Question about Nokia 2600
Heelp my vibra call doesn't work.where is the problem ?
    Problem Solver:
  • 9 Answers
Do you mean that your phone does not vibrate? If so, then the small vibrate piece might be dislocated. You would have to open your phone and put it back into place.
Posted on Apr 18, 2007
SOURCE:
My camry 95 wont start doesn't even turn the switch key light on no power what so ever.... heelp!!!!
It sounds like your main fuse has blown or the power main relay has failed.Check the 40A and 30A fuses in junction block 2, and the power main relay in block 1. See here p10-11
http://www.turboninjas.com/camry/be.pdf
Jan 05, 2013 | Toyota Camry Cars & Trucks
Hi 5800 only vibrate no on
1. By using a scale manually Multitester x1, connect the cables Multitester with positive and negative poles of the Vibra component, if the component is vibrating in a good situation, but if the components do not vibrate Vibra then you need to replace the defective component Vibra.
2. Further examination could be done if the component is not damaged and remained Vibra still using Multitester, connect the cable to the interface component Multiterster Vibra on phone PCB, if there is movement of the needle when it is connected Multitester the path under normal circumstances, otherwise if there is no needle movement means there is a path Multitester end. You can make jumpers system directly from the UI to the component controller IC Vibra. Check also that the positive path from the battery to the Vibra in good condition, if the track is lost then do the path-breaking jumper on you, then the vibration will work again.
exsample image on nokia n95
look
http://1.bp.blogspot.com/_y-JFYukllP4/S4p0DjmWvlI/AAAAAAAACGk/4wjfgVRipqw/s400/vibra%20N95.jpg
Apr 25, 2011 | Nokia 5800 XpressMusic Smartphone
I need creativewebcampd1100downlod
The following link has the driver for Creative Vibra PD1100. The driver has been tested and works with both windows XP and windows 7 as well...hope it helps.
http://seoroot.com/blog/driver-downloads/creative-vibra-pd1100-driver-download.html
regards Ahmer
Oct 19, 2010 | Creative Labs Vibra Webcam
WANTS too go on faceeeeey **** canttt d: heelp
try refreshing the page. also, what do you mean by not able to go on face book? i think your internet is lagging
Sep 23, 2009 | Facebook Social Network
Vibrate on
good day ! you need bring your phone to the cellphone technitian to check the vibra motor or the setting of your phone , if the setting is good thats mean the problem is the vibra motor or the vibra driver ic try to replace that ! good luck ! ...
Sep 09, 2008 | Sony Ericsson W200i Cellular Phone
Creative Labs Vibra Personal Web Camera
http://www.driverfiles.net/Sound-Cards/Creative-Labs/Vibra-128/download/page,sh,39893,455,7,.html please
Jul 02, 2008 | Creative Labs Vibra Webcam
Creative webcam labs vibra driver
i lost the driver of my creative labs vibra pesonal web camera... can you pls send me a driver of it?
Nov 08, 2007 | Creative Labs Vibra Webcam
VIBRATING ALERT DOESNT WORK
Open the unit and clean the contact on the vibra and check the vibra to see if its stil ok. Use an eraser to clean the contact.
Jul 24, 2006 | Nokia 3220
Nokia 2600 Logo
42 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
ASHRAF CA
ASHRAF CA
