Question about Sharp R-1480 Microwave Oven
Microwave problem hello sir i have a sharp R-450C microwave and the problem is that it's entire control panel is dead and need to be replaced so can you tell me where would i get it in india in mumbai(maharashtra state) please tell me as soon as possible
  • Sharp Master
  • 9,098 Answers
You would need to contact service centres via this link
Or you can contact them to ask where to buy spares here:
SHARP INDIA LIMITED [India]
Gat No.686/4, Koregaon Bhima, Tal.Sirur, Dist. Pune 412 216, Maharashtra, India
Tel: 91-2137-252417, 252418, 252419, 252420
Fax: 91-2137-252453
Posted on Dec 26, 2008
Where is the fuse on my sharp R-8340 convection microwave?
On a Sharp model, the fuse holder is most commonly found between the door switches or on the floor of the chassis behind the controller.
At my Web site, I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If your oven is dead, it may be a blown oven cavity thermostat (if equipped) or a magnetron thermal fuse.
Very few parts are shown to be available for this model, so generics may be in order. You can order available Sharp parts from Sears or Encompass.
Contact me directly if you need more help.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Feb 28, 2017 | Sharp Microwave Ovens
My Microwave oven Sharp R-450C is working but not heating.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on; use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
Feb 01, 2013 | Sharp Microwave Ovens
Sharp r-450c microwave oven not heating
Feb 01, 2013 | Sharp Microwave Oven Microwave Oven
On control panel r-220b pressing 2 does not work, sometimes 0 does not work all others work.
you need to change the control board. Its gradually becoming defective.
Jan 18, 2012 | Sharp R-220BW Microwave Oven
The microwave oven has completely gone dead Sharp r-1501c. Yesterday the light was on. I went to turn the light off and to put something in the microwave and it lost all power. I've checked the outlet...
It may be the control panel. What ever you do, don't send the control panel to William Miller. He ripped me off, and I have to dispose of my microwave because he never returned my control panel.
If yours has gone dead completely, it's more cost effective just to replace it. I bought an LG to replace mine.
Mar 08, 2011 | Sharp R-1501 Microwave Oven
My Sharp R1505 Microwave's LED display is malfunctioning, with only minimal lighting of digital/number segments. Do I need to replace the entire control board with a new LED attached or can I just replace...
You can order a new control unit (part number CPWBFB075MRU0 which comes with a display) from Encompass here.
Or you can get yours repaired for $39.95. Details here.
Feb 10, 2011 | Sharp R-1505 Microwave Oven
Can't find the power loss in microwave after fuse, switch check.
Sounds more like the transformer could be bad. Very easy to check. See my tip at http://www.fixya.com/support/r4318968-check_high_voltage_transformer_in . Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous rating.
Mar 11, 2010 | Sharp Microwave Ovens
Control Panel "clock Buttom" dead
Sounds like your keypad has failed, and on some models it's not available separately, so you have to buy the entire control panel assembly.
You have to remove the controller (see the video here) then unplug the keypad strip (see photo below) then move your circuit board to the new control panel assembly (part #
WB07X10798 if that's the right one for your model).
See exploded views
here. You can find this part for $101.91 here (compared to $163.50 from G.E.!).
Jul 20, 2009 | GE JVM1650 1000 Watts Microwave Oven
Sharp R 1610 Microwave Lights
For your reference, we repair this control panel assembly problem for customers nationwide for $32.50.
Oct 15, 2006 | Sharp R-1610 Microwave Oven
Sharp R-1480 Microwave Oven Logo
141 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
