Question about GE WJSR2070B Top Load Washer
GE Washing machine won't spin in rinse cycle
My three year old GE washing machine will not spin when it is supposed to in the spin cycle, everything else works fine. The motor does not turn on in the spin cycle. The agitator works fine.
  • 12 more comments
  • Anonymous Aug 21, 2008
    my 3 year old waher is giving me a problem, firt it leaks when it is on super water level,so I can only use the machine on small load or large/ now it will not rince or spin out.some say it might be the timer sewitch and others say it may be the lid switch. please help thank you. mpitts001@nycap.rr.com
  • bblmt Sep 16, 2008
    I have the same problem and the lid switch makes sense, but I am having trouble opening the top to get to it.
  • changlp Mar 20, 2009
    My GE washing machine won't drain and spin. Not sure if it will spin if the water is out of the system. Please help.
  • Bob Reineke
    Bob Reineke Mar 27, 2009
    Every thing work as normal except it won't spin out. The drain works fine and the lid contact works fine. #WBSE3120B2ww
  • Anonymous Mar 29, 2009
    door lock clicks off
  • Anonymous Mar 13, 2014
    Ge wash machine makes clicking niose when going into spin cycle, but will not spin with clothes in it
  • Anonymous Mar 16, 2014
    Spin cycle will not begin. Is the spin cycle switch not working
    Rinse and spin cycle does not begin, is the switch button the the door trips the problem
    The agitator works fine but the machine will not spin there is a click and slight movement but not spinning
  • Anonymous Mar 17, 2014
    Aqua cycle 400 series
    ge washing machine model wbvh6240fww cant change cycle on dial
  • Anonymous Mar 20, 2014
    rinse and spin not working.
  • Anonymous Mar 25, 2014
    will not spin
  • Anonymous Mar 28, 2014
    spin cycle works fine, but wont agitate...
    President:
  • 1,294 Answers
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Posted on Sep 12, 2007
  • 60 Answers
Your timer needs to be replacedthe contacts are sticking
Posted on Sep 13, 2007
It is probably the lid switch. It is an easy fix.
Posted on Jun 19, 2008
SOURCE:
Spin cycle does not work. Machine only hums when it should spin.
Check the motor capacitors. Wash cycle and run cycle capacitors are different in some m/cs.If these are OK motor winding to be checked.
Now it is ten years old and you are likely to get ball bearing problem. Get an repair estimate and decide which suits your budget.
Apr 06, 2010 | GE WBSE3120B Top Load Washer
GE washer WHSR2070VWB about 9 years old does not spin dry clothes. All of the cycle works except the final expulsion of water
If the cycle stops when it is supposed toi drain , that means that there is a problem with the drain pump.
Oct 12, 2008 | GE Washing Machines
Our GE washing machine makes a horrible sound during the spin cycle. It is only a couple of years old. Everything seems to be working fine otherwise, just tremendously noisy during this cycle. This just...
you will need to take a look at the clutch which sits on the top of the motor. if it comes apart, and it can if the machine is overloaded, you will need to replace the clutch. once you remove the "clutch clip", it is horseshoe shaped, you will need to replace it. you cannot reuse it as it won't hold. hope this helps you.
Oct 14, 2009 | GE WBSR3140DW Top Load Washer
Spin cycle stopped on 10 yr old Amana washer
its the brushes on your motor or your pump is blocked or defective
Jun 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
GE Top load washer 15years old. noisy when spinning
washer making a load cluck noise when the spin cycle starts.
It only happens when the motor turns slow for the first minute during the spin cycle. Otherwise it works fine.
if the motor is proper then the bearings in the motor got rusted and that needs replacement.the beasrings are located on the back of the motor.
Apr 03, 2009 | GE WVSR1060A Top Load Washer
Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Feb 13, 2009 | GE Spacemaker Washer and Dryer Electric...
GE WASHER WJRR4170G0WW-SPIN Cycle does not work- just make sound.
My washer is 2 years old and this is 1/2 the cost I paid for it new. My review of this product after 35 years of technical experience; GE products (Hotpoint)aren't worth buying any longer.
The problem is the Motor. There is an electronic PC Board attached to the top of the motor and under the drip protector, which protects the PC Board. On this board, there is a green flashing light which displays trouble codes by flashing. Unplug the washer, remove the 3 screws from behind the control panel. Slowly pull the control panel toward you and slide it to the right to release. Inside the washer, there is a diagram with the trouble codes printed in the lower right hand corner. Everything else is self explained. Flashes indicate the problem and the solution is all written. Since I have the same problem and a technician, this is a defective product GE has discontinued and re-manufactured. After phoning GE the motor # Normal 0 WH20X10051 cost $252.25 to ship to my location.
Jan 09, 2009 | Washing Machines
GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
coupling between motor and drive assy broken. take motor loose and you can get it out. Visual check first to see if motor is running when in agitate cycle.
Dec 03, 2008 | GE WBSE2090A Top Load Washer
GE Top Load Washer 10 yrs. old, used for 3 years, stored after that
the water must drain out of the tank b4 it can spin make sure the pump is working ok
Nov 17, 2007 | GE WBSR3140DW Top Load Washer
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
GE WJSR2070B Top Load Washer Logo
5,108 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
