Question about Whirlpool AWM5125/1 Front Load Washer
Whirlpool awm5125/4 washing machine
Unable to get fast spin at end of cycle or when at specific fast speed position.
    President:
  • 1,294 Answers
If the washer seems to complete all of its cycles, but it doesn't spin: 1) Be sure the load of clothes is not lop-sided. If the tub becomes unbalanced, it may spin erratically or not at all. Open the lid after 2 minute gap and reposition the clothes. This automatically resets an off-balance shut-off switch. Close the lid and re-try. 2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during the spin cycle. If the switch doesn't click when you press and release it, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) The belt may be loose, worn, or broken. If you're fairly handy, tighten or replace the belt, otherwise call an appliance repairperson. Pl post back results
Posted on Apr 18, 2007
Wfc7500vw spins but not at high speed on final spin
This is a common problem with the Whirlpool front load machine. The motor control board goes out but the new ones have been redesigned. You will need to replace the control board. Here is a link to the control board you need.
Oct 17, 2012 | Whirlpool WFC7500VW Washer
My whirlpool duet washer stops towards the end of the cycle and flashes 6 then F. The door stays locked and the washer beeps. It has happened before, the machine is about 6 years old, how can I fix
F/06
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Feb 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Spin cycle stops too sharp
The clutch isn't disengaging at the end of the spin cycle. The cause is usually the controller not progressing either mechanicaly or electronicaly.
Nov 04, 2009 | Maytag Performa PAV3200
Whirlpool front load washer won't spin - just sometimes
Most Whirlpool (Hotpoint) machines have "out of balance" sensors that detect very large movements of the drum suspension usually due to a very badly balanced washing load.
This can occur for various reasons but putting large and/or heavy items in can trigger these sensors i,f as the machine starts to spin, the items dont get distributed evenly around the drum. This is more likley with large/heavy items.
The machine will then restrict the spin speed for the remainder of the wash cycle, and once the machine is switched off, the next time the machine is used it returns the spin speed back to normal - but if it detects an out of balance situation, it will again restrict the spin speed.
It sounds to me the machine is acting as designed. You could try positioning the items differently as you load them, and hope they dont end up "all over one side".
Oct 06, 2017 | Whirlpool CAM2752KQ Top Load Washer
Malber WD1000 won't hi-speed spin
check if the drum assembly is loose, but it seems like one of the mounting arms or shocks broke.
Jul 10, 2009 | Washing Machines
Whirlpool Duet ht...does not spin out?
run it with no clothes, wait the entire cycle because it only spins fast at the end, dont overload the machine.
Feb 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Does not always spin
How old and is it on all loads? How fast to stop the machine when you lift the lid? Can you stop the tub while spinning, careful on this one?
Oct 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't spin fast, only slow
tyr removing the lower acees panel from the uint , ther is a "button trap" located there to catch debris from entering pump assy, chances are its clogged and if it cant drain all the water it wont go into high speed spin, also you MUST use an HE detergent. HE detergent specifically designed for front loading washers
Apr 28, 2008 | Kenmore 44102 Front Load Washer
Whirlpool AWM5125/1 Front Load Washer Logo
123 people viewed this question
Sal De
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
