I am currently using my default motherboard graphics, having plugged in the cable from the moniter into the motherboard graphics slot. i also have a NVIDIA GeForce FX 5200 graphics card installed with drivers and everything, but when I try to plug my moniter into the NVIDIA card slot, a message comes on my moniter saying "input not supported". totally confused on how to proceed.
  • 565 Answers
Try to disable the integrated old monitor in bios and use this one
Posted on Dec 26, 2008
  • Teet Bergmann Dec 26, 2008
    1. Power on then press DEL to enter BIOS setup
    2. There are tabs along
    the top of the BIOS screen and by default you are on the MAIN tab. Use
    the right arrow key on your keyboard to highlight the Advanced
    tab.
    3. On the Advanced tab use the down arrow key to highlight
    Chipset then hit the enter key to bring up the Advanced Chipset
    Settings
    4. Use down arrow to highlight Internal Graphics Mode
    Select
    then hit enter key
    5. Select Disable option then hit
    enter
    6. Hit Esc key twice and you should see Exit and Save
    Settings
    then hit enter key and the BIOS should exit from setup, save your
    new settings and then re-boot.
How to install riser card compaq evo
Finding a compatible graphics cards may be a daunting task if you know little about your computer's components and technical specifications. To find a video card that is compatible with your system, you'll need to uncover information about your motherboard and power supply by opening your case and peeking inside. From there, you can perform additional research and make an informed determination of the types of graphics cards compatible with your computer. If your warranty is still in place, consult your computer manufacturer or builder to obtain the information you need
Physically open your case and examine the number and types of slots on your motherboard. Unplug any cables connected to your computer prior to removing the side panel, but make a note of where your monitor connects. Remove your case's left side panel (when facing the front of the case). You may need to remove screws or to adjust latches. Please see your case or computer manual if you are unsure how to remove the side panel. Locate the current graphics card. By matching the port your monitor plugs into with the graphics card, you should be able to easily locate your video card. If you have an on-board graphics chip, the monitor will not connect with a card but with ports directly on the motherboard. Measure your case interior and the card slot. Make a note of how long the current card is. You must also measure for prospective maximum expansion card length. For example, if you measure 7.5 inches from the slot cover to the nearest obstruction (obstructions may include other slots, chips, or the processor), you will not be able to buy a card that measures 8.5 inches in length. The card you install must not affect any other components on the motherboard. Write down any brand name or model number so that you can verify the measurements by researching the card's specifications. Locate a serial number, brand name or product number for your motherboard and write it down so that you can research the motherboard and its specifications. Locate your power supply. Generally, the power supply will be in the upper-left corner of the case. Power cables connected to your drives, your motherboard and possibly your video card will run to the power cable. Make a note of the wattage, the brand name, and any model number. Perform research to verify the power supply's specs. Replace the side panel, and plug in all cables. Find a graphics card that will work with your motherboard and power supply and fit the motherboard's measurements. The card should both fit into the slot physically and be designed for the type of slot on your computer. Ensure that the card has drivers for your operating system. Hope this helps.
http://www.4allmemory.com/video-card/compaq-hp-evo-d510-series/
Jan 01, 2013 | Compaq Evo D510 PC Desktop
Dual monitors t3516
Is it just like this with NO graphics card installed?
http://products.pacificgeek.com/emachines_t3516_celeron_d_3_20ghz_512mb_120gb_cdrw_dvd_xp_1013070674.php
If so, Not happening.
The I/O area is to the left side. (Input/Output area)
In this rectangular area you see;
1) PS/2 mouse port, and PS/2 keyboard port, at the top.
2) Orange port below them.
3) Black port below it.
4) Down below all of the above is the blue VGA port.
If you do not have a graphics card, your monitor is plugged into this blue VGA port.
If so you are using Integrated Graphics. Another term used is OnBoard graphics. ON the motherBOARD.
Do Not try to use a splitter cable, and run two monitors off of this VGA port. Ain't happening.
See the four long slots at the bottom of the computer? The bottom one has the Ethernet adapter card in it?
A graphics card, (Video card. Same/same), is installed on the motherboard, and the end of it sticks out one of those 3 unoccupied slots.
Each of those slots are known as Expansion Bay Slots.
When you choose what slot you want, you remove the Expansion Slot cover, for that slot.
My sources indicate the motherboard is an Intel D101GGC motherboard,
http://www.e4allupgraders.info/dir1/motherboards/socket775/D101GGC.shtml
There are 2 white PCI slots at the bottom.
