Hi, i have a problem with color laser printer xerox (can't remember model), the problem is please reboot printer error number 004321, please help to solve. thanks
    Guru:
  • 389 Answers
You should обратпться in service service. Тhe temprechure of block of the fastening insufficient, for functioning(working) the printer. This can be an usual preventive maintenance. Under thermo by sensor is going to the toner and the temperature is displayed untrue. Good luck you!
Posted on Sep 13, 2009
What causes error code 091-720 on a xerox colorqube 8900x printer?
That error signifies a printhead tilt fault. You need to replace the process drive camshaft kit, part number 8900-Z1.
http://www.iteminconline.com/8900-z1_8900-z1-xerox-8900-process-drive-camshaft-kit.htm
Feb 29, 2016 | Xerox ColorQube 8900X Multifunction Color...
Fault code 042-325 on xerox 6280 color printer
error code 042-325 on xerox mean the problem is the main drive motor.
Jul 22, 2014 | Xerox 6280DN Laser Printer
Please reboot printer (124-315)
How to reboot printer Xerox DocuPrint C4350 error code : printer (124-315)
Oct 03, 2011 | Samsung CLP 315 Laser Printer
How to repair a code 72 on a Xerox 6200 color laser printer
This is an NVRAM verify error. If the fault is persistent, even after a reboot, the only solution is to replace the engine board.
Jan 08, 2011 | Xerox Phaser 6200N Laser Printer
004321 restart printer error
This type of error code implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer.
Nov 30, 2010 | Dell 3100cn Laser Printer
How to reboot printer Xerox DocuPrint C4350 error code : 124-315
How to reboot printer Xerox DocuPrint C4350 error code : 009-383
Oct 24, 2010 | Xerox DocuPrint C4350 Laser Printer
Change ink cartradge 11ER00670, same error after new cartradge.
SYSTEM NEED TO BE RESET, CARTRIDGE MAYBE DEFECTICE, THE SWITCH MAYBE A PROBLEM, GO ONE LINE AND SEE IF ANYONE ELSE SEEN THESE TYPES OF PROBLEMS, GO ONLINE AND TYPE:
XEROX PHASER 5500N LASER PRINTER CARTRIDGE ERROR 11ER00670
ENTER
IF THAT WAS THE ERROR NUMBER YOU HAD
OR
XEROX PHASER 5500N LAZER PRINTER CARTRIDGE ERRORS
ENTER
OR
XEROX FOREM GROUP
ENTER
OR
MANUFACTURE NAME,MAKE,MODEL, DRIVERS AND SERVICE MANUAL
ENTER
ROD
Feb 09, 2009 | Xerox Phaser 5500N Laser Printer
Fan Failure Error 54
1 of 2 things.
You need to clean or replace the fan.
You have to remove the back, right side and top cover to access that fan.It is near the back just behind the fuser module.
It could also be the low voltage power supply fan. Most likely the fuser fan.
Once you remove the fan, there is a label on it, remove the label, There is a rubber plug behind the label, remove the plug and drip some lubricant into the fan. Reassembly and it should be ok.
I would recommend replacing the defective fan though.
Here is a very reliable part source.
https://www.partsdrop.com/store/
If you call ask for Britt and specify the model number and that you need a fuser fan and probably order a Power supply fan, Neither are very expensive.
Have both on hand to be 100 percent sure the problem is resolved, But its a 90 percent fuser fan failure code. It operated in a heated area and can dry out faster.
Mar 27, 2008 | Xerox Phaser 7700 Laser Printer
k24674
jasbo
jasbo
