Question about HP Compaq dx2300 Microtower - RT950UTABA PC Desktop
Computer starts but moniter stays in sleep mode .. moniter works on different comp .. will adding a vid card to my comp fix this problem ??
    Novelist:
  • 117 Answers
Actually, Yes. It seems like you have answered your own question... Especially considering the monitor works on another computer.
Do you have another monitor to test on this computer?
Although another consideration could be if you recently installed or downloaded a program which may have changed your video output range to a setting your video monitor wont handle. If this is the case and you can start the computer in safe mode, this will allow you to go into your properties settings and change it back. This way, a new vid card is not req.
Good Luck
Posted on Sep 14, 2012
  • dicksondavid
    dicksondavid Sep 14, 2012
    yes i have another monitor and it does the same thing .. thank you for the advice im goin to try a vid card and see what happens and ill let you know
5 Suggested Answers
melnavz
  • 1226 Answers
SOURCE: monitor will not boot up stays in sleep mode
Is your pc got beeps, if yes then try to remove and clean the memory and also the video card if it is add on card. and then insert it again test. if encounter still the same error then try to replace the memory.
please tell me more if ever what you encounter about the issues.
may this help,
melnavz
Posted on Oct 04, 2008
  • 916 Answers
SOURCE: My computer isn't working...it's in sleep mode and
Hold down the power button until it turns off. Turn oit back on and tap F8. Choose last know good configuration from the menu.
Posted on Jun 08, 2009
  • 10406 Answers
SOURCE: Compaq Presario stuck in sleep mode
Connect the monitor to some other computer, e.g., a notebook, and see if it does the same thing. If it does, then the monitor is the problem.
If it does not, then your computer is not putting-out any "video" signal, and so the monitor goes to "sleep".
If you have MORE than one VGA-output port on your computer, connect your monitor to the "other" VGA port.
Or, press-and-hold the ON/OFF button on your computer, to force it to completely shutdown.
Posted on Jan 13, 2010
  • 44 Answers
SOURCE: unpacked computer after move moniter will not stay
Hi
please check the cable between the computer tower and the monitor.
either the cable is not connected properly or the cable is defective.
this is a message you normally get when the computer is off, and you try turning on the monitor alone.
hope it helps
Posted on Sep 24, 2010
Came home to find computer off. It was left in sleep mode. The moniter keeps saying there is no signal and the keyboard has no power.
If its truely in sleep mode, and won't come out of sleep mode. Unplug the computer from its power, hold the power button down for 5-15 sec, then wait 2-5 full minutes. Then plug it back in, and turn it on.
If that doesn't work it is NOT stuck in sleep mode. Most dell computers I've worked with the caps go out in the power supply and/or the motherboard. I would next clean out the computer with canned air, check the caps on the motherboard, and in the power supply. If there are any bad caps, replace them, and it should fix it. Hopefully though the above paragraph fixes your problem.
Sep 13, 2013 | Dell Dimension 4600 PC Desktop
Moniter goes into sleep mode after i turn it on. Have to turn off the monitor for 20 seconds and then it comes back on for about 20 seconds and goes back into sleep mode
This may be a problem with the monitor, such as a failing video board, or it may also be a problem with the video card in your computer. If you can try the monitor on another computer or try a different monitor on your computer, you will have the answer. At the price new 18" widescreens are selling for (sub 100.00 in Canada), I would have a hard time justifying spending too much time or money trying to fix this one.
Mar 09, 2011 | HP Pavilion F1703 17" LCD Monitor
Hi...I have a Flatron W2234S that is about one year old. It has been problem free until recently when I moved. Now all of a sudden it comes on and immediately goes off and I have to turn it on and off 3 or...
You can take it apart and inspect for bulging capacitors - the tops should be perfectly flat. Even a slight bulge at the top is an indication that the capacitor is bad.
Nov 11, 2010 | LG 22" FLATRON LCD Monitor
My pc crashed and i had to switch the pc off by the switch
I agree it must be a PCI slot or video card problem .Try to change the videocard.
Jun 05, 2009 | E-Machines eMachines Desktop PC
"Analog going into power saving mode" when I try to play a game.
Most of these kinds of problems are created by using the different version than the current version of your video card driver.
Check your video card company's website and download the specific video card driver for your devide's ID and It should resolve the proble,
May 30, 2009 | LG W2252TQ Monitor
When turn on pc it wont come out of sleep mode
make clear you have conected every cord onto its original position. be sure that cooling system works. some computers get stuck when they get too warm too quick.
Jan 20, 2009 | ASUS Motherboard, GeForce 6100, Athlon 64...
The monitor will turn on but only stays on for about 3 seconds
Maybe you guys should make sure the moniter is on the right input, because if moniters are on a wrong input then they go into sleep mode. If that doesn't work make sure that the cables are fully inserted! Hope I Helped!
Jan 20, 2009 | HP Pavilion F1703 17" LCD Monitor
Added a new video card, now my monitor stays in sleep mode
If the computer originally had integrated video, have you tried reconnecting the monitor to that output? Most system boards will automatically detect when you install a separate video card, but on some you need to disable the built-in video in the BIOS before the new card will work. Also, have you considered the chance you just got a lemon of a new card? It happens sometimes (it's happened to me!).
Nov 18, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Monitor will not boot up stays in sleep mode
may this help,
melnavz
Oct 04, 2008 | HP Media Center m7060n PC Desktop
Won't come out of sleep mode
Have you tried getting a second monitor ? then using it to get to the desktop and go to power options and set your monitor to never turn off? after that is done try your monitor again and see if that works.
Feb 07, 2008 | KDS Radius RAD-7 17" Flat Panel LCD...
HP Compaq dx2300 Microtower - RT950UTABA PC Desktop Logo
179 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