There is 1 black PCI-Express x1 slot above them.
There is a longer black PCI-Express x16 slot above it.
The PCI-Express x16 slot is for a graphics card. It is the best graphics card slot on your motherboard.
(The white PCI slots are lame. The PCI-Express x1 slot, is NOT used for a graphics card)
Suggest you use a PCI Express graphics card for your computer, and run two monitors at the same time.
From here it depends on what the two monitors are. Do you have two monitors that use a VGA cable?
Example of a VGA cable, and a VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
Or do you have a monitor that uses a VGA cable, and a monitor that uses a DVI cable?
Example of DVI connectors,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
Or do you have one monitor with a VGA cable, and a monitor that has a DVI cable?
Post in a Comment as to the monitor manufacturer name, and model number.
[ For example I am using an HP 2009m (20 inch widescreen), and a 26 inch RCA EN-V HDTV, as dual monitors ]
This is an example of a very economical PCI Express graphics card, that will run dual monitors,
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130755
You can use a monitor with a VGA cable (Blue port), and a monitor with a DVI cable.
You can use two VGA monitors, with using a VGA to DVI adapter, for one of the monitors.
You can use two DVI monitors, with using a DVI to VGA adapter, for one of the monitors.
Already have a graphics card, and two monitors connected to it?
1) Right-click on an empty area of your desktop screen.
2) At the bottom of the list left-click on Properties.
3) In the Display Properties window, left-click on the Settings tab.
4) Left-click on the rectangular monitor icon, that has the 2 in it.
5) Go below to the left, and left-click on the empty square next to-
Extend my Windows desktop onto this monitor
6) Go below to the right, and left-click on Apply.
7) Go below to the left, and left-click on OK.
Your desktop screen is on your second monitor.
Need guidance past this post in a Comment.
Regards,
joecoolvette
Jun 09, 2012 | Computers & Internet
THE BOARD IS WORKING BUT IT HAS NO WHERE TO PLUG MY MONITER
It would seem as if you need a separate graphics card. A lot of the newer Mobos have no onboard graphics. Or it could be you have the wrong connector on your monitor (ie VGA, DVI, Display Port or HDMI)
Jan 22, 2012 | HP (D7580-60003) Motherboard
HI this is pradeep iam using ASROCK motherboard processer AMD Anthlon(TM)XP2600+ for this motherboard which graphic card can i use my problem is i brought dell 24inch moniter ST2420L but graphic...
Asrock K7VM3 mother board with AMD Athlon 2600+ processor.
The Motherboard is having a AGP slot which says to use AGP with 4X and 1.5 V
Can someone suggest the market products available
when I contact the technical team of Asrock. they responded as below:
The AGP slot on K7VM3 is the standard AGP x8 slot , as long as the VGA card you want to buy is standard AGP VGA card , K7VM3 can support the standard AGP VGA card.
Or , you can double check your question with your VGA card vender before you buy it .
Oct 17, 2010 | Asrock K7VM3 Motherboard
Why does my computer swith on but not boot up
try getting a new graphics card or when it turns on try resetting it a few times.
Aug 20, 2009 | Compaq D51S 1.6GHz Desktop XP Computer
No vga port
No on board graphics adaptor, you will need a graphics card that will fit in the PCI express slot
Jun 02, 2009 | Intel DG31PR Motherboard
My moneter can't disply any thing. There is no problem in moniter I checked it. it's a problem of my motherbord .
Step 1 -check & make sure your vga cable is properly secured on te compuuter & the monitor
Step 2- if you have a graphics card in your computer , make sure its properly seated in the slot of the motherboard
Mar 23, 2009 | Compaq (162857-001) Motherboard
Is my Motherboard compatible?
Try to find out what the AGP voltage is on the motherboard.
Some graphics cards use 1.5 volts and some use 3.
If it's a 1.5 volt AGP slot and you plug a 3 volt graphics card in, it either wont work or you could permanantly damage both card and motherboard.
Mar 07, 2008 | Computers & Internet
Probably not. There is not quite enough information in your post to really help, but from what I'm finding on the GeForce 6800 GT, it is only available in PCI-Express and AGP 8x (AGP3.0) Versions. Your motherboard only supports AGP 1x, 2x and 4x (AGP2.0) cards.
Dec 13, 2007 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Computers & Internet Logo
198 people viewed this question
Alun Cox
k24674
