Question about Hoover HW160M Front Load Washer / Dryer
Leaking i got water leaking out of the powder/comfort tray the leak only seems to happen when the cycle is ready to add the comfort
  • Hoover Master
  • 3,463 Answers
I sugest that you remove the dispenser from the waher, remove every piece of it and thoroughly clean all parts, particularly the part(s) that take the conditioner down.Trust this helps you.
Plz rate my solution.
Thanks.
Posted on Dec 26, 2008
My machine seems to be stuck on a drain cycle
Sounds like your 'anti flood' system is activated. This happens when a leak fills the drip tray on the base of the machine, and a anti flood float switch senses water in the tray. Leaks can come from several sources - loose pipes, leaking door gaskets - even opening the door while the machine is hot! i.e. to add an extra item after the machine has started, for example. ISOLATE THE POWER and examine the base tray, if its a free standing machine tip the machine back at an angle (The Hemlich manoeuvre for Dishwashers lol) and the water will flood out - if built in, remove the lower front panel. Once the water is removed, the machine should start - but if the problem occurs, the leak is still there. Zanussi machines are tricky - you'll probably need an engineer to sort it out - expect not much change out of £100. Cheers!
Oct 16, 2015 | Zanussi 18 in. DCS12W Free-standing...
Water leaking from the panel under the turn knob
Water comes in the back, then goes via to solenoid valves to the back of the powder tray, it then is distributed through holes above each compartment, take out the powder tray (push down the blue bit at the back of the softener compartment) and check for cracks or even blockages, (water goes from tray down the back and through a short rubber hose straight into the drum.
Feb 11, 2014 | Russell Hobbs RH1042 Frontload Washing...
Scotsman prodigy leaking water
How to work on Scotsman Prodigy Ice Machine
Jan 16, 2014 | Scotsman Kitchen Appliances - Others
Frigidaire dishwasher leak
run it with no soap. if you get no leaks then cut back on your soap. you may need to run washer a few cycles to get rid of excess soap.
Sep 02, 2012 | Frigidaire Dishwashers
Leaking water
Water can't leak out the top from overloading unless the entire tub is full of water which is a major malfunction, or an inlet hose between the powder drawer and tub is somehow blocked (extremely unlikely).. Are you using topload detergent? Normal detergent can foam up and out through the drawer and leak onto the floor..
Normally water enters through the top of the powder tray to disperse it into the tub. pull out the tray slightly while filling to see how this works. You might be able to identify that the water is not flowing properly. Normally you can really pack into a front loader, I've been thrilled with my 5100 for 8yrs.
If this doesn't help let me know and I'll suggest next step.
May 14, 2010 | Whirlpool AWM5125/1 Front Load Washer
Small leak,maybe from underneath the powder tray on hotpoint wma
the shaft seal on the plastic tub in the machine may be leaking or the pump out hose that goes to the water pump may be leaking,if you can remove a cover from the machine and put water in the machine and watch it go through the cycles you may be able to spot where the problem is
May 23, 2009 | Washing Machines
Put washing powder in tray ,machine doing wash but leaving large residue of powder
Don't put the powder in the tray. Select you wash cycle, let the water run into the washing machine, then add the powder.The powder should dissolve before you put your clothes inside the machine. Let the washing machine fill up to almost half way and add clothes. This should stop the clothes from getting the residue powder on it.
Mar 23, 2009 | Whirlpool Washing Machines
Water is leaking out of the washing powder drawer
the spray holes in the soap manifold are partially blocked and spraying at an angle. try to reduce the water flow pressure at the feed tap and clean the water holes in the soap tray manifold (above the tray).
Feb 16, 2008 | Whirlpool AWM8143 Front Load Washer
Washing machine wm1814cw
Check the wire ring that goes around the rubber seal located just inside the door - we had to call a repair person out one day because our door was leaking, and he told us it's important that the spring be at the top of the door opening to prevent leaks from happening. He had a hard time moving the spring to the top but that seemed to help.
A few months later we found a water leak from our soap tray, so we had the tray replaced under warranty, although I'm not sure that helped because the replacement looked identical to the old one. It only leaked when we used powdered Oxyclean and liquid soap in the tray at the same time; the leaking water ran behind the front cover and dripped out onto the floor all along the front of the machine, mostly near the left corner, but we stopped putting Oxyclean into the tray & the problem stopped. Hope that helps.
Feb 05, 2008 | LG WM1814CW Front Load Washer
Water leaking
There is a small plastic "gate" that is left down for liquid detergent and moved back and up for powder detergent. If this piece is left down and powder detergent is used, the water leaks and the detergent won't go into the washer properly.
Oct 13, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Hoover HW160M Front Load Washer / Dryer Logo
106 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
