Question about Sanyo DS27800 27" TV
How do I get to S-Video?
I just bought an S-Video cord to adapt my laptop computer to the TV because the TV has an S-Video jack along with the audio/video. I can not get the S-Video to open on the TV, even though I can get to the regular Video screen for my DVD player. How do i get the S-Video to come up? Sanyo Model # DS27880
  • 56 Answers
Go to your graphic card settings located in the display properties menu, click "properties". You'll be able to see the settings of your laptop's graphic card. Choose "advanced",then select your "TV" as a target screen. Your S-Video cable has to be plugged in to your laptop when you are searching for the Laptop Display/TV selector I mentioned above. Also where this selector is located depends on what graphic card you have.
Posted on Apr 17, 2007
How do I hook my sylvania model number 6432GG TV to my ASUS laptop model #D550MAVD801?
The only inputs tho the TV are cable in and AUDIO / VIDEO in.
You can use 'stereo patch cords', to plug into the tv. Check with your local computer store to see if you can find adapters to plug into the computer and change to RCA jacks.
All of that means, you probably can't.
Dec 04, 2014 | Sylvania 6432GG 32" TV
My laptop Vostro 1320 wont boot up anymore. The power button light goes on, the battery light doesnt, but the 'nr. 9 lock' is flashing, along with the 'A' and 'arrow down' lock are...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
It's also possible that your motherboard is problematic.
Hope this helps.
Sep 24, 2011 | Dell Vostro 1320 Notebook
How to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Sep 13, 2011 | Lenovo IdeaPad Y560 Laptop
What do i need to play back recorded video onto my t.v from my sony handycam dcr-trv260...i have s cord, usb cord, yellow rca jack??? so what else do i need!!!...nothing i have tried has worked???please...
You can connect this camera to a suitable TV with either the S-Video lead or the RCA lead, but only if the TV is equipped with the appropriate inputs. The S-Video lead looks like a tiny DIN plug, and the RCA jacks are three separate plugs coloured red, white and yellow (yellow is composite video, red and white are left and right stereo sound). If you use S-Video you will also need to make a separate connection for sound (using the red and white RCA connectors). Sometimes the TV sound input is a mini stereo jack, and you will need a Y connector to adapt the two RCA connectors to the mini jack, or maybe the camera's sound output is also by mini jack, in which case you may need the reverse Y connector. Most TVs have some way of accepting a video signal, but you may already be using it for a DVD player or the like.
If your TV lacks these connections, you may be able to use an adapter. In the UK, most recent TVs have a SCART (Peritel) socket, which takes a big plug with 21 connections on it. You can get an adapter to fit that socket that will allow you to plug in the RCA connectors and maybe the S-video too. I don't know what country you are in, or what adapters are available in your country if it isn't the UK.
Once you have made the connections, you must select the appropriate input on your TV. The other possible hiccup is setting the camera to the right video standard, NTSC or PAL., to match that used by your TV.
The USB cord will not connect your camera to the TV.
Jan 11, 2011 | Sony Handycam DCR-TRV260 Digital Camcorder
I have an ultra-slim 29 TV. I want to connect it to my laptop so that I can get laptop's output through TV along with sound. Please note i do not want to watch TV on my laptop (thats vice versa).
the picture is easy either a HDMI cord or a regular computer monitor cord should be able to connect depending on your laptops connections.
As far as the sound you will need an adaptor to go from a 3.5 mm headphone jack on your computer to a red and white RCA jack like on a dvd player and plug into your tv
Dec 06, 2010 | Philips Televison & Video
How do I hook my tv up to my acer netbook? I dont have a tv port but do have a port for a second moniter and have the cord to hook it up but it will not work...
If the TV doesn't have a VGA input, you have two options. If the TV has component video inputs (3 RCA jacks color-coded red, green and blue, not just a single video jack coded yellow), you can use a simple adapter cable. Here is an example.
If your TV only has a single yellow video input jack (called composite video) you can't use the simple cable. But you can get a VGA to video converter. This device takes the VGA signals and converts them to the form the TV can use.
Hope this helps. Thanks for using Fixya!
Mar 30, 2010 | Acer Aspire One PC Notebook
My cord to my adapter got bent. I bought a new
Full breakdown and replacement of the power jack should be no more than $125 - you can find places on eBay for that.
Nov 12, 2009 | Acer Aspire 3680 Laptop
Dell Laptop - Inspiron 1525 - Electrical Sparks w/HDMI Cable and Dell Adapter
Now shortage,.. why you dit not use the s video connector? if you want to show the move from the laptop computer to tv, just s video to tv. tv out..should...
if som burn or damage in board that is big problem.. you need to bring shop for repair.. or if under warranty try to return it
Jun 08, 2009 | Dell Inspiron 1525 Laptop
Old Curtis CMC13003 will not display DVD picture
Radio Shack has a Y adapter to hook up the 2 audio wires together RED/WHITE are audio. 2 females to 1 male Y adapter
Feb 03, 2009 | Curtis CM13102 13" TV
Ati mobility radeon 9000 agp
hi camperd55,
I believe you have the right adapter cable. According to my knowledge the Radeon 9000 supports TV output via RCA (check http://ati.amd.com/products/MobilityRadeon9000/index.html:" Mobility™ Radeon™ 9000 provides the highest quality output support for DVI-I, TV and CRTs.")
Firstly, it would be a good idea to make sure your TV has the 3 RCA jacks into which you will insert the adapter cable's 3 RCA connectors according to the colors of the connectors and jacks.
Secondly, if your laptop has a VGA port, you're set to connect your laptop to your TV, no hustles. If your laptop doesn't have a VGA port, your going to have to get a DVI-VGA converter, so you're setup will be something like: [laptop]-[DVI-VGA converter]-[VGA-3RCA adapter cable]-[TV's 3RCA jacks].
When you get your laptop's screen displaying on your TV, its merely a matter of using your recording equipment to record the TV's image as you would any program showing on the TV.
I hope this will help you solve your problem, thank you for using the FixYa service.
Kind regards
Henru : )
kind regards
Feb 10, 2008 | ATI Mobility RADEON Graphic Card
Sanyo DS27800 27" TV Logo
128 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
