Question about Whirlpool Duet GHW9150P Front Load Washer
F35 code I have a Whirlpool front load washer. The suds light comes on and changes to f35 code . Any ideas? thanks, doug
  • jdtech May 11, 2010
    Try running several rinse cycles several and using less detergent in the future Be sure to use HD detergent Also check to make sure the tub is draining properly if not clean pump filter
  • 15,935 Answers
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 28, 2010
I have a Maytag front load Washer Model MHWE500VW10 (5000 Series) . The dreaded F35 / SUD error code keeps coming up. I have checked the tubing and electrical connections to the Water Level Pressure...
Hi
There is only one Analog Pressure Sensor Switch Part no. W10156252, another one that it has is the water level switch (part no W10415587). I believe you are talking about the first one as that is what error code F35 means (ANALOG PRESSURE SENSOR FAILURE). Hope this helps...please post back for further assistance.
Daniel
Sep 17, 2011 | Maytag MAH21PDD Commercial Front-Load...
Code f35 and sud on washer machine/whirlpool duet front loader
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
May 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Suds and F35 keep shuting down my laundry day:(
Remove the service panel and see if the filter has something in it77cb04b.jpg2402fad.jpgf032166.jpg
May 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
SUD and F35 codes come up at beginning of cycle
open front bottom cover their is drain pump open filter from drain pump be care full there is water in your drain pump (may be 1 or 2 gal water)
clean filter put it back. run washer..if you get same error again then change your detergent and use less make sure you use he detergent. let me know it help or not please. thanks.
Jun 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
F35 and suds it turns off after 5 mins and whenever I put it on rince only it still cuts off.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
May 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
587 people viewed this question
Dan Webster
Dan Webster
Sal De
