheck the box near the top that says 'Use Shortcut'
if this doesn't work then you may want to have a look at some of the other keyboard accessibility options and see if you can get something to work
you may have to restart windows in order for the changes to filter keys to take effect.
SOURCE: SHIFT KEYS NOT WORKING PROPERLY
Please try to deactivate the Fn (function) key. That will help you get rid of your problem. Press Fn key + Numlock key once and try again. You can also try pressing the Fn key once and type letters in any word processor program with the key combination everytime you press the Fn key once. E.g. open the notepad, press Fn once and after that press ) with Shift.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
SOURCE: the @ key will not work on my acer aspire one
Hi!
No! i mean press AltGr and 2 (the numberal 2 upp to the left on the keayboad)
If i press those on my keayboard it gives me an @ :)
Nic
SOURCE: shift key sticking on Lenovo laptop.. its like a
Hello..
Sticky keys a really a big problem, i had to face this too couple of months back when i came across these guys who sell individual keys
www.laptopkey.com
So i just order a new key from them, they sent me the fitting with the key which was really easy to get together ,, im really happy to find them, You to could try replacing the sticky keys on your laptop.
Good luck
SOURCE: my eee pc 901 doesn't
Hi
It seems to be there is pressed button and should be released.
Try with the control keys like ( Ctrl, Alt, Shift, both right and left, and Fn key ).
Press these keys hardly ( not much ) to release them,
Please, Tell us your results.
Good Luck
SOURCE: my n145 netbook was working fine last nite then
try looking it under a light or in the sun if you can make out the screen but the light is out then you either have a bad back light or inverter
