Question about Philips MCM275 Shelf System
"READING" message for USB source
I am getting "READING" message whenever I switch to USB source, with or without a USB drive being plugged in. This is a new unit. Anyone with a similar problem?
Panasonic sa pt860
Check your USB memory to make sure that it comply with the points below:
1) USB standard USB 2.0 full speed
2) Media file format support MP3 (.mp3) WMA (.wma) JPEG (.jpg) (.jpeg) MPEG4 (.asf)
3) USB device file system FAT12, FAT16, FAT32
4) USB Port power Max. 500 mA
As you can see
1) You should format your USB in windows format (FAT system)
2) The files on your USB should be those mentioned above on point 2.
3) 2.5" hard drives most likely do not work without an external power supply.
you can download the manual from HERE !
Please don't forget to rate me!
Best Regards
XyFinx
Dec 14, 2013 | Televison & Video
I cannot put files on my external hard drive
just plug your hard drive in another noze of usb...
if u have loose connection in usb then it will happen. try to copy small size of data
Sep 01, 2012 | Western Digital My Book Essential 1TB...
Hi there, I have a Toshiba external HDD 250GB that is giving me some problems and need some urgent help! When I plug my external HDD into my laptop everything seems to work fine. The lights come on, the...
It sounds as though your issue is one of in adequate power. Do both the external HDD have their own power source, or are they powered through USB? if they are powered through USB it may be that as soon as the second drive spins up to transfer the files, it overwhelms the limited power of the laptop. You can try it with the laptop plugged in (though this may not provide it with more power than the battery) or by purchasing a usb hub with its own external power source so that it is not drawing power from the laptop, or purchase an external hard drive with its own power source
The other option is simpler and free, and its to copy the files first to your laptops own HDD, then unplug the source external hard drive, and then plug in the drive you want to copy to, then transfer the files from your laptops hard drive. This will of course take twice as long, but will cost you nothing.
May 29, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
I have a Kingston Data Traveler 8GB USB Flash Drive which I bought 4weeks ago. Whenever I plug it in one of my usb ports, i get a message which says "USB Device Not Recognized. One of the USB Devices...
The thumb drive might have some fault.
Plug it in other OS mainly windows XP and Linux.
If still same problem persists after tried in Linux, problem is with pen drive.
You can ask for a replacement from the dealer as it has guarantee for 5years.
Nov 30, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computer is not recognizing my external hard drive
If the light won't blink, there could be problem with the power source. Do scanning hardisk for errors manually ( take off the hardisk from the case, assemble it on other PC Desktop)
May 06, 2010 | IO Magic Corporation GigaBank (I250HD35)...
Kingston 2gb datatraveler malfunctioned
there is absolutely no problem in your pc .
your pen drive is faulty.
Feb 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to use USB device in USB port of Sony DVD Player
Hi!
When using the pen drive with the dvd player add the images/videos/songs directly into the pen drive without creating any folders in the pen drive and then try to connect.
Thanks
Rylee
Feb 09, 2009 | Sony Audio Players & Recorders
USB Message keeps flashing
Do a Google search with the following string:
(Brand Name) (Model Number) +driver
Download and install the latest drivers for your camera, this should correct any software problems in your camera. The problem with the computer may be related to the software problem in the camera.
Hope this helps.
Apr 25, 2008 | Fuji FinePix E510 Digital Camera
Philips MCM275 Shelf System Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
