Question about Zanussi FJS1225W Front Load Washer
Machine not turning
Hi after fixing the last problem with my machine which was a new pcb and pump, i have had the machine going for two months and now it is just outside the qarauntee, and it has stopped again. it will not turn over or spin. when it trys to take in water it has to turn a few times , but it will not and subsequently shuts down, can anyone help , is this a motor problem , should it be repalaced?
  • neil brownlee Apr 17, 2007
    think this is a brushless motor havent even looked yet but it most prob an induction type motor
    President:
  • 1,462 Answers
Could be motor or module problem - can't tell remotely but at least check the motor brushes
Posted on Apr 17, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
My machine starts and then flashes F12 and stops working what's wrong please?
Deborah,
if your machine is a Hotpoint/Indesit the F-12 error code is a communication error between the main pcb and the display pcb. No simple fix im afraid, a new main pcb is required.
you will need to contact the manufacturer.
Aug 19, 2016 | Whirlpool Washing Machines
Hi , coffee machine is not heating water, pump working ok, just no hot water!
fest see if you do descaling may halpe to clean the boiler also see ntc which is the thermostat this part is based on the boiler with two leads attached to it this looks after the temperature if not you have to consider the pcb
Mar 26, 2016 | DeLonghi Icona 15-Bar Pump Driven...
Indesit washing machine pumnp burnt out, replaced it but it still won't pump or spin. Does it need a new programmer or can the programmer be fixed?
You're absolutely right. If you look at the wiring diagram on the machine it is clear that the drain pump is powered by triac on PCB (part code C00270972).
I think it is definitely safer and probably cheaper to replace than to repair the PCB.
It is always a good practice to visually inspect PCBs that there are no visible defects such burnt out elements, etc. before replacing. Sometimes the reason for burnout PCB may be on a completely different side.
25580311-2cx31aa5jn1eijqkorrs11s2-4-2.jpg Dado
Mar 16, 2015 | Indesit Washing Machines
I have a 609 Intuitive washer that was dead. Controller fuse was blown, pump control FETs shorted out. Another smaller chip in pump control circuitry obviously dead (small crater in the top). Corrosion...
i just love these machines they are not the best but there great when they work correctly. ok yes the most common problem with the f/p washers is they blow there power control boards the reason why is this there is no power short protection in the pcb have you ever unplugged the washer lifted the lid and turned by hand the barrel and seen that the lights on the control light up it allows the capstan drive motor to reverse its poer back to the board when the washer spins too fast it imt/s too much power back to the pcb. your completly ok to fit the control board it wont burn out 32 ohms on the pump is great give it a little spray of wd-40 anti corosive oil spray now the impulse reader on the side of the barrel small circuit board that must be clean and free of water marks and dust rust e.t.c then the drive break will respond faster stopping pcb burn out do this every 6 months
merry christmas
sonic boom electronics australia
please take the time to rank this advice
thanks
Dec 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hotpoint wma42. drum not turning, brushes changed last november, have tryed a new motor twice still not turning... suspect pcb. what do you think.
Pcb is a distinct possibility but would check loom from board to motor as i have found many broken wires on wma series.
Hope this helps & thankyou for using Fixya.
Feb 20, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hi, i have 2pcs of canon iR2016 Digital copiers which displays error codes of E246 AND E247. these errors are not in the service manual, please help
Sir i am a Canon trained tech. I just checked our website and my service information. I found the following. I suspect someone has been working on these machines or swapped some parts around.
Page 1 of 2
MODELS AFFECTED / SERIAL NUMBERS AFFECTED:
Digital Copiers, Including All imageRUNNER Products
SUBJECT:
Information About The New Soft Counter Circuits
GENERAL TECHNICAL INFORMATION
GENERAL:
This Technical Publication presents information about the new Soft Counter circuit that replaces the mechanical counter
used in the past. There are three (3) PCB’s associated with the new Soft Counter circuit; the Counter Memory PCB,
Main Controller PCB and the Serial Number PCB. A description of their function is provided below. Use this
document as a reference for current and future models that use the Soft Counter circuit.
Counter Memory PCB
On the latest Canon digital copiers, such as the imageRUNNER 5000, imageRUNNER 8500 and imageRUNNER 2200
series, there are no mechanical counters. Instead there is a Counter Memory PCB. This PCB is usually mounted on the
Main Controller PCB with one screw. The Counter Memory PCB is imprinted with the serial number of the machine
the first time power is turned ON and cannot be moved to another machine. Attempting to do so will generate an E246
error code. In the event of a Counter Memory PCB failure, a new one from stock (see Note 4) can be installed into the
machine. At that point the Main Controller PCB will transfer its present total count as indicated in “Counter Check” on
the control panel (recorded the last time power was turned OFF) to the new Counter Memory PCB and the total counter
will increment from that count on. Never attempt to operate a machine without the Counter Memory PCB
installed!
