Question about Pioneer Televison & Video
New tv - no sound problems with hdmi leads
Trying to set up the new pdp-lx6090 with skyHD (with scart as no picture no sound) using HDMI Kef540 sound set (via HDMI lead).
The DVD player is the only thing working on both sound and picture (as part of the Kef system).
Problem:-
- no sound on sky but got picture when using scart
- no sound on terrestial via analogue.
- Current tv settings will not allow acess to HDMI control
- no sound or picture on sky when using hdmi
  • steve_mcnaug Dec 27, 2008
    The kef system if the only thing that works the problem is the I cannot get sound when using scart for skyhd. also cannot get sound on terrestial nor can we get sound or picture on skyhd when using hdmi leads.
    I think the tv does not recognise the hdmi leads
  • 505 Answers
I'd recommend using component video and regular audio, as hdmi has these types of problems all the time. its usually an incompatability between devices and software upgrades may be needed on either end. contact your manufacturers if you want it fixes, or just bypass with the trustworthy older connections. if you want digital audio, run it straight to your stereo.. tvs have cheapo speakers anyways.
Posted on Dec 27, 2008
  • 365 Answers
Try to change the HDMI settings and try tocheck out the cables which are going in.the input port may be damaged and try it with a new one .thank you
  • JITHIN ANTONY Dec 31, 2008
    does the problem solved
  • Pioneer Master
  • 19,396 Answers
Switch the HDMI channel input settings on TV menu, you do this using the TV remote.
Try also using a different HDMI socket at the back of the TV.
Posted on Dec 26, 2008
    President:
  • 2,110 Answers
When i connect my ps3 via the hdmi socket i get no picture, only sound when i use the ps3 controller. i have tried using the new scart lead and still nothing. i have gone through all the AV channels also....
You may have it set to scart video audio hdmi , instead of the scart try using the analogue video also , yellow connector on tv if it has it , also AV and scart aren't always the same on tvs search through the source option on the tv
Dec 01, 2014 | Sony SELECT KDF-E50A12U Rear Projection...
I have no picture on DVD with scart lead on AV1 and no picture or sound on separate player on HDMI connections. both players work fine on other televisions.
Is the same HDMI cable you use in other TV.Will you properly check the plug of HDMI cable at the HDMI input of your TV and check the setting.
Jul 11, 2011 | Televison & Video
I have skyhd connected to Lght-805sh via optical connection but when i turn sky over from a hd channel to normal channel there is no sound
Not sure what you mean by "optical connection" but you need to connect your SkyHD box to your TV using both HDMI and SCART cables. Your Sky HD box will then send the signal via the HDMI cable for the HD channels and the SCART cable for the SD channels.
Hope this helps
BElectric
Nov 06, 2010 | LG Televison & Video
Hi I have a Philips 32inch ambilight TV about
No a lot of HDMI does NOT send the sound signal through the HDMI cable & must be run AV to AV, the RED WHITE & YELLOW plugs Color to color for RED & WHITE, the YELLOW is Composite Video. . The SCART should indeed have it "All in one" however that signal is only RGB, or Composite Video, a lower quality, than HDMI. Just use HDMI & AV. you'll be all good.
Feb 06, 2010 | Televison & Video
Ps3 gets sound but no picture when using hdmi cord
you need an optical lead for the sound and hdmi for the picture
Dec 29, 2008 | Philips 23PF4321 23 in. HD-Ready LCD...
Set up surround sound with the following
YOU CAN ONLY GET 5.1 FROM THE OPTICAL OUTPUT ON THE SKY BOX NOT THE HDMI
SO CONNECT YOUR SKY BOX OPTICAL TO TV OPTICAL
PLZ LET ME KNOW IF THIS HELPS
JonnieC
Aug 10, 2008 | Pioneer PDP-4270HD 42 in. Plasma...
I have got wharfedale lcd 42in and a wharfdale dvdr24hd how do you set up the hdmi cable to get clear picture i have tryed taking out the scart lead out and left the hdmi cable in but i only get a picture ...
Sounds like you either have a bad card or a bad HDMI cable. Scarts are not the most dependable when it come to HD imaging there is alot of converting going on espically if the TV isnt NTSC standard to begin.
Mar 06, 2008 | Televison & Video
Ps3 sound problem
PS3 is The amazing device by sony but it has some common problems like sound, but no picture problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Oct 10, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
73 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
