Question about Canon imageRUNNER 5000 Copier
Related to fixing
All type of paper's will exit from fixing unit but when we are copieng the A4 size paper ! paper will jam in betweem heat and preasser roll in fixing unit. pls help me that what can i will do for this machiene.
  • 168 Answers
Ok so were are you feeding the A4 paper from if from the bypass you need to select A4 size or free in the settings for the bypass tray
Posted on Dec 26, 2008
My copier canon ir2525 legal size paper jamming problem half paper exit unit out half paper exit assembly in A4 size and A3size 100%perfect exit plz solution this problem
Most common jam problems are caused by using thin paper 80g density or less. Recycled paper is the worst as it tends to tear easier as the their is only 20% new cellulose fibre in it and 80& is paper mache'. When using recycled paper, use min 100-120g weight papers and your jams will disappear.
May 29, 2015 | Canon Office Equipment & Supplies
How do i fix the little black piece that broke off of the fuser exit sensor on my Xante Ilumina?
Amanda,
The problem is related to the paper exit assy. Their is no problem with your fuser assy. Take a look at the exit document related to your problem. Usually that is cause when removing a paper jam, that switch flags break for pulling the paper in the back direction. You would have to replace the paper out exit swicth black actuator.
Oct 03, 2014 | Xante Ilumina® 502 Laser Printer
Erro code e02 in toshiba estudio 181
hello
dear you have to verify all the exit sensor related
1. do u have look on fuser unit drive gears.
2. is the exit rollers are good some time exit roller got damaged they don't hold hold paper to run out from machine.
3. do u have clean the exit sensor.
4. do you have verify that the exit sensor actuator is free to operate the sensor.
5. some time exit sensor actuator broken.
Aug 28, 2014 | Office Equipment & Supplies
Hi my samsung clp 310 printer regularly jams paper halfway to completion. ....
Hi
Please look at the printer properties under Paper, you will see that the type of paper used can be chosen.
1. This apparently makes the printer behave differently when the default is not chosen.
For example, when I choose Thick Paper, the printer feeds the paper inside the printer much slower than when default is chosen. This, most likely, is done to prevent the paper from jamming up somewhere inside from feeding too quickly.
Therefore, if one is finding that their printer is constantly having a paper jam, changing the paper type may have positive results.
2. Heat maybe another source of paper jams. Although there is no paper jammed in the laser printer, the laser printer may stop printing due from overheating. Therefore, if heat is the culprit, changing the paper type may not work.
Hope this helps !
Jul 22, 2010 | Samsung CLP 315 Laser Printer
Samsung CLP300 jams when normally printing, but will print test
If you are using a 6cm paper to print that is smaller than a A4 size paper.
do a check when you print did you select the correct paper size. as wrong paper size is print will course paper jam too.
Apr 08, 2010 | Samsung CLP 300 Laser Printer
Paper jam in exit area. How do you remove?
The paper jammed on fixing unit area. Probably the pressure roller is worn-out causing the paper to stick on it rather than sliding the paper out. Remove the fixing unit so that you can remove the paper. Removing the fixing unit needs a lot of skills, I recommend you call the nearest service center for assistance.
Feb 17, 2010 | Canon ImageRUNNER 1670F Copier
Can't send or receive faxes after fixing error code problem
your printer CHANGE PAPER TO
A4/LTR/LGL PLAIN
The paper size setting is set to a size other than
A4, letter or legal in fax receive mode.
The paper type setting is set to a type other than
PLAIN in fax receive mode.
Set the paper size setting to A4, letter or
legal and load paper of the same size.
Set the paper type setting to PLAIN.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
Printer says "Remove paper jam"
check that the paper tray is set to match the paper your printing - look also in the printer driver settings for the correct size. A4, Letter etc.. If that did not fix it make sure the paper take-up roller isnt worn.
Jan 20, 2008 | Office Equipment & Supplies
Paper jam and possible failure to pull A4 paper ?
1- you must remove the jam paper first
2- set the tray to LETTER or LEGAL not A4
A4 is european size not used in the U.S
Make sure the paper adjuster in the tray is touching the end of the paper size, also there should be some markings in the tray.
The noise is coming from the jammed paper, it is trying to feed itself but is stuck.
Dec 24, 2007 | Office Equipment & Supplies
Canon imageRUNNER 5000 Copier Logo
93 people viewed this question
old marine
old marine
