Question about Lenovo 3000 N200 Notebook - Intel Celeron M 530 1.73GHz - 15.4" WXGA - 512MB DDR2 SDRAM - 80GB - Com... PC Notebook
CPU starting very late app.it take 30 minutes
Continuous pressure on start button.
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
I have an 89 e350,starts and runs for 30-40 minutes then dies. try to start but won't. can't hear the fuel pump go on?
The first question is always - do you have spark and fuel pressure when it fails to start. And to continue, do you have power at the fuel pump and EEC relays ?
Aug 05, 2014 | Ford E350 Cars & Trucks
Jeep sputters
Check fuel pressure at the injector rail. Could be pump is failing or filter is clogged.
Jul 28, 2017 | Cars & Trucks
It will crank up and run for about 20 or 30 minutes then it will die and it will not start back up for 30-45 minutes. It has plenty of battery power and sounds like it wants to start but it just...
This sounds like a fuel pump issue. Check the fuel pressure and for spark at the plugs after it dies. If fuel pressure is low then you will need to replace the fuel pump. Feel free to respond after these items are checked. Thanks
Sep 03, 2011 | 1992 Dodge Caravan
Fuel filter or pump. will start but will not continue. gage show 55 lbs of pressure when start, none when not key on.
Sounds like a pump. You should have 43 lbs of pressure after system is primed by turning key to ON. Pump will run for 5 seconds and shut off if engine is not running. It should hold pressure for 30 minutes with just a few lbs drop. If not, it is the check valve, internal to the pump or the fuel pressure regualtor on the fuel rail. Hardly ever the latter
Jun 23, 2011 | 2004 Ford Explorer
Half-warm engine start problems. My Saab 9-3, 2,0, 2000 mod. bought in april 2010 has now been running totally 230 000 km. Lately repaced distributor cover, rotor, spark plugs so far. Still the engine...
One possibility is in the the fuel system. It may be the the fuel filter, fuel pump or injecters. You can test fuel pressure to the the injecter rails and change the fuel filter if you haven't already done so.
Mar 13, 2011 | 2001 Saab 9-3
Oil light comes on when starting engine or when excelerating. Started last week, checked level was fine changed oil and filter this weekend and still doing it.
An easy one, finally.
The oil pressure sensor is one of the least reliable parts of any car and yours is bad. They are supposed to turn on the 'idiot light' at ~ 4 pounds of pressure which is almost too late for any warning since oil pressures range from ~30- ~60 pounds in most engines.
These are common failures and not costly to replace. Once you know where it is, with an appropriate wrench, it's about a 5-minute job.
Nov 15, 2010 | 2005 Buick LeSabre
When trying to turn on HP Media Center desktop, I press start button then button starts to blink green and orange and computer will not boot. I unplug CPU and start button stays lit for atleast 30 seconds.
this issue has been taken up on this forum, with a plethora of solutions. This is a power issue. Easiest solution, unplug the computer, wait 5 minutes, plug it back in, wait 2 minutes, then turn it on. That will fix your problem 90% of the time. If not, here is a bunch of solutions:
http://www.fixya.com/support/t350366-power_green_light_flashing_hp_desk_top
Dec 27, 2009 | HP Media Center m7250n (ED842AA) PC...
P21G (V3.1) motherboad freezes and wont start
ขอ driver motherboard p 21 g v3.1 หน่อยสิ
Feb 09, 2008 | PC Chips MB PCCHIPS P21G (V3.1) P4M800 775...
Booting so late
Check u're BIOS settings ! There are setting that allow a delayed drive test (for the hard drives that initiate them selfs slower than the motherboard) maybe that is u\re problem. U can also do a BIOS update, and set all the settings on default ...
it can also stay that long if u manually set a disk drive in BIOS, and that disk does not exist ...., or even a faulty dvd unit ....try removing u're dvd and see if it influences the boot up time. ..
Jan 19, 2008 | Mercury P4VM800M7 Motherboard
Lenovo 3000 N200 Notebook - Intel Celeron M 530 1.73GHz - 15.4" WXGA - 512MB DDR2 SDRAM - 80GB - Com... PC Notebook Logo
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
