Question about Nikon Coolpix S51c Digital Camera
Nikon s51 i dropped my moms camera and know the thing wont even turn on. the battery is fully charged. also when you barely shake it you here a rattle. HELP PLEASE!!
  • 88 Answers
What you have is called impact damage, this is not covered by warranty. Nikon can fix it for you, and it will probably cost you more to fix it than to buy a new one. I have a friend who fixes cameras.
http://www.cameradr.com/
He can do it faster and cheaper than Nikon.
Nate
Posted on Jan 08, 2009
Nikon s9300 - When I turn it on, the lense fully extends, but the screen stays black. I have to pop the battery out, then put back in for the lense to retract. Battery is fully charged and even tried
When the battery is fully charged, please put it in again. That means, if it is still in, remove it once again.
Switch it on, and even if you don't see a thing try to make a picture.
Then press the display button several times, to see if anything comes on the screen again.
If the camera does not respond after that, you should go back to the dealer, of contact Nikon.
Dec 21, 2013 | Nikon COOLPIX Cameras
My nikon s51 will not turn on when I plug the transfer cable into the camera
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer or Picasa.
Feb 08, 2013 | Nikon COOLPIX S51 Digital Camera
Hello I have this Nikon Camera (N55) and it just wont turn on. A few months back it worked and now it doesn't. I have the right batteries and film so I was just wonderig if there was anything I could...
I'm sorry that the Camera is not turning ON. Please follow the below troubleshooting steps and check the operation:
  1. Please make sure that battery is fully charged.
  2. If the battery is not used for a while, it is possible that it may be damaged or completely discharged even if it was charged fully before. Hence charge the battery again and check the operation.
  3. Remove and Reinsert the battery and check the operation.
  4. Try with a different battery. If the issue persists with new fully charged battery, service may be required. You can click hear to setup a service for the Camera.
Thanks for understanding. Please let me know if you require further assistance.
Sep 10, 2011 | Nikon N55 35mm SLR Camera
Nikon COOLPIX S51 Digital Camera Charge usb
The S51 does not charge via the USB. Connecting the camera to a computer merely drains the battery faster, since the camera has to expend power communicating with the computer (even if it's only to say it has nothing to say).
The S51 comes with an MH-62 charger, which plugs into a wall outlet. This allows you to charge one EN-EL8 battery while using another in the camera.
If you need a charger, you can order one from Nikon at
http://shop.nikonusa.com/store/nikonusa/en_US/pd/productID.213504000
or a third-party one for about half the price at
http://www.overstock.com/Electronics/Dolica-Nikon-MH62-Charger/3540124/product.html
Jan 03, 2011 | Nikon COOLPIX S51 Digital Camera
Coolpix s51
The camera should have come with an MH-62 battery charger. Put the battery into the charger and plug the charger into a wall outlet.
If you acquired your camera without a charger, you can order one from Nikon at http://www.nikonmall.com
Mar 01, 2010 | Nikon COOLPIX S51 Digital Camera
My Nikon COOLPIX S51 will not turn on.
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 07, 2009 | Nikon COOLPIX S51 Digital Camera
Transfer pictures from my Nikon, Coolpix S51
Hi!
Try to plug into a different USB port. If that does not help then go to Control panel->systems-> hardware tab-> device manager->and now try to see if your Camera appears under the options listed (would be under Scanners and Camera, Click on every + sign to see)
Do rate the solution.
Thanks
Rylee
Feb 10, 2009 | Nikon COOLPIX S51 Digital Camera
Nikon s51 coolpix "lens error" upon start up yeah my nikon s51 coolpix camera worked like champ, for about 8 mos, darn thing giving me "lens error" message , wont let me look at pictures...
i had the error and i just banged the left side of the camera against my palm a few times and turned it back on. It worked for me maybe it will work for you
Feb 04, 2009 | Nikon Coolpix S51c Digital Camera
Battery light is orange
sir,how old ur battery?and u clean ur charging pad pins
Mar 04, 2008 | Nikon Coolpix S51c Digital Camera
Nikon S51 transfering pics to computer?
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program, such as Picasa.
Organize edit and share your photos
Jan 28, 2008 | Nikon Coolpix S51c Digital Camera
Nikon Coolpix S51c Digital Camera Logo
82 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
