Question about Konica Minolta DiMAGE S414 Digital Camera
Please help...I can't take any pictures!
Hi. When I try to take a picture, the camera focuses (even though the little red light is flashing rapidly) but nothing happens. If I try again it shuts itself off and "Err" appears on the screen. I put in new batteries and the same thing happens. Please help! Thanks!
  • mrelvis56 Nov 30, 2007
    My problem is exactly the same. I tried fresh batteries and reseating the memory card with no results.
  • bnymoore Dec 24, 2008
    I have the same problem. I found that turning off the flash I could again take pictures. Thanks...
  • 3 Answers
I have the excact same problem so it must be with all the cameras.it will only let me take pictures when i have the flash off.send it to a shop. that probably what i will do if i get the money
Posted on May 08, 2008
I actually figured out it's the flash that is broken...just wish I could fix it myself!
Posted on Sep 03, 2007
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
Possibility one : lens unit faulty and proper focus is not being achieved camera goes into error mode because of this and then it switches off to prevent further damage.( replace /repair lens unit ) Possibility two: shutter faulty . Lens delivers proper focus but when you try to take picture goes into error mode because shutter not coming on line or malfanctions. ( replace shutter only ).
I have a nikon 55-200mm lens for the D40X digital camera. The pictures I take are blurred. I use the auto settings. the 18-55mm lens works fine and there are no problems with the picture clarity. Is the...
One of a few things might be happening
1. Photos being taken at high zoom (i.e. 200mm) are susceptible to camera shake, even though the lens is focusing properly. The solution here is use a tripod, zoom out, or steady yourself.
2. Photos being taken without flash when flash should really be used will result in motion blur (which is slightly different than camera shake). This is due to the camera using a longer shutter speed to let more light in, with the side effect being that objects will move while the shutter is open, blurring the picture. The solution here is to use a flash, or take pictures in better light.
3. The camera may be focusing on something other than what you intended.
3. If you are taking photos in good light with a steady hand, and the camera is choosing the correct subject to focus on, then yes, the lens could need readjusted, though this is not a very likely scenario.
If the lens is "hunting" for focus, that could be a sign that something is amiss.
A local camera shop can verify the accuracy of focus for your lens.
Mar 04, 2011 | Nikon D40x Digital Camera
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Slow taking pic, flash flashes multiple times while lenses acts like it is trying to focus
The evolt cameras use the flash bursts as a "autofocus help". Try to find points with high contrast or edges to point one of the three autofocus points at (you see these points while looking through the viewfinder and they flash red as soon as the camera is focused).
So, flash bursts basically mean "too low light" some other situation which is hard for the camera to focus. In such situations, try to switch to MF mode (manual focus). Or you could buy an external flash (e.g. Olympus FL-36) which has a red light for autofocus assistance instead of flash bursts.
Dec 05, 2007 | Olympus EVOLT E-500 Digital Camera
Multiple flash firing
I would double check all your settings - even though you say it is on any flash setting, it sounds like it is using the nighttime flash setting (which does 2-3 rapid fire flashes).
Just go through every setting in the camera, and make sure that everything is set how you really want it, INCLUDING the daytime/nighttime, etc.
On the CAPTURE menu, check your adaptive light setting and make sure that you don't have it tweaked in some way to make the camera think EVERY picture is a nighttime picture.
I'd also check your "EV COMPENSATION" and "WHITE BALANCE", making sure those are set to "auto".
Hope that will work for you - good luck!
Oct 12, 2007 | HP Photosmart M22 Digital Camera
Problems storing pictures to Memory Card
Shawna, Since your camera is still under warranty, best thing will be sending it to the appropriate factory service center for repair the problem.
Aug 08, 2007 | Olympus EVOLT E-300 Digital Camera
Casio EX-Z57 Flash not working
Try resetting your camera and see if that helps. Sometimes it does. In REC mode press menu go to setup tab go up to reset press right arrow & highlight reset press set. If that doesn't work you are probably going to have to send it in.
Oct 29, 2006 | Casio Exilim EX-Z57 Digital Camera
DSC-W1 Focus Problems
Try taking some flash pictures (in fairly good light) in Manual Mode @ 1/500sec to rule that out though. Use "Center" or "Spot" autofocus. If you don't have a tripod, then use the self timer for these tests. If camera shake can be ruled out, and the camera has focusing problems even in bright light, then that unit is trashed. Sorry to hear that the Sony service center couldn't fix it right the first time. Demand a replacement.
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
My picture is blurry or out of focus.
ake sure your subject is within the camera's range. You should be at least 20 inches away to take a picture without the flash, and 20 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close-ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. See Chapter 4 for more information about how to change the shutter speed from the LCD menus. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Picture blurry or out of focus.
Make sure your subject is within the camera's range. You should be at least 31 inches away to take a picture without the flash, and 31 inches to 8 feet away to take a picture with the flash. You can take a picture as close as 8 inches in macro mode. When you take macro close- ups, make sure you have adequate lighting (with the flash disabled). Using a tripod will help you capture sharp pictures. Make sure you hold the camera steady after you press the shutter button (until the red light starts to flash), and your subject isn't moving. If you are shaking the camera when you lock the focus, a warning icon appears in the right corner of the LCD. If you want to photograph a moving subject, you can change the shutter speed while the camera is connected to your computer. Try increasing the shutter speed. For more information, see Chapter 6. Make sure your flash is not set to flash off. When you focus on a nearby object, your picture's background may appear blurry. Try changing your focus.
Sep 13, 2005 | Epson PhotoPC 750Z Digital Camera
Konica Minolta DiMAGE S414 Digital Camera Logo
291 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