This may generate an E245 code, which can only be cleared by “zeroing out” the Main Controller PCB by
one of our A.P.R.F.’s (Authorized Parts Repair Facilities).
Main Controller PCB
The Main Controller PCB, aside from performing other tasks, retains the total count by means of SRAM with a battery
back up after power has been turned OFF. If, however, the Main Controller PCB has been replaced with either a new
one or a used one, it will read in and record the total count from the Counter Memory PCB retained the last time power
was turned OFF. The total count will then increment from that count on.
Note 1:
Even though the total count will be the correct value for that machine after replacing the Main Controller, the soft
counters in Service Mode will not. If a new Main Controller was used for the replacement, then all soft counters in
Service Mode (service counters in “Counter Mode”) will be zero. If, on the other hand, a used Main Controller was
used for this replacement, the soft counters previously recorded on that PCB would be shown. At that point it is
advisable to clear these values in Service Mode using Function>Clear>CNT-MCON.
All Main Controllers sent to our A.P.R.F.’s for repair will be “zeroed out” before being sent back to the dealer.
Page 2 of 2
GTI-T151
04-30-02 GT I
Note 2:
The Counter Memory PCB and the Main Controller PCB should never be replaced simultaneously!
This will
generate an E354 code and assistance from the Canon Reseller Technical Support Center Hotline will be required. If
the Main Controller is sent to one of our A.P.R.F.’s for repair, you must remove the Counter Memory PCB
before sending it out!
Failure to do so will only increase down time for your customer.
Note 3:
If the Main Controller PCB is replaced, ensure that connector J1023 is connected. If it is not, an E350 will be
generated.
Serial Number PCB
The Serial Number PCB’s main function is to identify the machine’s serial number. This PCB cannot be moved to
another machine.
Attempting to do so will generate an E355 and assistance from the Canon Reseller TechnicalError codes not listed in the Service Manual:
There are various error codes that are not listed in the Service Manual. Canon U.S.A., Inc. reserves the right to treat
these error codes as Proprietary Information. If you encounter any of the following error codes, contact your Canon
E245 E246 E247 E350 E354 E355
Note 4:
Please be advised that Canon U.S.A., Inc. treats the Counter Memory PCB and Serial Number PCB as “restricted” parts.
When a dealer orders these components they will be asked to provide the reason for their replacement, and the original
PCB will have to be returned to Canon U.S.A., Inc. for evaluation.
Jan 07, 2009 | Office Equipment & Supplies
Ariston a1600wd not working
There is a filter of sorts in the pump inlet pipe, its a big item catcher coins etc, but thats got nothing to do with the module error wich is a pricey item at £120! I've had one go already and in the last year, a inlet valve plus a control pcb panel in fact its almost a NEW machine! i'll never buy another hotpoint or ariston again. The machine is two yrs old!
Oct 02, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Buzzind sound
There are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. As far as installation instructions go; you have to have some soldering experience, first. You will also need some type of de-soldering device, be it a solder ****** or solder wick to remove the caps. Make note of the polarity before removing. Then it is just a matter of popping the new ones in (they are slightly larger than the originals so they might not go all the way down flush with the PCB) and soldering them back in. Make sure you do not make any solder shorts or your system will be toast! Your unit will be as good as new and will probably last forever now.
Dec 24, 2007 | Philips HTS3450 System
Mine buzz for about a month and now it is turning red light and no sound..... anything I can replace to fix it?
As I found somewhere on the internet; there are two 470uF/25V capacitors on the power supply board in the sub-woofer that are the cause of buzzing, crackling and then eventually no sound. Go to Radio Shack and buy two Catalog #: 272-1030 470uF/35V capacitors and change them out. They are in the middle of the Power Supply PCB and are close to the long flat aluminum heatsink. Make sure you match the polarity properly when replacing. Your unit will be as good as new and will proibably last forever now.
Dec 18, 2007 | Philips HTS3450 System
Hotpoint WD440
On the power pcb panel, there is an eeprom. This gets corrupted and throws the machine into a frenzy. A replacement should include a new pcb and a new eeprom. Only from dealers unfortunately.
Aug 28, 2007 | Hotpoint Aquarius WD63 Front Load...
Zanussi FJS1225W Front Load Washer Logo
52 people viewed this question
Top Zanussi Washing Machines Experts
jimorris77
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
