Question about Gateway 7001433 Keyboard
I formatted my HDD and now it says Keyboard Not Found
Now im stocked at the booting screen. I cant go on to installing my OS because my CPU doesnt recognize my keyboard. Im well aware that my keyboard is functional and working. I just Formatted my hard disk using Clean and Swipe program and planning to install a new OS. when im done formatting, i rebooted and now it doesnt recognize my keyboard. im using ps2 port keyboard. please help me.. many thanks!!!!
  • chardmb Dec 27, 2008
    Im using the same keyboard before I started formatting the hard disk. and i borrowed another keyboard from a friend to see if its just my keyboard that started to malfunction in the middle of reformatting but the other keyboards just dont work.
    Problem Solver:
  • 12 Answers
Your problem is that you need the file for your keyboard. This sucks because you are already in the middle of a reboot situation. Do you have your old keyboard or another one to get you through?
Posted on Dec 26, 2008
  • kever Dec 27, 2008
    There are 3 things that you have to do. 1 I don't know the software(not that it matters), Can you boot to DOS? if you can and are able to type there then it is NOT the keyboard
    2. If you can, try running the reinstall from there(DOS), this should work.
    3. If this does not work can you do an auto reinstall from the CD with all keyboards disconnected until the software asks you for one
Formating remove virus
first off you have a choice you can either run virus scan to attempt to remove it from with in safe mode
format the HDD assuming it isn't your primary OS drive
or reinstall the whole OS
we will start with safe mode
so whilst the pc is still in start up (POST) rapidly press f8
this will take you through to a start up menu choose safe mode at the top.
once booted up log in and run antivirus software such as bitdefender/avast/avg and others. I recommend avast (personal preference) if nothing Is found look for more in depth for a better anti virus program.
formatting will technically remove a virus from a HDD but if you format your OS your screwed and it is unlikely that a virus will install itself to your second drive so ignore this. (don't even attempt to format)
this is a last resort if you cant solve it.
borrow or create a live cd/dvd/usb OS boot the computer into this and then install the OS if you are using windows, use your recovery disk that no one makes and if you didn't make one contact your laptop/PC manufacturer as they should have one for a fee
Jan 12, 2014 | Transcend StoreJet Computers & Internet
Hi i have a portege s100-s1133, i try to install new os but the hdd cant not detected, but if i tried to boot into windows the hdd are detected. and im tried to go to bios settings because i want to change...
1.FIRST YOU DO ONE THING IF YOU USING XP OS MEANS CHANGE THE SATA MODE TO IDE OTHER WISE CHANGE THE SATA MODE TO AICH.
2.IF BOOT WITH CD MEANS CHANGE BOOT PRIORITY CD/DVD ROM
2.IF YOU BOOT WITH HDD MEANS CHOOSE HDD.
BIOS OPTION----CONTINUOSLY PRESS F2 KEY.
Nov 17, 2010 | Toshiba Portege S100-S1133 Notebook
Boot Problem
when it restart press F8 buttton thenenter in enable vga mode then if u able to see screen then no problem .
But if still face problem try to dleete all partition and create new partition then format c then check .
Jul 15, 2009 | ASUS Intel 810E Chipset CUWE-RM...
Bsod, error code:0x00000024, hdd problem booting xp os
Can you do this
Boot from the Windows XP CD.
Watch for a Press any key to boot from CD... message similar to the one shown above.
Press a key to force the computer to boot from the Windows CD. If you do not press a key, your PC will continue to boot to the Windows XP installation that's currently installed on your hard drive. If this happens, simply reboot and try to boot to the Windows XP CD again.
When the Windows XP Professional/Home Setup screen appears, press R to enter Recovery Console
Select your OS and enter password (if needed)
When you reach the command prompt type the following and then press Enter:
expand d:\i386\hal.dl_ c:\windows\system32\hal.dll
Using the expand command as shown above, d represents the drive letter assigned to the optical drive that your Windows XP CD is currently in. While this is most often d, your system could assign a different letter. Also, c:\windows represents the drive and folder that Windows XP is currently installed on. Again, this is most often the case but your system could be different.
If you're prompted to overwrite the file, press Y.
Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Apr 24, 2009 | Sony VAIO VGN-T170P/L Notebook
OPERATING SYSTEM NOT FOUND MESSAGE
HI,
This can be an issue with the hard drive..
Go to bios by tapping F10 while the system boots > go to diagnostics and select hdd self test.
If it given an error "No IDE device found" then try reseating the hard drive. i.e. take it out and put it back in.
Otherwise try changing the boot order by going to advance / system configuration > select boot order > select the hdd and pess F6 till it goes to the top. Press F10 to save and exit.
Hope this helps..
Regards,
Anup
Apr 08, 2009 | Compaq Presario 700US Notebook
Just repaired g3 ibook. Hard drive needs formatting, as it has xp loaded on it. Ibook starts up, boot tone, proceeds to load, then screen has a file in the center of screen with the osx finder square face...
With the OS X Installer CD in the drive, try booting your mac and holding down the option key immediately after you hear the start up chime. This will (hopefully) load a firmware boot loader that will show available start up discs. Hopefully the OSX installer will show up as CD Icon. Select the Icon with your mouse or keyboard and press enter to start up with the Installer CD. From the installer you should be able to erase and format the drive as Mac OS Extended before installing OS X.
If the computer still won't boot from the CD double check that it is a retail OS X installer CD. If your CD has "software restore" or "ibook restore" or any other varient of restore written on the label; or if it names a particular model such as "ibook install" or "imac install" it is not a retail copy and may not be a bootable disc. A retail copy will only name the version of the operating system followed by the word install written on it's label and usually have a brief instruction on booting from the CD by holding the C key at startup.
Hope this helps, let me know what happens.
Apr 03, 2009 | Apple iBook G3 Mac Notebook
Problem with installing new windows OS on toshiba A105
You should put the drive back in the external caddy, delete the format, partition the drive for NTFS. format the drive and set as active.
Mar 24, 2009 | Toshiba Satellite A105-S2712 Laptop
I cant install vista OS on this MBD , by sata HDD
You must enter setup at boot and select the CD/DVD as first boot. Then ensure that the BIOS settings have SATA enabled. When CD/DVD is first boot watch the screen for 'press any key to boot from cd' message is displayed. The boot screen will say how to enter setup. Typical buttons are F2, Delete, F1, F10 -you did not say which manufacturer. OEM trumps mobo maker with BIOS setup.
Oct 14, 2008 | Gigabyte GA-8KNXP Motherboard
Im having no boot issue
Things to Check When No boot...
1. Have you connected all the power cable?
2. Do you see any display?(including the power lights glowing)
3. Does the screen show you any blue screen error message?
4. Do you hear any beep noises?
5. Have you tried to install any third party hardware or software?
6. What do you think could have caused the issue?
Mar 28, 2008 | Dell Dimension 4600 PC Desktop
Gateway 7001433 Keyboard Logo
77 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
